"Peter R." writes:
Christopher Brian Colohan wrote: first, it means that the planes will fly through the freezing levels quickly (and up higher where it is too cold for ice accumulation), so they don't pick up much ice. Thanks, Chris. Regarding the above, that may be true for departing aircraft, but what about aircraft on approach to a busy airport? It is certainly probable that these aircraft may be vectored around at lower altitudes for many minutes at slower speeds. I would imagine that if this occurs in heavy freezing rain this could be a real problem, no? (speaking from a complete lack of experience...) I also imagine that this could be a problem, and I would guess that the solution is "don't do that". If a plane is picking up ice, the solution is to leave the icing conditions -- either climb or descend. I'm sure ATC would allow a plane to do this if a request was made. Chris |
On the ground, freezing rain does to an airplane just what
it does to your car. The entire airplane is clobbered. Doors won't open or close properly. Flaps, ailerons and spoilers may be frozen in position. Before take-off, airlines spray boiling hot water on the airplane (180° or so) to remove the snow and ice, then they switch to a heated mixture of water and anti-freeze to keep any ice from accumulating on the airplane during the time it takes to taxi and take-off. As rain/snow fall on the plane and melt, the antifreeze solution become diluted and the water will begin to freeze in hinges and such. The FAA parts 121 and 135 do not allow take-off in certain extreme icing conditions, but pilots have the authority to NOT GO even when the regulation might allow. In-flight, the aircraft anti-and de-icing systems will handle typical icing encounters, but severe icing is defined as ice that build TOO FAST for even the equipment to handle. see http://ecfr.gpoaccess.gov/cgi/t/text...1.21&idno= 14 and http://ecfr.gpoaccess.gov/cgi/t/text...1.14&idno=1 4 "Christopher Brian Colohan" wrote in message .. . | "Peter R." writes: | Christopher Brian Colohan wrote: | | first, it means that the planes | will fly through the freezing levels quickly (and up higher where it | is too cold for ice accumulation), so they don't pick up much ice. | | Thanks, Chris. Regarding the above, that may be true for departing | aircraft, but what about aircraft on approach to a busy airport? It is | certainly probable that these aircraft may be vectored around at lower | altitudes for many minutes at slower speeds. I would imagine that if this | occurs in heavy freezing rain this could be a real problem, no? | | (speaking from a complete lack of experience...) I also imagine that | this could be a problem, and I would guess that the solution is "don't | do that". If a plane is picking up ice, the solution is to leave the | icing conditions -- either climb or descend. I'm sure ATC would allow | a plane to do this if a request was made. | | Chris |
![]() Jim Macklin wrote: brevity snip Before take-off, airlines spray boiling hot water on the airplane (180° or so) to remove the snow and ice, then they switch to a heated mixture of water and anti-freeze to keep any ice from accumulating on the airplane during the time it takes to taxi and take-off. As rain/snow fall on the plane and melt, the antifreeze solution become diluted and the water will begin to freeze in hinges and such. Light frost on the aircraft prompted our pilot in SLC to de-ice. One plane ahead of us: total delay ~45 minutes. http://i16.tinypic.com/4gr9p8n.jpg http://i10.tinypic.com/2rcu9sh.jpg ----- - gpsman |
SLC and frost, who would have thunk it?
Frost can be polished smooth, but a gallon or two of alcohol spray does a good job on light aircraft as long as there is no precip falling and the sun is out. Airports stock alcohol for windshield and prop deicing on aircraft. Don't use the stuff they sell at the auto stores for car windshields, it will probably damage the plastic windows on your plane. The best cure,aside from a trip to Florida, is a heated hanger. Roll the plane in under the IR heaters, and pre-flight while the frost disappears. Cold weather pre-flights are often rushed and incomplete because of the cold. If you have to do it outside in -20 wind-chill, dress properly, hypothermia can make the take-off dangerous since your mind won't be work at 100%. "gpsman" wrote in message oups.com... Jim Macklin wrote: brevity snip Before take-off, airlines spray boiling hot water on the airplane (180° or so) to remove the snow and ice, then they switch to a heated mixture of water and anti-freeze to keep any ice from accumulating on the airplane during the time it takes to taxi and take-off. As rain/snow fall on the plane and melt, the antifreeze solution become diluted and the water will begin to freeze in hinges and such. Light frost on the aircraft prompted our pilot in SLC to de-ice. One plane ahead of us: total delay ~45 minutes. http://i16.tinypic.com/4gr9p8n.jpg http://i10.tinypic.com/2rcu9sh.jpg ----- - gpsman |
![]() Jim Macklin wrote: The FAA parts 121 and 135 do not allow take-off in certain extreme icing conditions, but pilots have the authority to NOT GO even when the regulation might allow. The Canadian MOT doesn't allow takeoff with any ice. Some, however, have forgotten that: http://aviation-safety.net/database/...0117-0&lang=en |
FAA requires ice removal for all take-offs, but depending on
what the weather conditions are, take-off may or may not be allowed. Light snow, drizzle can be controlled by application of anti-icing fluids after de-icing. But heavy rain, whether freezing or not will wash the anti-icing fluids away and allow to form. "cavedweller" wrote in message oups.com... | | Jim Macklin wrote: | | The FAA parts 121 and 135 do not allow take-off in certain | extreme icing conditions, but pilots have the authority to | NOT GO even when the regulation might allow. | | The Canadian MOT doesn't allow takeoff with any ice. Some, however, | have forgotten that: | | http://aviation-safety.net/database/...0117-0&lang=en | |
![]() Jim Macklin wrote: FAA requires ice removal for all take-offs, The Pelee accident came to mind because of the similarity with recent weather in the Detroit/Windsor area with the condtions at the time of that accident in 2004 and the almost matching dates. |
Strategy for icing due to freezing rain | Ron Rosenfeld | Instrument Flight Rules | 0 | March 5th 06 02:33 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Rain, rain, go away... | PJ Hunt | Rotorcraft | 3 | October 30th 04 07:51 AM |
