Wing walk ply question.
Old January 18th 07, 06:30 PM posted to rec.aviation.homebuilt
Mustardbuilder[_4_]
Default Wing walk ply question.
"Lou" wrote in news:1169120606.808676.277590
@l53g2000cwa.googlegroups.com:
Mine also calls for 1/4" but only from the front spar to
the back spar, since I have flaps. Laminating 2 peices should
be ok but I wouldn't us an 1/8" trowel. I would spred the glue
around with a popsicle stick or scrap wood, quite a few clamps,
and straps of wood to put on top. Clamp one end, then start
clamping every couple of inches until you reach the other end.
OK. Here's what I'm thinking now. I use a couple of 3/4 ply ribs as a
mold with holes drilled near the upper edge as a place to locate the
clamps. A few pieces of wood across the underside of the ply to keep it
from sagging and a few pieces clamped right on top of those to ensure a
good contact between the two glued surfaces. the width is only 12 inches
so I'm supposing the two pieces would have adequate surface contact
(i.e, no gaps) and I should end up with a molded walkway..
Good news for private pilots' spouses Skylune Piloting 30 July 7th 06 11:19 PM
Wing dihedral Dallas Piloting 35 March 20th 06 04:01 PM
The Impossibility of Flying Heavy Aircraft Without Training Immanuel Goldstein Piloting 365 March 16th 06 01:15 AM
The Impossibility of Flying Heavy Aircraft Without Training Immanuel Goldstein Home Built 331 March 10th 06 01:07 AM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 03:52 AM
