substitute aluminum for 4130?
Old January 23rd 07, 12:35 AM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
Default substitute aluminum for 4130?
"ChuckSlusarczyk" wrote in message
In article om, Bob
Kuykendall
says...
where it folds over and sticks to itself. AC43.13 change 2e will
address the repair of duct tape laminates, with specific reference to
brand-name materials that went off the market in 1974.
Hmmm I guess we would need to know the section modulus as well and the
moment of
enertia of th section .Maybe a composite of duct tape and cardboard would
give
better stifness .Ahhhh the possibilities are endless :-)
Chuck (tape 'er down boys tape 'er down ) S
Actually, it should be the optimal substitue for Stitts fabric / Polly blah
blah blah - Duct tape is both self stick and pre-finished...
Geoff
Old January 23rd 07, 07:04 PM posted to rec.aviation.homebuilt
Phil
As I remember , it was the substitution of alum. instead of AN Steel bolts
that caused a Thorp T-18 to lose a wing panel at the EAA International
fly-in many years ago , would really want to do the numbers before I would
substitute any material on an aircraft , just the opinion of an old A/C
welder.
Phil Lohiser
Middlefield , Ohio
"Robert Loer" wrote in message
Plans call for wing spar to fuselage carry through attach fiitings to be
7/8x1/8 4130 steel. Advisability of using 9/16x 3/16 6061-T6 aluminum as I
have it on hand.
Your thoughts please. I have plans for another ship which uses the
6061-T6.
Thanks
Old January 23rd 07, 07:34 PM posted to rec.aviation.homebuilt
welder.
Phil Lohiser
I remember another that crashed because the builder used pop
rivets in the spar fittings instead of the AD rivets the plans called
for. Too many homebuilders have died because they made substitutions or
other changes without the knowledge necessary to do it. The designer
often has obscure but important reasons for the materials he specifies,
and the naive builder doesn't realize the peril he creates for himself
and others when he decides that he knows it already.
Dan
Question about Alodine 1201 Andrew Sarangan Home Built 20 April 11th 06 01:31 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
