Implications of.....keeping the speed up
Old January 6th 07, 07:26 PM posted to rec.aviation.ifr
Default Implications of.....keeping the speed up
On Sat, 06 Jan 2007 18:49:27 GMT, Jose
Could you explain? I'm talking ifr here, and imc. Using my example,
you're at 6000 feet msl over the appalachians. How is 2500 AGL easy
to eyeball?
I suppose under those circumstances, it would be challenging. However,
the 2500 foot rule only applies within four miles of a class C or D
airport. That would place you right in the traffic pattern, and it's
unlikely that ATC would route you through there
It might be unlikely, but it is still my responsibility to ensure this
speed restriction, not atc's. Am I misinformed?
Stan
Old January 6th 07, 08:15 PM posted to rec.aviation.ifr
Jose[_1_]
Regarding the 2500 foot rule, it's prefaced by something like "unless
authorized or required by ATC...". If ATC says to keep your speed up, I
would say that counts as an authorization to keep your speed up.
Jose
He who laughs, lasts.
Old January 8th 07, 12:35 AM posted to rec.aviation.ifr
Newps
Nope. ATC does not overide the FAR's. The pilot is always responsible
for not busting the speed limit.
Old January 8th 07, 01:32 AM posted to rec.aviation.ifr
Jose[_1_]
The FAR's what? (you probably meant plural, not posessive)
My statement doesn't require ATC to "override" the FARs. Rather, ATC's
authority to grant permission to fly at higher speed (in the case in
question) is explicitly written =into= the FARs. At least the way I
read them. I'm looking at 91.117(b), and the words "by ATC".
Jose
Old January 8th 07, 02:04 AM posted to rec.aviation.ifr
Sam Spade
Jose
You are correct. "Unless authorize by ATC" is authority from the
Administrator for ATC to supercede whatever the relevant FAR says.
When it says "Unless otherwise authorized by the Adminstrator" then ATC
is out of the picture.
Propeller thrust question xerj Piloting 11 November 25th 05 03:12 AM
Crosswind Landings... But airspeed? Jmarc99 Soaring 21 October 4th 05 07:54 PM
speed record set by scramjet - fair? Don French Piloting 55 November 28th 04 01:57 PM
Overweight takeoff / flight Koopas Ly Piloting 50 December 3rd 03 11:53 PM
