GPS approaches with VNAV vertical guidance
Old November 1st 04, 04:21 AM
Doug
Default GPS approaches with VNAV vertical guidance
With all the talk about the GNS80 and the Garmin 430 having VNAV and
LAAS capability, I would like to know something. Are there any actual
approaches in use that one can fly, today, that use these features? Do
you get vertical guidance from GPS derived altitude or is it vertical
guidance from altimeter derived altitude? Where are these approaches?
Old November 1st 04, 07:17 PM
Roy Smith
Once it works, I believe your advantage with be with LPV minimums more than
VNAV/LNAV minimums.
The plate shows a catagory of "GLS PA DA", which I decode as "GPS
Landing System, Precision Approach, Decision Altitude" (with minimums
shown as NA). Is that the same as the LPV you're talking about?
Old November 1st 04, 07:48 PM
Dave Butler
VNAV/LNAV minimums.
Take a look at RNAV(GPS) RWY 36 at OSH for an example of an approach with
different LPV, VNAV, and LNAV minima.
Dave
Old November 2nd 04, 02:20 AM
Roy Smith
Dave Butler wrote:
VNAV/LNAV minimums.
Dave
Hmm, not so much difference as I would have thought. The LPV only gets
you another 40 feet and 1/4 mile. Better than nothing, I guess, but
still not an earth-shattering improvement.
Is the idea that the synthetic GS for the LPV will be 3 degrees like a
real GS, or will they be all sorts of different angles? I pretty much
know what power settings I need to track a 3 degree GS, and it would be
a shame if I couldn't leverage that knowledge on the LPV.
Old November 1st 04, 08:18 PM
Barry
GLS does stand for "GPS Landing System," and would provide capability
equivalent to CAT I ILS (200 ft decision height/altitude). WAAS was
originally supposed to provide this, but due to integrity issues is only good
down to 250 ft, which is the limit for LPV approaches. Current plans for WAAS
upgrades include better coverage and redundancy, but not GLS. There are
tentative plans to modernize GPS and add a new civil frequency; if this is
done, then WAAS might provide GLS at some time after 2013.
Old November 2nd 04, 01:35 PM
Jon Parmet
"Barry" wrote in message ...
Just a nitpick:
GLS actually stands for "GNSS Landing System." The intention is have
the term encompass any satellite navigation system, of which "GPS"
(the U.S. based system) is (currently the only certified operational)
one.
It can eventually apply to the European, Japanese, Indian, etc.,
systems if/when those systems support it.
Old November 2nd 04, 01:28 PM
VNAV/LNAV minimums.
No. GLS is on hold. It would be equivalent to ILS. LPV is close to ILS, but
not quite there. Here is the info in the current AIM (1-1-20):
"2. A new type of APV approach procedure, in addition to LNAV/VNAV, is being
implemented to take advantage of the lateral precision provided by WAAS. This
lateral precision, combined with an electronic glidepath allows the use of TERPS
approach criteria very similar to that used for present precision approaches,
with adjustments for the larger vertical containment limit. The resulting
approach procedure minima, titled LPV, may have decision altitudes as low as 250
feet height above touchdown with visibility minimums as low as 1/2 mile, when the
terrain and airport infrastructure support the lowest minima. LPV will be
published on the RNAV (GPS) approach charts (see paragraph 5-4-5, Instrument
Approach Procedure Charts)."
Old November 1st 04, 03:13 PM
C Kingsbury
"Roy Smith" wrote in message
What's a little silly is that there's also an ILS-16 which gets you the
standard 200 & 1/2, so except as a contingency against the ILS being
OTS, having the LNAV/VNAV approach doesn't buy you anything.
There's significant labor involved in charting a new approach- obstacle
analysis, airspace planning, test-flying, etc. My guess is that where there
is an ILS already, creating an LNAV/VNAV approach is relatively low-cost
since you can piggyback on most of the existing labor.
Likewise, I suspect most of the new approaches we'll see over the next year
or two will be added to fields already equipped with an ILS. Lots of fields
here in the Northeast have an ILS but only on one runway end. I suspect in
five years or so every airport with air carrier traffic will have a
precision approach to every runway end. Somewhere along the way, we'll start
to see a trickle of these come to fields that currently have published
approaches but no ILS.
Another issue is that right now only airlines can really make use of this
stuff anyway, since relatively few people are flying behind v2 GNS-480s.
This is why Jane Garvey said in her AOPA speech that it's important for
pilots to go out and get new equipment that can make use of this. Of course,
I'd like to see her agency help by making it easier to certify and install
such equipment. There's no reason it should cost $15,000 to do so.
-cwk.
CNS-80 VNAV John R. Copeland Instrument Flight Rules 17 October 28th 04 04:24 AM
GPS/WAAS VNAV approaches and runway length Nathan Young Instrument Flight Rules 8 October 25th 04 06:16 PM
Closest SDF, LDA and LOC-BC Approaches Andrew Sarangan Instrument Flight Rules 17 June 5th 04 03:06 PM
Terminology of New WAAS, VNAV, LPV approach types Tarver Engineering Instrument Flight Rules 2 August 5th 03 03:50 AM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 01:43 PM
