Richard Riley wrote:
I've been working with a conventionally configured helicopter for a few months and this suddenly started eating my brain. In a 2 rotor helicopter you are countering the torque of one rotor with the other rotor. But how do you do a pedal turn? In a coaxial I'd think you'd increase the pitch of once set of blades and decrease the other. But what do you do in a tandem, like a CH-46? Increase the pitch, you get more torque, but you also get more lift, so the aircraft would move forward or backward - Any helo pilots out there that can set me straight? I have no clue if I am right but I always thought that stepping on the pedals would be similar to a situation where you had a stick for each rotor and moved them in equal and opposite directions. How that is done mechanically I don't even want to think about. -- Chris W KE5GIX "Protect your digital freedom and privacy, eliminate DRM, learn more at http://www.defectivebydesign.org/what_is_drm" Gift Giving Made Easy Get the gifts you want & give the gifts they want One stop wish list for any gift, from anywhere, for any occasion! http://thewishzone.com |
![]() "Chris W" wrote I have no clue if I am right but I always thought that stepping on the pedals would be similar to a situation where you had a stick for each rotor and moved them in equal and opposite directions. How that is done mechanically I don't even want to think about. I don't think so. Banking a chopper with a stick tilts the mast because of the offset of thrust on the one side. That causes the turn. To do so in opposite directions with a tandem rotor would only try to twist the fuselage, and not end up with any bank to cause a turn, assuming the you don't twist the fuselage in two. g -- Jim in NC |
![]() Morgans wrote: "Chris W" wrote I have no clue if I am right but I always thought that stepping on the pedals would be similar to a situation where you had a stick for each rotor and moved them in equal and opposite directions. How that is done mechanically I don't even want to think about. I don't think so. Banking a chopper with a stick tilts the mast because of the offset of thrust on the one side. That causes the turn. To do so in opposite directions with a tandem rotor would only try to twist the fuselage, and not end up with any bank to cause a turn, assuming the you don't twist the fuselage in two. g It also causes the vehicle to yaw into the turn. I still remember my instructor yelling at me to press the outside peddle (quiet odd for a fixed wing pilot to do in a turn). -robert |
![]() "Robert M. Gary" wrote It also causes the vehicle to yaw into the turn. I still remember my instructor yelling at me to press the outside peddle (quiet odd for a fixed wing pilot to do in a turn). I thought we were talking about tandem rotor choppers, and how they managed to do things like rotate (change direction they are pointed) in a hover. No? -- Jim in NC |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
