Maxwell wrote:
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:faOdnWsiTthUryjYnZ2dnUVZ_qGjnZ2d@wideopenwest .com... "Morgans" wrote in message ... "Maxwell" wrote No, ya got lost somewhere Dan. The question at this point is how do you resize a forstner bit by dressing it, and how could it possibly be the ideal bit to resize. Turn down the outside, or grind down the outside. It is a relatively small height, and all solid, except for one or two small areas. -- Jim in NC You are talking about grinding the OD of one of these bad boys? http://www.woodcraft.com/family.aspx?familyid=8311 Larger pictu http://www.woodcraft.com/InhancedIma...?FamilyID=8311 -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. Thanks Geoff, that is the question on my mind too. If you could even find one that was 11/16, you would have to pull .030 per side off of it to get an oversized 5/8. If not, you would have to pull .060 per side off of a 3/4. I don't see how you could do it without a tool grinder. If you own a bench grinder, drill press or dremel equivalent make a bracket out of sheet metal, phenolic or hardwood to hold the tool. It sounds a tad Rube Goldburgish but it can be done. I made a few for grinding lathe tools. In the case of a rotating bit you need symmetry as much as size. It seems to me you coulduse a wood block drilled to accept the tool shaft at one end and drilled to make a pivot point at the other. A simple stop like a machine screw could serve as an adjustable stop. Visit a machine shop some time, you'll see some rather clever widgets made for a one time use. You never know, they might have exactly what you are looking for. Dan, U.S. Air Force, retired |
Wire Strike Info | Ol Shy & Bashful | Piloting | 13 | August 18th 06 03:33 AM |
Helicopter Physics info online anywhere?? | [email protected] | Rotorcraft | 4 | April 24th 04 04:18 PM |
Mooney info | eddie | Owning | 13 | March 12th 04 06:42 PM |
POSA Carb Info and HAPI Engine Info | Bill | Home Built | 0 | March 8th 04 08:23 PM |
Starting new info site need info from the pros | MRQB | Piloting | 7 | January 5th 04 03:20 AM |
