A point that needs to be made is that the FAA and DoD ATC systems are
not completely independent and parallel systems; they're thoroughly intertwined. For instance, Ellsworth Approach/Departure handles civilian traffic into and out of Rapid City Regional; Wichita Approach/Departure handles McConnell AFB traffic; military controllers at Sheppard AFB handle traffic for the civilian side of the field (Wichita Falls Muni) in the air and on the ground. Military sorties are under FAA control except under two circumstances: 1. When being handled by a military ATC facility. The handoffs to/from FAA controllers are done in accordance with procedures established in part at the national level and in part by local FAA/DoD working groups. Handling of civilian traffic by military controllers is worked out the same way. 2. When operating in a Military Operations Area (MOA) or a low-level training route. The sortie is directed to the MOA or the entry point of the route by the FAA, then it's on its own (unless there's a military ATC facility controlling the MOA, e.g. Nellis Range Control) under a policy known as MARSA (Military Assumes Responsibility for Separation of Aircraft). The FAA tries to keep civilian traffic out of the way, but is not responsible for mishaps unless the FAA controllers were negligent. When the sortie has flown the route or is ready to leave the MOA it contacts Center, declares itself "no longer MARSA" and is again under FAA control. Emergencies are handled the same way as in civilian aviation, although a military crew may have to justify their irregular actions to two sets of authorities afterward. DoD flight safety regulations are heavily based on FAA requirements and even preferences; the military comes down hard on unnecessary violations of FARs. However, I don't know of a case in which a military pilot who also held an FAA license was punished by both the DoD and FAA for an action in a military aircraft. |
In article . com,
"quietguy" wrote: A point that needs to be made is that the FAA and DoD ATC systems are not completely independent and parallel systems; they're thoroughly intertwined. in fact, the new STARS is a joint DOD/FAA program with the FAA as lead and the DOD follower, and the companion ASR-11 (aka DASR) has the DOD as lead with the FAA follower. In other words, in the NAS, the FAA and DOD will be using the same systems for TRACONs and terminal radars (for the most part). -- Bob Noel Looking for a sig the lawyers will hate |
