Why does airspeed change when I adjust the prop?
Old January 16th 07, 02:41 PM posted to rec.aviation.piloting,rec.aviation.student
Jose
Default Why does airspeed change when I adjust the prop?
The implication is that you can go faster in cruise
with coarse pitch (just as you can go faster in overdrive in a car
when cruising), but it doesn't seem to work that way.
What happens when, in a car, you go from second gear to fifth gear?
Unless you are going fast enough for fifth gear to be appropriate, the
car will lug, and slow down. The point of car gearing is to keep the
engine at its most efficient RPM range. While this is an extreme case,
something similar happens with an airplane engine - if you lower the
RPM, the pitch will become coarser (all other things being equal) and
the engine will have a harder time (do more work) for each revolution.
Each revolution pulls you through more air.
Jose
He who laughs, lasts.
Old January 16th 07, 06:32 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Jose writes:
So ultimately why do you change the prop adjustment? At full power,
slowing the RPM just slows the aircraft down. So does reducing the
throttle. Why would I slow the RPM rather than reduce the throttle?
Old January 16th 07, 09:25 PM posted to rec.aviation.piloting,rec.aviation.student
Jose
For better efficiency.
Jose
Old January 16th 07, 10:48 PM posted to rec.aviation.piloting,rec.aviation.student
Danny Deger
"Mxsmanic" wrote in message
snip
A fixed prop optimized for takeoff would overspeed the engine at cruise
speed. With variable pitch, the prop can be flat for take and higher pitch
for cruise.
Danny Deger
Why does a prop ice up so apparently readily? Mike Rapoport Instrument Flight Rules 2 November 8th 05 02:52 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
