![]() wrote Over on rec.boats some people say they have found marine ply with voids in the interior plys. And I have had a video card fail on a brand-new laptop, in less than a month. Manufacturing defects occur, in everything under the sun. -- Jim in NC |
wrote in news:1169587980.886995.205400
@s48g2000cws.googlegroups.com: Mustardbuilder wrote: wrote in news:1169496475.404255.84720 @m58g2000cwm.googlegroups.com: ... Dunno, that's what I was asking. I've laminated two pieces of ply together before, just was wondering if it was practical or advisable to do it curved. Laminating a curved piece is, if anything, better than laminating a flat piece, and also better than using a single piece. Yeah, that's what I reckoned. If you laminate it on the curve before the glue sets the laminated plywood will be pre-stressed to the desired curve. You don't need a mold, you can attach one piece, let it set, then glue the second piece over it. Regarding the veneers, the laminated piece should be symetrical. If the pieces have an A and a B face, they should be laminated ABBA or BAAB, not ABAB or BABA. The grain on the new front and back face should be parallel. I'd put the A faces out, ABBA. Well, the don't really. This stuff is so fine it's beyond belief. For instance the 1/4 birch IU have is 12 ply and is one direction on one side and the other on the other side, so it doesn't much matter which way you put it on. Aha, I bet that is exactly why they make it that way. Plywood with the grain on the front and back parallel is 15% stronger (or is it stiffer, I don't remember) vs bending across that grain. Made as you describe, it is more omnidirectional in stiffness. If I were to laminate it for the wing walk, I'd do it with the outer face grain (outside and inside) parallel to the spar It should curve better that way and be a bit stiffer--like the way plywood is laid over joists. OK, that makes sense. This stuff is pretty stiff as it is which is why i'd prefer to make it out of two laminated pieces. But I think aircraft and marine plywood is supposed to have A-grade veneers front and back, right? This stuff has a grade all the way through.. Over on rec.boats some people say they have found marine ply with voids in the interior plys. Yeah, i think that's allowed in marine. This stuff is aircraft grade and I've cut up quite a bit of it into small pieces. I've never found even the tiniest spot in it. Bit of sworl on the outer faces from time to time, but nothing even approaching what you'd call a knothole.. |
![]() On Jan 23, 8:07 pm, Fortunat1 wrote: wrote in news:1169587980.886995.205400 @s48g2000cws.googlegroups.com: Over on rec.boats some people say they have found marine ply with voids in the interior plys. Yeah, i think that's allowed in marine. This stuff is aircraft grade and I've cut up quite a bit of it into small pieces. I've never found even the tiniest spot in it. Bit of sworl on the outer faces from time to time, but nothing even approaching what you'd call a knothole.. No. Repairs (like those football-shaped patches you see the B-face of B-C plywood) are allowed in the interior plys of marine plywood, but no voids. -- FF |
Good news for private pilots' spouses | Skylune | Piloting | 30 | July 7th 06 11:19 PM |
Wing dihedral | Dallas | Piloting | 35 | March 20th 06 04:01 PM |
The Impossibility of Flying Heavy Aircraft Without Training | Immanuel Goldstein | Piloting | 365 | March 16th 06 01:15 AM |
The Impossibility of Flying Heavy Aircraft Without Training | Immanuel Goldstein | Home Built | 331 | March 10th 06 01:07 AM |
An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 03:52 AM |
