#21
On 01/17/07 08:35, Roy N5804F wrote:
Dave, I have signed up ! About the only instrument that I have not overhauled in this Archer is the VSI. It reads horribly optimistic, like, I have the only Archer ever built that climbs on the plains here at 1200 FPM. If I really try, I can make 1500 FPM :-) I have to admit that I don't know much about the operation of a VSI appertaining to an Archer :-( I can't get my head round it at the moment, but could the slight negative pressure in the cabin affect the VSI ? It shouldn't. The VSI should be vented (through a calibrated "leak") to the static air source, outside. The cabin pressure shouldn't affect it, unless you've selected the alternate static source, or there is a leak between the static source and alternate static source. -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
![]() "Mark Hansen" wrote in message ... On 01/17/07 08:35, Roy N5804F wrote: Dave, I have signed up ! About the only instrument that I have not overhauled in this Archer is the VSI. It reads horribly optimistic, like, I have the only Archer ever built that climbs on the plains here at 1200 FPM. If I really try, I can make 1500 FPM :-) I have to admit that I don't know much about the operation of a VSI appertaining to an Archer :-( I can't get my head round it at the moment, but could the slight negative pressure in the cabin affect the VSI ? It shouldn't. The VSI should be vented (through a calibrated "leak") to the static air source, outside. The cabin pressure shouldn't affect it, unless you've selected the alternate static source, or there is a leak between the static source and alternate static source. Thanks, I had all the hoses replaced last year, incluing all in the cockpit and out to the pitot tube. Maybe they are all ok. [I changed all the vacuum hoses as well] Roy |
On 01/17/07 08:54, Roy N5804F wrote:
"Mark Hansen" wrote in message ... On 01/17/07 08:35, Roy N5804F wrote: Dave, I have signed up ! About the only instrument that I have not overhauled in this Archer is the VSI. It reads horribly optimistic, like, I have the only Archer ever built that climbs on the plains here at 1200 FPM. If I really try, I can make 1500 FPM :-) I have to admit that I don't know much about the operation of a VSI appertaining to an Archer :-( I can't get my head round it at the moment, but could the slight negative pressure in the cabin affect the VSI ? It shouldn't. The VSI should be vented (through a calibrated "leak") to the static air source, outside. The cabin pressure shouldn't affect it, unless you've selected the alternate static source, or there is a leak between the static source and alternate static source. Thanks, I had all the hoses replaced last year, incluing all in the cockpit and out to the pitot tube. Maybe they are all ok. [I changed all the vacuum hoses as well] Well ... one way to tell would be to select the alternate static source while flying. Assuming your alternate static source is vented to the cabin, it should show a slight climb for a time before settling back to zero. If it shows no change when selecting the alternate static source, there may be something amiss there. -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
Ahhhhhhhhhhh..... Rats!
Sorry.. Open the Alt static, THEN see if closing the airvent affects the VSI.. If it momentarily swings positive, it could indicate a neg pressure in the cabin.. Just a thought... Sorry my first was not complete.. ![]() Dave On Wed, 17 Jan 2007 16:35:35 GMT, "Roy N5804F" wrote: Dave, I have signed up ! About the only instrument that I have not overhauled in this Archer is the VSI. It reads horribly optimistic, like, I have the only Archer ever built that climbs on the plains here at 1200 FPM. If I really try, I can make 1500 FPM :-) I have to admit that I don't know much about the operation of a VSI appertaining to an Archer :-( I can't get my head round it at the moment, but could the slight negative pressure in the cabin affect the VSI ? Roy "Dave" wrote in message .. . Hi Roy! I second this. That group has the most knowledgeable group on Cherokees bar none! Newbees to seasoned AME's, and they all LOVE their Cherokees! I think this discussion is closing in on UR prob, SOMETHING is greating a vacuum in your cabin, and the cold air is roaring in to replace the air being sucked out "somewhere" How does the VSI respond to quickly closing the vent? As to why the "left side vs right side"..scratching my bean on that part... Dave On Wed, 17 Jan 2007 00:02:20 GMT, "Roy N5804F" wrote: Thanks Jay, I shall head over and get joined up. Last year I was intending to go to the Fly-In but ran out of days to take off from work. Maybe this year, but intend to do Sun n Fun & OSH so we shall have to see what happens. Roy "Jay Honeck" wrote in message egroups.com... As far as I can tell their is no draft coming out of the fine mesh plank vent on the pilots side. That is so weird. Is there something blocking *that* opening? I just can't imagine what's causing that kind of strong air-flow. The Cherokee Chat is the Cherokee Pilot's Association on-line chat room. You've got to be a member, but it's worth every penny to join, and then some. See them he http://www.piperowner.com/ With over 4000 Cherokee owners in the organization, you can always count on getting an answer on ANY Cherokee question you might have. And they have the BEST fly-in of the year. See info on that he http://cherokeeflyin.com/ We've attended the last four, and intend to go again this year. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() :-) Thanks Dave, Roy "Dave" wrote in message ... Ahhhhhhhhhhh..... Rats! Sorry.. Open the Alt static, THEN see if closing the airvent affects the VSI.. If it momentarily swings positive, it could indicate a neg pressure in the cabin.. Just a thought... Sorry my first was not complete.. ![]() Dave On Wed, 17 Jan 2007 16:35:35 GMT, "Roy N5804F" wrote: Dave, I have signed up ! About the only instrument that I have not overhauled in this Archer is the VSI. It reads horribly optimistic, like, I have the only Archer ever built that climbs on the plains here at 1200 FPM. If I really try, I can make 1500 FPM :-) I have to admit that I don't know much about the operation of a VSI appertaining to an Archer :-( I can't get my head round it at the moment, but could the slight negative pressure in the cabin affect the VSI ? Roy "Dave" wrote in message . .. Hi Roy! I second this. That group has the most knowledgeable group on Cherokees bar none! Newbees to seasoned AME's, and they all LOVE their Cherokees! I think this discussion is closing in on UR prob, SOMETHING is greating a vacuum in your cabin, and the cold air is roaring in to replace the air being sucked out "somewhere" How does the VSI respond to quickly closing the vent? As to why the "left side vs right side"..scratching my bean on that part... Dave On Wed, 17 Jan 2007 00:02:20 GMT, "Roy N5804F" wrote: Thanks Jay, I shall head over and get joined up. Last year I was intending to go to the Fly-In but ran out of days to take off from work. Maybe this year, but intend to do Sun n Fun & OSH so we shall have to see what happens. Roy "Jay Honeck" wrote in message legroups.com... As far as I can tell their is no draft coming out of the fine mesh plank vent on the pilots side. That is so weird. Is there something blocking *that* opening? I just can't imagine what's causing that kind of strong air-flow. The Cherokee Chat is the Cherokee Pilot's Association on-line chat room. You've got to be a member, but it's worth every penny to join, and then some. See them he http://www.piperowner.com/ With over 4000 Cherokee owners in the organization, you can always count on getting an answer on ANY Cherokee question you might have. And they have the BEST fly-in of the year. See info on that he http://cherokeeflyin.com/ We've attended the last four, and intend to go again this year. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
NP Roy!
Will look 4 U on the Cherokee Chat! Don't be bashful! Dive in! Dave On Thu, 18 Jan 2007 01:15:01 GMT, "Roy N5804F" wrote: :-) Thanks Dave, Roy "Dave" wrote in message .. . Ahhhhhhhhhhh..... Rats! Sorry.. Open the Alt static, THEN see if closing the airvent affects the VSI.. If it momentarily swings positive, it could indicate a neg pressure in the cabin.. Just a thought... Sorry my first was not complete.. ![]() Dave On Wed, 17 Jan 2007 16:35:35 GMT, "Roy N5804F" wrote: Dave, I have signed up ! About the only instrument that I have not overhauled in this Archer is the VSI. It reads horribly optimistic, like, I have the only Archer ever built that climbs on the plains here at 1200 FPM. If I really try, I can make 1500 FPM :-) I have to admit that I don't know much about the operation of a VSI appertaining to an Archer :-( I can't get my head round it at the moment, but could the slight negative pressure in the cabin affect the VSI ? Roy "Dave" wrote in message ... Hi Roy! I second this. That group has the most knowledgeable group on Cherokees bar none! Newbees to seasoned AME's, and they all LOVE their Cherokees! I think this discussion is closing in on UR prob, SOMETHING is greating a vacuum in your cabin, and the cold air is roaring in to replace the air being sucked out "somewhere" How does the VSI respond to quickly closing the vent? As to why the "left side vs right side"..scratching my bean on that part... Dave On Wed, 17 Jan 2007 00:02:20 GMT, "Roy N5804F" wrote: Thanks Jay, I shall head over and get joined up. Last year I was intending to go to the Fly-In but ran out of days to take off from work. Maybe this year, but intend to do Sun n Fun & OSH so we shall have to see what happens. Roy "Jay Honeck" wrote in message glegroups.com... As far as I can tell their is no draft coming out of the fine mesh plank vent on the pilots side. That is so weird. Is there something blocking *that* opening? I just can't imagine what's causing that kind of strong air-flow. The Cherokee Chat is the Cherokee Pilot's Association on-line chat room. You've got to be a member, but it's worth every penny to join, and then some. See them he http://www.piperowner.com/ With over 4000 Cherokee owners in the organization, you can always count on getting an answer on ANY Cherokee question you might have. And they have the BEST fly-in of the year. See info on that he http://cherokeeflyin.com/ We've attended the last four, and intend to go again this year. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() Thanks Dave, Well I am in there monitoring the chat. -- Roy Piper Archer N5804F "Dave" wrote in message ... NP Roy! Will look 4 U on the Cherokee Chat! Don't be bashful! Dive in! Dave On Thu, 18 Jan 2007 01:15:01 GMT, "Roy N5804F" wrote: :-) Thanks Dave, Roy "Dave" wrote in message . .. Ahhhhhhhhhhh..... Rats! Sorry.. Open the Alt static, THEN see if closing the airvent affects the VSI.. If it momentarily swings positive, it could indicate a neg pressure in the cabin.. Just a thought... Sorry my first was not complete.. ![]() Dave On Wed, 17 Jan 2007 16:35:35 GMT, "Roy N5804F" wrote: Dave, I have signed up ! About the only instrument that I have not overhauled in this Archer is the VSI. It reads horribly optimistic, like, I have the only Archer ever built that climbs on the plains here at 1200 FPM. If I really try, I can make 1500 FPM :-) I have to admit that I don't know much about the operation of a VSI appertaining to an Archer :-( I can't get my head round it at the moment, but could the slight negative pressure in the cabin affect the VSI ? Roy "Dave" wrote in message m... Hi Roy! I second this. That group has the most knowledgeable group on Cherokees bar none! Newbees to seasoned AME's, and they all LOVE their Cherokees! I think this discussion is closing in on UR prob, SOMETHING is greating a vacuum in your cabin, and the cold air is roaring in to replace the air being sucked out "somewhere" How does the VSI respond to quickly closing the vent? As to why the "left side vs right side"..scratching my bean on that part... Dave On Wed, 17 Jan 2007 00:02:20 GMT, "Roy N5804F" wrote: Thanks Jay, I shall head over and get joined up. Last year I was intending to go to the Fly-In but ran out of days to take off from work. Maybe this year, but intend to do Sun n Fun & OSH so we shall have to see what happens. Roy "Jay Honeck" wrote in message oglegroups.com... As far as I can tell their is no draft coming out of the fine mesh plank vent on the pilots side. That is so weird. Is there something blocking *that* opening? I just can't imagine what's causing that kind of strong air-flow. The Cherokee Chat is the Cherokee Pilot's Association on-line chat room. You've got to be a member, but it's worth every penny to join, and then some. See them he http://www.piperowner.com/ With over 4000 Cherokee owners in the organization, you can always count on getting an answer on ANY Cherokee question you might have. And they have the BEST fly-in of the year. See info on that he http://cherokeeflyin.com/ We've attended the last four, and intend to go again this year. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
FS/FB : 1976 PA28-181 Piper Archer | [email protected] | Aviation Marketplace | 0 | December 1st 05 06:31 AM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
Any way to lower Piper Dakota seat height? | Bob Reynolds | Owning | 2 | October 10th 03 05:22 AM |
Piper Colt child seat STC | R. Wubben | Owning | 1 | September 22nd 03 05:11 PM |
The Piper Cubs That Weren't | Veeduber | Home Built | 5 | August 28th 03 04:38 AM |
