LPV vs LNAV/VNAV?
Old January 7th 07, 02:17 PM posted to rec.aviation.ifr
Sam Spade
Default LPV vs LNAV/VNAV?
Andrew Sarangan wrote:
Sam Spade wrote:
paul kgyy wrote:
Both of these options require a WAAS receiver, I presume?
Yes, and if WAAS is not available to the standards required by the specs
then the 146 box will not accept the WAAS solution, which means (using
Garmin as an example) LPV, L/VNAV, and LNAV+V will not be available;
only LNAV will be available.
Something I never understood is why LNAV approaches don't automatically
show a glideslope so that the airplane arrives at the MDA at the VDP.
With the 146 spec you will often have an advisory glideslope to MDA.
That is the LNAV+V mode and will be provided if Jeppesen has coded that
capability into the approach's database string. As Garmin says in the W
handbood, not all LNAV-only IAPs have been so coded.
Old January 7th 07, 02:27 PM posted to rec.aviation.ifr
Sam Spade
I misstated that somewhat.
If I read it correctly (assuming WAAS is available and passes muster)
you will always get LNAV+V on an LNAV-only IAP, thus you will have
vertical guidance to MDA.
If, on the other hand, it is an LNAV/VNAV approach you will get L/VNAV
if Jeppesen has that approach so coded, otherwise you will get LNAV+V.
You'll have vertical guidance in both cases, but I presume you can only
use the DA concept and VNAV minimums if you get the L/VNAV annuciation.
Old January 7th 07, 03:17 PM posted to rec.aviation.ifr
Stan Prevost[_1_]
"Sam Spade" wrote in message
Sam Spade wrote:
If I read it correctly (assuming WAAS is available and passes muster) you
will always get LNAV+V on an LNAV-only IAP, thus you will have vertical
guidance to MDA.
Can an RNAV approach have stepdown fixes on the final approach segment?
Old January 7th 07, 03:59 PM posted to rec.aviation.ifr
Sam Spade
guidance to MDA.
Yes.
When VNAV first came in they could only be an an LNAV-only IAP. Then,
quite a few years ago that was changed to permit them for LNAV minimums
on an LNAV/VNAV IAP.
Old January 7th 07, 07:20 PM posted to rec.aviation.ifr
Stan Prevost[_1_]
Yes.
quite a few years ago that was changed to permit them for LNAV minimums on
an LNAV/VNAV IAP.
An "advisory" guide slope could only be applied to a final approach segment
without stepdown fixes, or one in which the glide slope clears the
obstacle(s) by the required margin. I doubt that all LNAV-only approaches
have been TERPSed for that, especially those without VDPs.
LNAV, VNAV and LPV Andrew Sarangan Instrument Flight Rules 5 January 14th 07 01:57 PM
LNAV preferable over LNAV/VNAV [email protected] Instrument Flight Rules 4 October 16th 05 06:34 PM
GPS approaches with VNAV vertical guidance Doug Instrument Flight Rules 18 November 2nd 04 10:36 PM
CNS-80 VNAV John R. Copeland Instrument Flight Rules 17 October 28th 04 04:24 AM
Which GPS Support LNAV/VNAV? C Kingsbury Instrument Flight Rules 1 October 23rd 04 12:28 AM
