Why does the shuttle throttle on ascent?
Old January 13th 07, 09:29 PM posted to rec.aviation.piloting,sci.space.history,sci.space.shuttle
Mary Pegg
Default Why does the shuttle throttle on ascent?
Pat Flannery wrote:
http://www.abo.fi/~mlindroo/SpaceLVs/Slides/sld053.htm
A 747 with an SSME in the tail...
[Note to r.a.p. - that's a Space Shuttle Main Engine]
Old January 14th 07, 12:11 AM posted to rec.aviation.piloting,sci.space.history,sci.space.shuttle
Pat Flannery
The _New_ Boeing SST proposal! ;-)
It makes sense though... since you're storing LOX and LH2 on the 747
anyway for pumping into the ET at altitude, you might get some use out
of them to up its maximum release altitude at the same time.
Pat
Old January 14th 07, 06:31 AM posted to rec.aviation.piloting,sci.space.history,sci.space.shuttle
Henry Spencer
...It makes sense though... since you're storing LOX and LH2 on the 747
If memory serves, Boeing eventually concluded that this wasn't a good way
to do it -- too much structural strengthening needed? They looked instead
at injecting fuel into the bypass ducts of the turbofans (!), and
concluded that they could get a very large thrust increase that way, and
that it wouldn't hurt the engines if you kept the duration short.
spsystems.net is temporarily off the air; | Henry Spencer
mail to henry at zoo.utoronto.ca instead. |
Old January 14th 07, 11:07 PM posted to rec.aviation.piloting,sci.space.history,sci.space.shuttle
Pat Flannery
Somewhat similar to the way NASA looked into upping their SR-71's
performance via H2O2 injection into the afterburners.
But in that case the improvement in performance was pretty marginal.
Borrowing a page from the D-21/M-12 program, I wonder if you could use
the mini-shuttle's engines for the final climb, while constantly topping
the ET up from the internal tankage till release.
Pat
How to get maximum height on a winch launch? Dan G Soaring 38 December 22nd 16 12:29 AM
NASA: "The Shuttle Was a Mistake" AES Piloting 39 October 10th 05 01:10 PM
Is possible to pair a Saitek X35 throttle and a MS Sidewinder Pro? Riccardo Simulators 3 December 24th 03 06:07 PM
Boeing: Space shuttles to last into next decade JohnMcGrew Piloting 17 October 24th 03 09:31 PM
Cause of Columbia Shuttle Disaster. Mike Spera Owning 2 August 31st 03 03:11 PM
