Wayne Paul wrote:
"cavelamb himself" wrote in message hlink.net... Wayne Paul wrote: Bob, Your HP-18 side-stick to center-stick is an example of good design. http://www.hpaircraft.com/center_sti...22_january.htm (Complete story http://www.hpaircraft.com/center_stick/) Other designs that may be of interest to the group are Udo Rumpf's use of a PIK-20 sailplane stick http://www.soaridaho.com/Schreder/Co...ter_Stick.html and Brian Case's HP-16 modification. Brian need to lower the seatpan in his HP16 to allow more head/canopy clearance. So he removed the old cable system which ran under the seat and designed the following modification: http://www.soaridaho.com/Schreder/Co..._Stick_Mod.htm (Brian by his HP-16T http://www.soaridaho.com/Schreder/HP...Mackay_IDa.JPG) Wayne HP-14 "6F" http://www.soaridaho.com/Schreder The second picture from the top tells the tale. I'd assume (?) that there is something like a U joint behind the cockpit to let the push rod line up with the elevator horn? I'll have to think about this some more. You guys just could be right! Richard, Here are some pictures from behind the cockpit that may help understanding Brian's control system.. http://www.soaridaho.com/Schreder/Co...ick_Mod_11.jpg The above picture was take looking forward. It shows the bulkhead aft of the wheelwell. You can see the series of bell cranks that actuate the ailerons and the push the stick's push rod as it is routed through the right side of the bulkhead. The elevator push rod and direction reversal crank can be seen on the left side of the bulkhead. (More pictures http://www.soaridaho.com/Schreder/Co...tick_Mod_9.jpg http://www.soaridaho.com/Schreder/Co...ick_Mod_10.jpg) As you can see, there are no "U-joints". The linkage has almost no "slop" and give good control surface feed-back. It should also be noted that the ailerons droop and reflex with the flaps avoiding misalignment during normal cruise and thermaling flap configurations. Wayne HP-14 "6F http://www.soaridaho.com/Schreder Richard Sorry. my bad. I was refering to the U-Joint in the Elevator pushrods. (and a word of warning about them...) http://www.soaridaho.com/Schreder/Co...ll.html#ujoint That lateral torque tube (actually a walking beam) in my sketch is in the elevator control system. It takes the pushrod from the lateral joystick torque tube and inverts it so the long tube to the elevator is in tension. Also centers up the aft push pull tube. The lower arm in the center is the attach horn for a MAC servo (elevator trim) coupled by a "U" shaped fiberglass spring. I didn't dream that one up - saw it on the net some years back - but I wish I had. Well, _I_ thought it was a pretty simple setup... Richard |
![]() "cavelamb himself" wrote in message link.net... Richard, Here are some pictures from behind the cockpit that may help understanding Brian's control system.. http://www.soaridaho.com/Schreder/Co...ick_Mod_11.jpg The above picture was take looking forward. It shows the bulkhead aft of the wheelwell. You can see the series of bell cranks that actuate the ailerons and the push the stick's push rod as it is routed through the right side of the bulkhead. The elevator push rod and direction reversal crank can be seen on the left side of the bulkhead. (More pictures http://www.soaridaho.com/Schreder/Co...tick_Mod_9.jpg http://www.soaridaho.com/Schreder/Co...ick_Mod_10.jpg) As you can see, there are no "U-joints". The linkage has almost no "slop" and give good control surface feed-back. It should also be noted that the ailerons droop and reflex with the flaps avoiding misalignment during normal cruise and thermaling flap configurations. Wayne HP-14 "6F http://www.soaridaho.com/Schreder Richard Sorry. my bad. I was refering to the U-Joint in the Elevator pushrods. (and a word of warning about them...) http://www.soaridaho.com/Schreder/Co...ll.html#ujoint That lateral torque tube (actually a walking beam) in my sketch is in the elevator control system. It takes the pushrod from the lateral joystick torque tube and inverts it so the long tube to the elevator is in tension. Also centers up the aft push pull tube. The lower arm in the center is the attach horn for a MAC servo (elevator trim) coupled by a "U" shaped fiberglass spring. I didn't dream that one up - saw it on the net some years back - but I wish I had. Well, _I_ thought it was a pretty simple setup... http://www.soaridaho.com/Schreder/Sc...76_Page_28.JPG http://www.soaridaho.com/Schreder/Sc...76_Page_29.JPG |
![]() "cavelamb himself" wrote in message link.net... Wayne Paul wrote: "cavelamb himself" wrote in message hlink.net... Wayne Paul wrote: Bob, Your HP-18 side-stick to center-stick is an example of good design. http://www.hpaircraft.com/center_sti...22_january.htm (Complete story http://www.hpaircraft.com/center_stick/) Other designs that may be of interest to the group are Udo Rumpf's use of a PIK-20 sailplane stick http://www.soaridaho.com/Schreder/Co...ter_Stick.html and Brian Case's HP-16 modification. Brian need to lower the seatpan in his HP16 to allow more head/canopy clearance. So he removed the old cable system which ran under the seat and designed the following modification: http://www.soaridaho.com/Schreder/Co..._Stick_Mod.htm (Brian by his HP-16T http://www.soaridaho.com/Schreder/HP...Mackay_IDa.JPG) Wayne HP-14 "6F" http://www.soaridaho.com/Schreder The second picture from the top tells the tale. I'd assume (?) that there is something like a U joint behind the cockpit to let the push rod line up with the elevator horn? I'll have to think about this some more. You guys just could be right! Richard, Here are some pictures from behind the cockpit that may help understanding Brian's control system.. http://www.soaridaho.com/Schreder/Co...ick_Mod_11.jpg The above picture was take looking forward. It shows the bulkhead aft of the wheelwell. You can see the series of bell cranks that actuate the ailerons and the push the stick's push rod as it is routed through the right side of the bulkhead. The elevator push rod and direction reversal crank can be seen on the left side of the bulkhead. (More pictures http://www.soaridaho.com/Schreder/Co...tick_Mod_9.jpg http://www.soaridaho.com/Schreder/Co...ick_Mod_10.jpg) As you can see, there are no "U-joints". The linkage has almost no "slop" and give good control surface feed-back. It should also be noted that the ailerons droop and reflex with the flaps avoiding misalignment during normal cruise and thermaling flap configurations. Wayne HP-14 "6F http://www.soaridaho.com/Schreder Richard Sorry. my bad. I was refering to the U-Joint in the Elevator pushrods. (and a word of warning about them...) http://www.soaridaho.com/Schreder/Co...ll.html#ujoint That lateral torque tube (actually a walking beam) in my sketch is in the elevator control system. It takes the pushrod from the lateral joystick torque tube and inverts it so the long tube to the elevator is in tension. Also centers up the aft push pull tube. The lower arm in the center is the attach horn for a MAC servo (elevator trim) coupled by a "U" shaped fiberglass spring. I didn't dream that one up - saw it on the net some years back - but I wish I had. Well, _I_ thought it was a pretty simple setup... Richard, Oops, I didn't intend the send the last message. The "U" joints in the above referenced article are associated with Dick Schreder's original side stick design. They have been eliminated in both Bob's and Udo's modification. Here are some of the drawings that show the original design containing those pesky "U" joints. http://www.soaridaho.com/Schreder/Sc...76_Page_28.JPG http://www.soaridaho.com/Schreder/Sc...76_Page_29.JPG http://www.soaridaho.com/Schreder/Sc...76_Page_35.jpg http://www.soaridaho.com/Schreder/Sc...76_Page_36.jpg Soaring magazine's entire six month series on building the HP-18 can be found at http://www.soaridaho.com/Schreder/Sc...the_HP-18.html Wayne HP-14 "6F" http://www.soaridaho.com/Schreder |
Wayne Paul wrote:
Here are some of the drawings that show the original design containing those pesky "U" joints. http://www.soaridaho.com/Schreder/Sc...76_Page_28.JPG http://www.soaridaho.com/Schreder/Sc...76_Page_29.JPG http://www.soaridaho.com/Schreder/Sc...76_Page_35.jpg http://www.soaridaho.com/Schreder/Sc...76_Page_36.jpg Soaring magazine's entire six month series on building the HP-18 can be found at http://www.soaridaho.com/Schreder/Sc...the_HP-18.html Wayne HP-14 "6F" http://www.soaridaho.com/Schreder Lots of good jucy stuff there. Thanks for sharing the links, Wayne... Richard |
doodles damit... | Richard Lamb | Home Built | 8 | March 5th 06 08:17 AM |
Doodles... | Richard Lamb | Home Built | 39 | January 20th 06 08:34 PM |
