IFR Practical test requirements
Old January 23rd 07, 01:06 AM posted to rec.aviation.ifr
kevmor
Default IFR Practical test requirements
So I'm reading my ASA Practical test standards booklet for Instrument
Airplane and it says:
(pg.6)
2. pass the appropriate instrument rating knowledge test SINCE THE
BEGINNING OF THE 24TH MONTH BEFORE THE MONTH IN WHICH THE PRACTICAL
TEST WAS TAKEN.
This means if I took the knowledge test 2/22/05, it's good until the
end of the month, 2/28/07, right? Can anyone make sense of the above?
Old January 23rd 07, 01:14 AM posted to rec.aviation.ifr
Bill Zaleski
(pg.6)
TEST WAS TAKEN.
You are correct. Good till the end of the month 2 years after the
month you took it in.
Old January 23rd 07, 01:19 AM posted to rec.aviation.ifr
Mark Hansen
(pg.6)
TEST WAS TAKEN.
Sounds like you just did. The results are good for 24 months.
Of course, if you think that's just too long, you can always take
the test again ;-)
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old January 24th 07, 09:23 PM posted to rec.aviation.ifr
kevmor
Also, are steep turns required for the practical test? I don't see
them in the standards, but I've heard they are.
(pg.6)
TEST WAS TAKEN.
end of the month, 2/28/07, right? Can anyone make sense of the above?Sounds like you just did. The results are good for 24 months.
the test again ;-)
Sacramento, CA
Old January 24th 07, 09:30 PM posted to rec.aviation.ifr
Mark Hansen
In some cases, the D.E. has a choice from a number of activities,
like "pick any two of the following 5" for example.
Steep turns are part of the PP-ASEL PTS, but I'd have to look at
it to see if they are actually required (I think they are).
(pg.6)
TEST WAS TAKEN.
the test again ;-)
Sacramento, CA
Sacramento, CA
Old January 24th 07, 09:33 PM posted to rec.aviation.ifr
Mark Hansen
Oops, I see now that this was for the IR Practical Test. No, I don't
think steep turns are part of the IR practical. Recovery from unusual
attitudes is (while under the hood, of course) ... and some of those
can be pretty steep ;-)
Sacramento, CA
Old January 25th 07, 01:49 PM posted to rec.aviation.ifr
Ron Natalie
The PTS changed in October. Steep turns for the instrument are gone.
Old January 25th 07, 01:52 PM posted to rec.aviation.ifr
Kevin Clarke
which makes sense since everything is supposed to be standard rate or
1/2 rate.
I'm 1 or 2 more practice rides from the check ride. Looking forward to
being done.
KC
Old January 25th 07, 05:14 PM posted to rec.aviation.ifr
Jim Macklin
They maybe gone from the PTS, but any good training course
will still include them.
James H. Macklin
ATP,CFI,A&P
"Kevin Clarke" wrote in message
link.net...
| Ron Natalie wrote:
I don't see
standard rate or
| 1/2 rate.
Looking forward to
| being done.
| KC
Old January 25th 07, 05:40 PM posted to rec.aviation.ifr
Kevin Clarke
I still did them (awhile ago now). I actually found them easier under
the hood then when doing my PPL. You just keep checking on the AI during
the scan and keep that picture the same. Rollout is the same under the
hood or not. Assuming you don't futz with the power or trim (which you
wouldn't do normally anyway).
KC
Commercial rating: complex aircraft required aircraft for practical test? Marc J. Zeitlin Piloting 22 November 24th 05 04:11 AM
CRS: V-22 Osprey Tilt-Rotor Aircraft Mike Naval Aviation 0 October 14th 05 08:14 PM
Slip to landing on PPG practical test Roger Worden Soaring 56 November 11th 04 09:38 PM
CONRAC CORP C5A COMPUTER TEST SET Mikel Giles General Aviation 0 February 7th 04 05:04 PM
