Confusion about when it's my navigation, and when it's ATC
Old January 6th 07, 02:28 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Confusion about when it's my navigation, and when it's ATC
Neil Gould writes:
If the real aircraft can't get to a FL, *any* representation of the
aircraft's behavior at that altitude is incorrect.
Not so. The aircraft could be placed there by another aircraft, in
which case it would have some sort of behavior that presumably could
be simulated. It just can't get there under its own power. Slewing
functions in a simulator are the equivalent of carrying the aircraft
to that altitude in real life.
Thus, while there may not be much practical reason to simulate the
aircraft at that altitude, since it is physically possible for it to
be at that altitude, it is also possible to simulate it at that
altitude. However, if nobody ever tests the aircraft for real at that
altitude, any simulation of its behavior there remains a matter of
speculation and unverifiable.
Old January 6th 07, 03:01 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Neil Gould
Recently, Mxsmanic posted:
Neil Gould writes:
That is an absurd scenario, and of no use in the simulation of the real
aircraft.
Bottom line: if the game allows the aircraft to reach a FL that is twice
the service ceiling of the real aircraft, then the engine is modelled
incorrectly. If the engine is modelled incorrectly, everything else about
the aircraft's behavior in the game is suspect. Of course, it is a
non-issue for those of us that actually fly.
Neil
Old January 6th 07, 03:39 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Neil Gould writes:
aircraft.
I agree. But the important point is that nobody knows whether the
simulation is correct or not, because nobody has tried hoisting a 172
to that altitude to see how it flies.
incorrectly.
MSFS does not allow that. The only way to get that high is by
slewing.
Of course, it is a non-issue for those of us that actually fly.
You seem to be pretty upset over it.
Old January 6th 07, 04:30 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
You have a talent for causing real pilots to have that emotion. You
need a lot of work on tact and interpersonal relationships. I suspect,
though, you just don't care that you come off as arrogant, ignorant, and
obnoxious.
Old January 6th 07, 04:48 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Sam Spade writes:
They choose their emotions; I don't. Smart pilots tend to be
relatively unaffected, but it's still their choice.
Old January 6th 07, 09:49 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Neil Gould
Neil Gould writes:
Why would anyone be upset over a non-issue? I'm certainly not.
Neil
Old January 6th 07, 09:42 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Neil Gould writes:
Of course.
Old January 6th 07, 09:11 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
bdl
Why is the service ceiling of a 172 set so low then? Is it your
contention that if a B-29 dropped a 172 (i.e. "slew") from FL300 it
would continue to fly?
That its engine would somehow magically find enough oxygen to feed the
normally aspirated engine?
You'll construct anything in your mind to maintain your fantasy won't
you?
Old January 6th 07, 09:44 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
bdl writes:
Because it cannot climb in any useful way above a certain altitude,
and it's not a high-performance aircraft.
Is it your contention that if a B-29 dropped a 172 (i.e. "slew") from FL300 it
I don't really know. I think it probably would, but it would be
pretty unstable.
It doesn't need an engine to fly.
