Hi,
The L-NAV does everything an S-NAV does, except that the S-NAV has a waypoint database and you can create tasks. There may be a few other features, but that was the main thing. When the GPS-NAV is connected to either of them, you use the waypoints and tasks in the GPS-NAV, so there is no need for them in the S-NAV. So at the end of the production they didn't sell many S-NAVs - only L-NAVs. But there is nothing wrong with using an S-NAV with a GPS-NAV. Paul Remde "Solo" wrote in message ... What are the diffrences betwenn the L/NAV an S/NAV? -- Solo |
The real trick there is finding the GPS-NAV. I couldn't find one and
ended up with a Colibri I got from Paul. It seems it will work quite well with my S-NAV, at least on my desk. I have yet to fly with all this. If I run across a GPS-NAV for a good price I might pick it up but without the GPS-NAV all that seems to be missing is the goal altitude and you also don't have the final glide around a turnpoint. How often is the goal altitude really needed? Here, unless you're on your way to the last turnpoint or home you want to stay in the best lift which is usually above a certain altitude. It often has little to do with the ground elevation of the goal and more to do with the airmass. So you'd have to manually enter your "floor" altitude anyway. If you have something like GNII on a PDA you have the final glide around a turnpoint based on the GPS data and air and GPS speed-to-fly info on the S-NAV. The bottom line is all this stuff can only tell you what's been going on behind you and not what's going on with the airmass ahead. It still comes down to the pilot. I seem to have gotten off track but I didn't see anything in the S-NAV or manual about a waypoint database. Mine is the current version 7.9. Maybe that was dropped from earlier versions since it is available in the GPS-NAV. Bob On Jan 6, 7:30 am, "Paul Remde" wrote: Hi, The L-NAV does everything an S-NAV does, except that the S-NAV has a waypoint database and you can create tasks. There may be a few other features, but that was the main thing. When the GPS-NAV is connected to either of them, you use the waypoints and tasks in the GPS-NAV, so there is no need for them in the S-NAV. So at the end of the production they didn't sell many S-NAVs - only L-NAVs. But there is nothing wrong with using an S-NAV with a GPS-NAV. Paul Remde "Solo" wrote in ... What are the diffrences betwenn the L/NAV an S/NAV? -- Solo- Hide quoted text -- Show quoted text - |
One more thing. The S-NAV is black around the screen and the L-NAV is
more of a silver. The S-NAV looks better in the panel, at least my panel. On Jan 6, 9:28 am, wrote: The real trick there is finding the GPS-NAV. I couldn't find one and ended up with a Colibri I got from Paul. It seems it will work quite well with my S-NAV, at least on my desk. I have yet to fly with all this. If I run across a GPS-NAV for a good price I might pick it up but without the GPS-NAV all that seems to be missing is the goal altitude and you also don't have the final glide around a turnpoint. How often is the goal altitude really needed? Here, unless you're on your way to the last turnpoint or home you want to stay in the best lift which is usually above a certain altitude. It often has little to do with the ground elevation of the goal and more to do with the airmass. So you'd have to manually enter your "floor" altitude anyway. If you have something like GNII on a PDA you have the final glide around a turnpoint based on the GPS data and air and GPS speed-to-fly info on the S-NAV. The bottom line is all this stuff can only tell you what's been going on behind you and not what's going on with the airmass ahead. It still comes down to the pilot. I seem to have gotten off track but I didn't see anything in the S-NAV or manual about a waypoint database. Mine is the current version 7.9. Maybe that was dropped from earlier versions since it is available in the GPS-NAV. Bob On Jan 6, 7:30 am, "Paul Remde" wrote: Hi, The L-NAV does everything an S-NAV does, except that the S-NAV has a waypoint database and you can create tasks. There may be a few other features, but that was the main thing. When the GPS-NAV is connected to either of them, you use the waypoints and tasks in the GPS-NAV, so there is no need for them in the S-NAV. So at the end of the production they didn't sell many S-NAVs - only L-NAVs. But there is nothing wrong with using an S-NAV with a GPS-NAV. Paul Remde "Solo" wrote in ... What are the diffrences betwenn the L/NAV an S/NAV? -- Solo- Hide quoted text -- Show quoted text -- Hide quoted text -- Show quoted text - |
I noticed that too. But a quick call to Cambridge and they sent me a new
front stick-on panel for my LNAV that was black (meant for an SNAV). A felt tip marker took care of blacking out the "SNAV" and I was in business. Charge = $0 bumper wrote in message ups.com... One more thing. The S-NAV is black around the screen and the L-NAV is more of a silver. The S-NAV looks better in the panel, at least my panel. On Jan 6, 9:28 am, wrote: The real trick there is finding the GPS-NAV. I couldn't find one and ended up with a Colibri I got from Paul. It seems it will work quite well with my S-NAV, at least on my desk. I have yet to fly with all this. If I run across a GPS-NAV for a good price I might pick it up but without the GPS-NAV all that seems to be missing is the goal altitude and you also don't have the final glide around a turnpoint. How often is the goal altitude really needed? Here, unless you're on your way to the last turnpoint or home you want to stay in the best lift which is usually above a certain altitude. It often has little to do with the ground elevation of the goal and more to do with the airmass. So you'd have to manually enter your "floor" altitude anyway. If you have something like GNII on a PDA you have the final glide around a turnpoint based on the GPS data and air and GPS speed-to-fly info on the S-NAV. The bottom line is all this stuff can only tell you what's been going on behind you and not what's going on with the airmass ahead. It still comes down to the pilot. I seem to have gotten off track but I didn't see anything in the S-NAV or manual about a waypoint database. Mine is the current version 7.9. Maybe that was dropped from earlier versions since it is available in the GPS-NAV. Bob On Jan 6, 7:30 am, "Paul Remde" wrote: Hi, The L-NAV does everything an S-NAV does, except that the S-NAV has a waypoint database and you can create tasks. There may be a few other features, but that was the main thing. When the GPS-NAV is connected to either of them, you use the waypoints and tasks in the GPS-NAV, so there is no need for them in the S-NAV. So at the end of the production they didn't sell many S-NAVs - only L-NAVs. But there is nothing wrong with using an S-NAV with a GPS-NAV. Paul Remde "Solo" wrote in ... What are the diffrences betwenn the L/NAV an S/NAV? -- Solo- Hide quoted text -- Show quoted text -- Hide quoted text -- Show quoted text - |
Another Cambridge 302 logger bug | [email protected] | Soaring | 8 | July 19th 05 04:05 PM |
Commercial - Updated Cambridge 302A | Paul Remde | Soaring | 2 | December 16th 04 07:35 PM |
Cambridge Instruments | Ian McPhee | Soaring | 2 | June 18th 04 10:14 AM |
Cambridge Aero Explorer Fix | Guy Byars | Soaring | 8 | May 19th 04 03:04 AM |
Updated IGC approval documents for Cambridge GNSS flight recorders | Ian Strachan | Soaring | 0 | August 27th 03 05:28 PM |
