![]() "Jim Macklin" wrote in message ... FAR 135 requires that gross weight be adjusted so the SE SC is at or higher than the MEA or the aircraft must be flown under the single-engine IFR rules with VFR descent always possible. So adjusting gross weight when and engine fails means throwing the least liked passenger out the nearest exit and so-on untill gross weight for single engine operation is reached!! |
"GDBholdings" wrote:
So adjusting gross weight when and engine fails means throwing the least liked passenger out the nearest exit and so-on untill gross weight for single engine operation is reached!! Well, thank goodness that being the pilot I am a required crew member. :-) -- Mike Flyin'8 PP-ASEL Temecula, CA http://flying.4alexanders.com |
liked passenger out the nearest exit and so-on untill gross weight for single engine operation is reached!! So now watching "Survivor" on TV counts as pilot training? Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
It means pre-flight planning for the route and adjusting
payload or fuel so that the MEA can be maintained on one engine. "GDBholdings" wrote in message news:4U9rh.677783$R63.473026@pd7urf1no... | | "Jim Macklin" wrote in message | ... | FAR 135 requires that gross weight be adjusted so the SE SC | is at or higher than the MEA or the aircraft must be flown | under the single-engine IFR rules with VFR descent always | possible. | | So adjusting gross weight when and engine fails means throwing the least | liked passenger out the nearest exit and so-on untill gross weight for | single engine operation is reached!! | | |
![]() "Jim" wrote in message ... That's the correct phraseology. Loose an engine and you'll descend to the single engine service ceiling (density altitude). The Aztec is 6000 ft. Plenty of MEA's out west that are higher than that. I seem to remember that when the prototype twin Diamond came out, the SESC was something ridiculously low, like 1800 feet. You couldn't make it over a tree at that altitude, even in the East! They improved that, a great bit, for the current model! g -- Jim in NC |
Long time ago, the Champion Lancer had a single-engine best
rate of climb of 100 feet per minute down. Fixed gear, fixed pitch props, a Citabria with a nose-wheel. But it did have a Vmc and you could get a multiengine rating cheap. "Morgans" wrote in message ... | | "Jim" wrote in message | ... | That's the correct phraseology. Loose an engine and you'll descend to the | single engine service ceiling (density altitude). The Aztec is 6000 ft. | Plenty of MEA's out west that are higher than that. | | I seem to remember that when the prototype twin Diamond came out, the SESC | was something ridiculously low, like 1800 feet. You couldn't make it over a | tree at that altitude, even in the East! | | They improved that, a great bit, for the current model! g | -- | Jim in NC | | |
Jim Macklin wrote
Long time ago, the Champion Lancer had a single-engine best rate of climb of 100 feet per minute down. Fixed gear, fixed pitch props, a Citabria with a nose-wheel. But it did have a Vmc and you could get a multiengine rating cheap. Not quite, the Lancer was produced between '61-'63, the Citabria did not appear until 1964. More like a Tri-Champ with two engines. Bob Moore |
![]() Morgans wrote: What was the approximate single engine service ceiling? (if that is the right way to say it for multis) I don't remember exactly, but something like 5000 ft. for the Geronimo comes to mind. I have a copy of a copy of the POH, so the altitude performance chart is unreadable. I aways figured I could fly on one engine in low elevation areas, but in the mountainous west, particularly on a non-standard day, forget it. |
RomeoMike wrote:
I don't remember exactly, but something like 5000 ft. for the Geronimo comes to mind. I have a copy of a copy of the POH, so the altitude performance chart is unreadable. I aways figured I could fly on one engine in low elevation areas, but in the mountainous west, particularly on a non-standard day, forget it. I can't remember either, mainly because I never had to worry about it. As a flatland pilot, I was more concerned with the PITA hand pumping of the gear and the flaps if I lost the critical engine (which I think was the right one... it's been 16 years since I flew one). Pretty much any altitude at all would be enough to stay clear of obstacles on the routes I flew. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
![]() Mortimer Schnerd, RN wrote: I can't remember either, mainly because I never had to worry about it. As a flatland pilot, I was more concerned with the PITA hand pumping of the gear and the flaps if I lost the critical engine (which I think was the right one... it's been 16 years since I flew one). Pretty much any altitude at all would be enough to stay clear of obstacles on the routes I flew. Oh yes, I forgot about the hand pumping. The critical engine is the left one, and also the pump supplying hydraulic pressure for the gear and flaps was driven by the left engine. Fortunately, I didn't have to deal with that in the real engine out. The more I think about it the more I think that 5000 feet is too optimistic for the single engine service ceiling in the Geronimo. Anybody know what it is for the unmodified Apache? |
Commercial 250nm VFR flight - all 3 landings on the same day? | Jim Macklin | Piloting | 39 | December 20th 06 12:11 PM |
Aw Rating merger and Today's ASW | Charlie Wolf | Naval Aviation | 5 | May 12th 05 10:34 PM |
Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 02:16 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Enlisted pilots | John Randolph | Naval Aviation | 41 | July 21st 03 02:11 PM |
