![]() "Maxwell" wrote If he is trying to hold .002" oversize, an oversized drill is going to be much less predictable, probably more difficult to find and a good bit more expensive. The key is the type of bit he is advocating dressing and using. A wood cutting Forsner style drill bit eliminates any possible springback, as it cuts only on a straight line from the center to the diameter, and pretty much level across the hole. It has no flutes to try to dress, and a small area to dress. It is the ideal bit to re-size. -- Jim in NC |
![]() "Morgans" wrote in message ... "Maxwell" wrote If he is trying to hold .002" oversize, an oversized drill is going to be much less predictable, probably more difficult to find and a good bit more expensive. The key is the type of bit he is advocating dressing and using. A wood cutting Forsner style drill bit eliminates any possible springback, as it cuts only on a straight line from the center to the diameter, and pretty much level across the hole. It has no flutes to try to dress, and a small area to dress. It is the ideal bit to re-size. -- Jim in NC He didn't say what type of drill bit, and forstner bits do not eliminate any possibility of spring back, try drilling rubber or felt. Also, how do you easily resize a forstner bit? Are you sure the others are not talking about spade drills? |
![]() Try KBC Tools. They're on the 'Net, and have a full line of decimal reamers, which will fit almost any application. That said, I would chuck the UHMW in a four-jaw chuck on the lathe and turn the hole using a really sharp HSS bit. Dan |
![]() wrote in message ps.com... Try KBC Tools. They're on the 'Net, and have a full line of decimal reamers, which will fit almost any application. That said, I would chuck the UHMW in a four-jaw chuck on the lathe and turn the hole using a really sharp HSS bit. Dan No, ya got lost somewhere Dan. The question at this point is how do you resize a forstner bit by dressing it, and how could it possibly be the ideal bit to resize. |
![]() "Maxwell" wrote No, ya got lost somewhere Dan. The question at this point is how do you resize a forstner bit by dressing it, and how could it possibly be the ideal bit to resize. Turn down the outside, or grind down the outside. It is a relatively small height, and all solid, except for one or two small areas. -- Jim in NC |
... "Maxwell" wrote No, ya got lost somewhere Dan. The question at this point is how do you resize a forstner bit by dressing it, and how could it possibly be the ideal bit to resize. Turn down the outside, or grind down the outside. It is a relatively small height, and all solid, except for one or two small areas. -- Jim in NC You are talking about grinding the OD of one of these bad boys? http://www.woodcraft.com/family.aspx?familyid=8311 Larger pictu http://www.woodcraft.com/InhancedIma...?FamilyID=8311 -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
![]() "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:faOdnWsiTthUryjYnZ2dnUVZ_qGjnZ2d@wideopenwest .com... "Morgans" wrote in message ... "Maxwell" wrote No, ya got lost somewhere Dan. The question at this point is how do you resize a forstner bit by dressing it, and how could it possibly be the ideal bit to resize. Turn down the outside, or grind down the outside. It is a relatively small height, and all solid, except for one or two small areas. -- Jim in NC You are talking about grinding the OD of one of these bad boys? http://www.woodcraft.com/family.aspx?familyid=8311 Larger pictu http://www.woodcraft.com/InhancedIma...?FamilyID=8311 -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. Thanks Geoff, that is the question on my mind too. If you could even find one that was 11/16, you would have to pull .030 per side off of it to get an oversized 5/8. If not, you would have to pull .060 per side off of a 3/4. I don't see how you could do it without a tool grinder. |
![]() "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote You are talking about grinding the OD of one of these bad boys? http://www.woodcraft.com/family.aspx?familyid=8311 Yep/ That's the type. Make a widget to hold a small angle grinder on its side, with a pivot and a screw for advancing the grinder a bit at a time. Make it so that it will work clamped to a drill press table. Put the drill bit in the drill press, and push the bit up and down past the spinning grinder. Advance the grinder a bit at a time, and stop to check the progress often. It works. I've done it before. I am a bit "Rube Goldbergish" at times. That comes in handy, for a homebuilder. Of course, if you know someone who works in a machine shop, he could do the job in a tenth of the time. Where's the fun in that, though? -- Jim in NC |
Wire Strike Info | Ol Shy & Bashful | Piloting | 13 | August 18th 06 03:33 AM |
Helicopter Physics info online anywhere?? | [email protected] | Rotorcraft | 4 | April 24th 04 04:18 PM |
Mooney info | eddie | Owning | 13 | March 12th 04 06:42 PM |
POSA Carb Info and HAPI Engine Info | Bill | Home Built | 0 | March 8th 04 08:23 PM |
Starting new info site need info from the pros | MRQB | Piloting | 7 | January 5th 04 03:20 AM |
