![]() "Richard Riley" wrote in message ... On Sat, 06 Jan 2007 07:11:27 GMT, Alan Baker wrote: In article , "Peter Dohm" wrote: There's a picture in the gallery of a static test of the wings where it claims that 500kg on each wing is equal to 2.5g. That implies a weight of 400kg, which seems pretty crazy even as an *empty* weight. -- Why? (400 Kg is about 860 Lbs) OK. Give me a few examples... 860 lbs isn't outragous as an empty weight. Off the top of my head, the Ercoup is 815, the Aeronca 7ac is 710, the Cessna 120 about 780 lbs. But 860 gross weight does seem ambitious. They list useful load as 530 lbs, so an empty weight of 330 lbs? The engine alone is 132. So the airframe, control systems, panel, upholstery, canopy, retractable gear, fuel tanks etc is under 200 lbs? That seems unlikely. And 2.5 G's seems like an awfully low number to test to. If their gross weight is real it means their stall speed could be, too - at 50 square feet it's only a CLmax of 1.8. Empty weight of my BD-5J is 358.8 lbs. I set gross weight at 850 lbs. Full tanks and me in it plus parachute, helmet, misc. puts it at about 814 lbs. -- Posted via a free Usenet account from http://www.teranews.com |
Juan Jimenez wrote:
"Richard Riley" wrote in message ... On Sat, 06 Jan 2007 07:11:27 GMT, Alan Baker wrote: In article , "Peter Dohm" wrote: There's a picture in the gallery of a static test of the wings where it claims that 500kg on each wing is equal to 2.5g. That implies a weight of 400kg, which seems pretty crazy even as an *empty* weight. -- Why? (400 Kg is about 860 Lbs) OK. Give me a few examples... 860 lbs isn't outragous as an empty weight. Off the top of my head, the Ercoup is 815, the Aeronca 7ac is 710, the Cessna 120 about 780 lbs. But 860 gross weight does seem ambitious. They list useful load as 530 lbs, so an empty weight of 330 lbs? The engine alone is 132. So the airframe, control systems, panel, upholstery, canopy, retractable gear, fuel tanks etc is under 200 lbs? That seems unlikely. And 2.5 G's seems like an awfully low number to test to. If their gross weight is real it means their stall speed could be, too - at 50 square feet it's only a CLmax of 1.8. Empty weight of my BD-5J is 358.8 lbs. I set gross weight at 850 lbs. Full tanks and me in it plus parachute, helmet, misc. puts it at about 814 lbs. You are planning on losing 100 pounds? Judging from your video I peg you at about 250 pounds. Dan, U.S. Air Force, retired? |
Double that if you count is ego!
Dan wrote: Juan Jimenez wrote: "Richard Riley" wrote in message ... On Sat, 06 Jan 2007 07:11:27 GMT, Alan Baker wrote: In article , "Peter Dohm" wrote: There's a picture in the gallery of a static test of the wings where it claims that 500kg on each wing is equal to 2.5g. That implies a weight of 400kg, which seems pretty crazy even as an *empty* weight. -- Why? (400 Kg is about 860 Lbs) OK. Give me a few examples... 860 lbs isn't outragous as an empty weight. Off the top of my head, the Ercoup is 815, the Aeronca 7ac is 710, the Cessna 120 about 780 lbs. But 860 gross weight does seem ambitious. They list useful load as 530 lbs, so an empty weight of 330 lbs? The engine alone is 132. So the airframe, control systems, panel, upholstery, canopy, retractable gear, fuel tanks etc is under 200 lbs? That seems unlikely. And 2.5 G's seems like an awfully low number to test to. If their gross weight is real it means their stall speed could be, too - at 50 square feet it's only a CLmax of 1.8. Empty weight of my BD-5J is 358.8 lbs. I set gross weight at 850 lbs. Full tanks and me in it plus parachute, helmet, misc. puts it at about 814 lbs. You are planning on losing 100 pounds? Judging from your video I peg you at about 250 pounds. Dan, U.S. Air Force, retired? |
![]() "Dan" wrote in message ... You are planning on losing 100 pounds? Judging from your video I peg you at about 250 pounds. I weigh 225. I'll be happy to donate a calculator to the DannyBoy Brain Fund. ![]() -- Posted via a free Usenet account from http://www.teranews.com |
On Sun, 7 Jan 2007 14:43:40 -0400, "Juan Jimenez"
wrote: Empty weight of my BD-5J is 358.8 lbs. I set gross weight at 850 lbs. Full tanks and me in it plus parachute, helmet, misc. puts it at about 814 lbs. I can't resist... If you're the "pilot", then it doesn't need the fuel or the parachute. I assume you'll still want the helmet for appearance sake. So - plane 360, you and a lightweight helmet another 300. That's only 660, leaving 190 for a honkin' big boombox strapped on with duct tape. The Ride of the Valkyrie at maximum volume should be just the thing to mask the sound of the squeaky cherry-picker wheels when the um, mission, is over. Wayne |
![]() "wmbjk" wrote in message ... On Sun, 7 Jan 2007 14:43:40 -0400, "Juan Jimenez" wrote: Empty weight of my BD-5J is 358.8 lbs. I set gross weight at 850 lbs. Full tanks and me in it plus parachute, helmet, misc. puts it at about 814 lbs. I can't resist... If you're the "pilot", then it doesn't need the fuel or the parachute. Stick to gliders then. ![]() -- Posted via a free Usenet account from http://www.teranews.com |
