New_CFI writes:
hehehe....are you trying to avoid a building? small controll movements are key to a smooth flight. No, but if I put in a lot of trim to stay level, and then I need more control movement for an emergency, I might not have it. The trim can create the false impression that there is full movement in both directions. Neutral trim in cruse is not neccisarly good. read about it. I've read about advantages and disadvantages, but there doesn't seem to be any great danger in neutral trim. again, how much elevator do you need? I don't know ... so I like to have as much as possible in both directions. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
No, but if I put in a lot of trim to stay level, and then I need more control movement for an emergency, I might not have it. For real airplanes, FAR Parts 23 and 25 contain detailed requirements to provide for "emergency" maneuvers at all trim settings. If you have a problem here, it's solely MSFS. The idea that you would be concerned about such an emergency in a flight sim is really weird. Does MSFS really consume your life like this? Jeesh. F-- |
New_CFI wrote:
ok, then drive. or if your just intrested in seeing the world from above, fly a balloon. Save yourself the headache. He has no interest in seeing the world in any way other than in simulation. |
![]() "Mxsmanic" wrote in message news ![]() Thomas Borchert writes: Why would "neutral trim" be important? It allows for maximum control movement in both directions. It Does??? well... that is news to me Changing the trim setting does not change the set screws (Stop bolts) that limit the amount of Rudder, Aileron or Elevator travel. BT |
BT writes:
Changing the trim setting does not change the set screws (Stop bolts) that limit the amount of Rudder, Aileron or Elevator travel. But it does control how far you are from each stop. If you trim to pitch the aircraft upwards, for example, in order to eliminate the pesky need to hold the yoke way back, you may only be a short distance from the limit of your elevator travel. If you then become complacent and forget how much you've trimmed, and you suddenly need more elevator travel, you're out of luck. With a more neutral trim, you have plenty of travel in both directions if you need it. You can adjust your throttle so that you can remain level with zero trim. Or you can adjust your trim so that you remain level, pitching upwards as necessary. In the first case, you have plenty of safety margin on both sides; in the second case, you have very little margin to pitch up further, and if you suddenly need to climb and cannot, bad things can happen. This is why I prefer to stay near neutral trim. If I'm not in a rush, for example, I'll maintain altitude by adjusting the throttle until I can trim to zero. That way I have full elevator travel in both directions if I need it. And since this usually results in a lower throttle setting and slower speed as long as I'm not close to my ceiling, I have a good margin for thrust and speed as well. I will make an exception sometimes and trim down for high speeds, since that isn't as risky as the inverse. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
But it does control how far you are from each stop. In all horizontal tailplane designs? Guess again. F-- |
TxSrv writes:
In all horizontal tailplane designs? No, not in all designs. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
TxSrv writes: In all horizontal tailplane designs? No, not in all designs. Then you definitive statement about "how far you are from each stop" was flat wrong. Good we cleared that up. F-- |
![]() "TxSrv" wrote in message ... Mxsmanic wrote: TxSrv writes: In all horizontal tailplane designs? No, not in all designs. Then you definitive statement about "how far you are from each stop" was flat wrong. Good we cleared that up. F-- TxSrv.... now you see why no one pays attention to Mx |
Differences between automotive & airplane engines | Chris Wells | Home Built | 105 | February 18th 06 11:00 PM |
Pocket PC Weight and Balance Spreadsheet | Navzilla Support | Piloting | 0 | October 9th 05 11:47 PM |
Cessna 172 F Weight and Balance | [email protected] | Owning | 8 | September 22nd 05 02:38 AM |
172S Weight and Balance Question | David J | Piloting | 9 | March 23rd 04 01:08 AM |
Weight and balance.. | Bart | Rotorcraft | 9 | August 19th 03 02:57 AM |
