![]() Sam Spade wrote: wrote: Pilots are routinely taken below the floor of Class B airspace when exceeding 200 knots. Most airline pilots have no idea where the boundaries or floors of Class B airspace are located. No one cares except the occasional fed on the jump seat who has a thing about it. But those pilots at least know such a FAR exists. It seems very odd to me that a CFI or check pilot signed a guy off to fly something doing more than 250 knots and the guy isn't aware of the FARs. -Robert, CFII |
On Sat, 06 Jan 2007 08:21:47 -0800, Sam Spade
wrote: Pilots are routinely taken below the floor of Class B airspace when exceeding 200 knots. Most airline pilots have no idea where the boundaries or floors of Class B airspace are located. No one cares except the occasional fed on the jump seat who has a thing about it. This is what I've observed too. Pilots flying hi level do not bother with low level charts nor class B charts. Only hi level charts and sid/star charts. Not saying it is safe, legal or proper, just that it's normal ops. Sam, would it be true too for the 2500 AGL within 4 nm limitation too, in your opinion? Secondly, is there some atc requirement that if your destination is the primary airport in a class B, then atc is required to keep you in class B, and not vector you below? Stan |
![]() Sam Spade wrote: Secondly, is there some atc requirement that if your destination is the primary airport in a class B, then atc is required to keep you in class B, and not vector you below? That is policy to the extent it can be done without creating some other traffic problem. But, there is no "rule." Althought ATC can authorized it, there is a rule. 91.131 (2) Unless otherwise authorized by ATC, each person operating a large turbine engine-powered airplane to or from a primary airport for which a Class B airspace area is designated must operate at or above the designated floors of the Class B airspace area while within the lateral limits of that area. Why do I get the feeling that none of you guys have ever flown anything that does 250 knots? -Robert, CFII |
On 7 Jan 2007 21:11:01 -0800, "Robert M. Gary"
wrote: Sam Spade wrote: Secondly, is there some atc requirement that if your destination is the primary airport in a class B, then atc is required to keep you in class B, and not vector you below? That is policy to the extent it can be done without creating some other traffic problem. But, there is no "rule." Althought ATC can authorized it, there is a rule. 91.131 (2) Unless otherwise authorized by ATC, each person operating a large turbine engine-powered airplane to or from a primary airport for which a Class B airspace area is designated must operate at or above the designated floors of the Class B airspace area while within the lateral limits of that area. Why do I get the feeling that none of you guys have ever flown anything that does 250 knots? That's why I'm waiting to finish the G-III before joining this thread. Vne on the Deb is 225....MPH so it won't be with that. -Robert, CFII Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Robert M. Gary wrote:
Sam Spade wrote: Secondly, is there some atc requirement that if your destination is the primary airport in a class B, then atc is required to keep you in class B, and not vector you below? That is policy to the extent it can be done without creating some other traffic problem. But, there is no "rule." Althought ATC can authorized it, there is a rule. 91.131 (2) Unless otherwise authorized by ATC, each person operating a large turbine engine-powered airplane to or from a primary airport for which a Class B airspace area is designated must operate at or above the designated floors of the Class B airspace area while within the lateral limits of that area. Why do I get the feeling that none of you guys have ever flown anything that does 250 knots? -Robert, CFII And, doesn't it say "unless otherwise authorized by ATC?" The pilot of a large turbine-powered airplane cannot drop below the floor unless ATC sends them there. I don't know where you get your feeling. I suspect I have a lot more air carrier large jet time that you do, and let me assure you no one in the airline business refers to a Class B (TCA for many years) chart since no airline pilot in his/her right mind ever cancels arriving at a Class B airport. ATC takes aircraft out the sides of Class B, and sometime returns them below the floor of an outer area. I did my fair share of ferrying aircraft from KONT to LAX and the clearance was always at 4,000, handed off to LAX Approach Control (pre-SoCal) days well below the floor of Class B. On that one most of us were smart enough to stay at 200 knots; if not assigned something less before the handoff. |
![]() Sam Spade wrote: And, doesn't it say "unless otherwise authorized by ATC?" The pilot of a large turbine-powered airplane cannot drop below the floor unless ATC sends them there. Your browser appears to be truncating previous posts so I'll repost the statement I made in the posting you are referring to... "Althought ATC can authorized it, there is a rule." -Robert |
Sam Spade wrote: And, doesn't it say "unless otherwise authorized by ATC?" The pilot of a large turbine-powered airplane cannot drop below the floor unless ATC sends them there. Your browser appears to be truncating previous posts so I'll repost the statement I made in the posting you are referring to... "Althought ATC can authorized it, there is a rule." -Robert But, that is not a rule that requires ATC to keep you in Class B. It is just the opposite. The OP wanted to know whether ATC would assure containment within Class B. It was my choice of words to say there is no rule that requires to to that, but it is FAA policy to the extent practical. The regulation you cited is their authority to deviate from that policy. |
Sam Spade wrote:
That is policy to the extent it can be done without creating some other traffic problem. But, there is no "rule." First off, I'm a (very) light a/c IFR pilot. But having listened to Channel 9 on UA for 135000 miles this past year, it is my (again, limited) understanding/guess that on the approach the IAS is per the pilots discretion AND within the FAR's. If there will be a traffic problem, then ATC will issue to the affected a/c either delay vectors or speed restrictions. It is common to hear "maintain 180 IAS until 6 DME" where the pilots slow the plane to landing speed while descending on the ILS. I don't recall clearance of a IAS "at least 200" as I usually mentally read back clearances but I personally don't have to worry about the FAR's since I'm a lowly piece of luggage at seat 2A on a A320 rather than being the busdriver. I only wish an Archer could go that fast. I just wish I could rent an Airbus for 100k frequent flier miles per hour. ;-) Gerald |
Propeller thrust question | xerj | Piloting | 11 | November 25th 05 03:12 AM |
Crosswind Landings... But airspeed? | Jmarc99 | Soaring | 21 | October 4th 05 07:54 PM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
speed record set by scramjet - fair? | Don French | Piloting | 55 | November 28th 04 01:57 PM |
Overweight takeoff / flight | Koopas Ly | Piloting | 50 | December 3rd 03 11:53 PM |
