Determination of bank angle from speed and heading change per time period
Old January 10th 07, 10:11 PM posted to rec.aviation.piloting
Blueskies
Default Determination of bank angle from speed and heading change per time period
"Grumman-581" wrote in message
news : On Tue, 09 Jan 2007 13:17:32 +0000, in
: 28, Bob Moore wrote:
: I think that you are going to have to work with TAS instead of GS, but
: Figure 2.29 on page 179 of Aerodynamics for Naval Aviators has a graph
: of all the factors involved.
: Yeah, to be perfectly accurate, I would need air speed and not ground
: speed in addition to wind angle corrections, but I was curious if I could
: get a good approximation of the bank angle from just what I'm getting from
: the GPS without having to add a considerably costlier device like an
: accelerometer / gyro with rs232 outputs... The Garmin 18 5Hz puck type GPS
: goes for around $150... A bit more than the 1Hz units that are typical for
: car navigation, but not entirely out of line for this project... The
: accelerometer / gyro systems that I've seen so far with rs232 outputs go
: for around $1K-$2K... I understand that there is some new work in
: accelerometers for PC-based pointing devices that have brought the prices
: down considerably compared to the previous devices like this:
: http://www.watson-gyro.com/products/...A_80_spec.html
Don't know why wind angle would be important. Have to assume a coordinated turn also - a rudder turn would yaw like
crazy but not necessarily result in a bank angle....
Old January 11th 07, 05:30 PM posted to rec.aviation.piloting
Grumman-581[_1_]
On Thu, 11 Jan 2007 00:05:44 +1100, in ,
d&tm wrote:
Its close but is it close enough at greater angles.? what are you using
for the conversion of speed.? I used g =9.8 Pi as 3.14159 and v =
kts *1852/3600 m/s
For conversion of speed, I'm using 6076 ft per nm, 3.14159265358979 for
pi, 9.80665 m/s^2 or 32.17398421 ft/sec^2 for g...
Interestingly on g, I'ver seen sources that quite it as being defined as
9.80665 *exactly* and others that quote it at 32.1740486... Not sure about
the later figure though since it is not exactly correct at least from a
conversion standpoint of the 9.80665 figure using the value of 39.37
inches per meter that I remembered... A quick lookup on the net and I find
that my memory was not correct and the 39.37 was not an *exact* figure...
Plugging in 39.37007874015748 instead and the values agree... For some
reason, I had thought that the 39.37 had been defined as an *exact*
value... Of course this also means that my memory is faulty on the 2.54
cm/in value also...
With regards to higher velocities and decreased values of time for the 360
degree circle, even with a 1 second 360 degree circle and 500 kts, the
values match to more digits than I really need (i.e. 88.26219913 and
88.26219912 degrees respectively for SI and US measurement units)... Yeah,
I would like to have an exact match, but there's probably some conversion
factor that I'm not using enough significant digits with...
Old January 11th 07, 08:33 PM posted to rec.aviation.piloting
Danny Deger
news
d&tm wrote:
snip
cm/in value also...
My understanding is an inch is EXACTLY 2.54 cm.
Danny Deger
Old January 11th 07, 10:43 PM posted to rec.aviation.piloting
Default Determination of bank angle from speed and heading change per?time period
Whoever is selling you your floats, doubles, and long doubles must be
making a killing.
as 9.80665 *exactly* and others that quote it at 32.1740486...
http://en.wikipedia.org/wiki/Gravity_%28Earth%29 has the definition of
9.80665 m/(s^2). It does vary with where you are on the planet as well
as how far you are above it.
http://en.wikipedia.org/wiki/Acceler...due_to_gravity has a few more
details.
For some reason, I had thought that the 39.37 had been defined as an
*exact* value...
http://en.wikipedia.org/wiki/Inch#International_inch says that the yard
is defined as 0.9144 m. 0.9144 is exactly 36 * 2.54, so the correct
statement may be that an inch is exactly 2.54 cm. 36/0.9144 is
39.370079 according to the calculator; rounding off to 39.37 is a
whopping 0.0002% error.
Standard disclaimers about using Wikipedia as a reference apply.
360 degree circle, even with a 1 second 360 degree circle and 500 kts,
the values match to more digits than I really need (i.e. 88.26219913
and 88.26219912 degrees respectively for SI and US measurement units)...
Your protractor salesman must also be living quite well.
Matt Roberds
Old January 12th 07, 08:45 AM posted to rec.aviation.piloting
Grumman-581[_1_]
On Thu, 11 Jan 2007 14:33:45 -0600, in
Yeah, well I thought that a meter was defined as EXACTLY 39.37 inches
also, so I was leaving myself an out, just in case yet another previoiusly
held belief turned out to be wrong... According to
http://www.pmel.org/Handbook/HBConversion.htm, it appears that 2.54 is an
exact figure... Damn, that's a surprise...
Old January 12th 07, 08:51 AM posted to rec.aviation.piloting
Grumman-581[_1_]
On Thu, 11 Jan 2007 22:43:13 +0000, in ,
making a killing.
I get a discount on them at TWORD-Depot... grin
Better to have the accuracy and choose to not use it than to need it and
not have it... If performance becomes an issue, you can always decrease
the bytes allocated for your variables...
Old January 14th 07, 12:20 AM posted to rec.aviation.piloting
Don Byrer
On Tue, 09 Jan 2007 02:58:02 -0600, Grumman-581
Anyone know of a formula for determing the current bank angle, given the
current velocity and rate of change in heading over a particular period of
time? I was thinking of adding an artificial horizon to program that I'm
working on and figured that by taking the current velocity as reported by
the GPS and the change in heading as reported by the last two
course-over-ground measurements from the GPS, I should be able to
determine a close approximation of the actual bank angle... Of course,
this assumes that the current winds are ignored in addition to assuming a
coordinated turn... The current system that I am using only gets updates
at 1 Hz which might be a bit low, but I'm thinking of getting the Garmin
18 5 Hz unit which should be sufficiently fast in its update rate...
Sounds like a great project...
Provide a great deal of valuable "darn-near-real-time" info to a
pilot...and at a cost that wont break the bank.
Makes sense...therefore...
(do I even NEED to finish the comment?)
MORE POWER TO YA!
Let us know how it works out.
--Don Byrer
Don Byrer KJ5KB
Radar Tech & Smilin' Commercial Pilot Guy
Glider & CFI wannabe
kj5kb-at-hotmail.com
"I have slipped the surly bonds of earth; now if I can just land without bending the gear..."
"Watch out for those doves...smack-smack-smack-smack..."
