On Mon, 15 Jan 2007 08:59:57 -0500, Bob Noel
wrote in : Maybe not, since we were (are) on the east coast, and you didn't make the connection between Noel and Noel's Piano Supply. I was only an amateur who restored a couple of pianos, so I wasn't so intimately involved in the business. But I'll bet Dick would recognize the name. You ironed the cloth off? ugh. Lightly burn it and it comes off easily. Sure, there are bellows that can't be easily burned, but ironing-off the old cloth is sooooo slow. It wasn't too slow if the iron was hot. The glue readily re-melted, and the old pneumatic cloth slid right off. Didn't burning the cloth cause a lot of noxious fumes and char scaring of the wood? You didn't use a torch to remove the pneumatic bellows from the stack did you; you used an iron right? Today, of course, the popularity of mechanical pianos is in rapid decline in favor of smaller, less expensive electronic keyboards, but I still thrill at the sounds of a real grand piano lilting through the house even if it is being played by a PianoDisc system: http://www.pianodisc.com/ |
Larry Dighera wrote: Maybe not, since we were (are) on the east coast, and you didn't make the connection between Noel and Noel's Piano Supply. I was only an amateur who restored a couple of pianos, so I wasn't so intimately involved in the business. But I'll bet Dick would recognize the name. Later today I'll try to remember to ask my father if he remembers the name You ironed the cloth off? ugh. Lightly burn it and it comes off easily. Sure, there are bellows that can't be easily burned, but ironing-off the old cloth is sooooo slow. It wasn't too slow if the iron was hot. The glue readily re-melted, and the old pneumatic cloth slid right off. Way quicker to put 10 or so into a C-clamp, lightly burn it, open the clamp, use a floor-standing 6" belt-sander to clean off the pneumatics (in groups of 3), being very careful of the hinged end. Didn't burning the cloth cause a lot of noxious fumes and char scaring of the wood? fumes, yes. Noxious? I hope not. :-) if you burned the wood, you burned it too much. Use a propane torch to just get the cloth/glue to char/bubble just a little. You didn't use a torch to remove the pneumatic bellows from the stack did you; you used an iron right? For the pneumatics, the only time you need to use an iron is when chiseling doesn't work. We had (and still have) a slightly dull wood chisel that was perfect (if the chisel can cut pine, it's way too sharp). Start the pneumatic with a hit or two underneath along the entire row, a hit or two on the side and hinged end of each pneumatic, and they pop right off, usually. Sometimes the glue is so old/dried that you can knock them off with one hit if you did it just right - took practice. The beauty of chiseling was that often they wouldn't come off clean and smooth, which helped in positioning the pneumatic when we glued them back on. If we broke one, we simply made a new one. -- Bob Noel Looking for a sig the lawyers will hate |
On Mon, 15 Jan 2007 11:19:34 -0500, Bob Noel
wrote in : The beauty of chiseling was that often they wouldn't come off clean and smooth, which helped in positioning the pneumatic when we glued them back on. I was taught to drill shallow holes through the pneumatic into the stack, and put short pieces of steel rod (cut 3d nails worked) into the holes, so that they could be keyed back into their exact original position. Those were the days. I'm better for the experience, but I'm happy they are behind me. |
Larry Dighera wrote: The beauty of chiseling was that often they wouldn't come off clean and smooth, which helped in positioning the pneumatic when we glued them back on. I was taught to drill shallow holes through the pneumatic into the stack, and put short pieces of steel rod (cut 3d nails worked) into the holes, so that they could be keyed back into their exact original position. wow. ohmygawd, wow. That is so labor intensive. Obviously it works, but it's a bit more than necessary. If you use a pencil, you can draw a line across the hinged end. This shows how far back to have the pneumatic. For left/right, there is always some marking left on the stack which shows where the pneumatic was. And the pencil line has a little dip in-between the pneumatics as extra information. -- Bob Noel Looking for a sig the lawyers will hate |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
OT I have lost a dear friend | Dudley Henriques | Piloting | 17 | March 4th 06 05:44 AM |
LS-6A and B life extension | JS | Soaring | 0 | December 8th 05 10:56 PM |
LIfe with Shakespeare on the Chucky V | Allen | Naval Aviation | 10 | September 15th 05 02:11 AM |
I saved a life, maybe you can save mine. | lifeguard | Owning | 3 | July 18th 05 11:19 AM |
