Landing gear door operation
Old July 6th 03, 08:38 AM
Urban Fredriksson
Elliot Wilen wrote:
Or generally, is there some reason that some
jets are designed with gear doors that stay open, while others have
doors that close after the gear are extended?
Apart from what's already been mentioned I can add that
the gear bay can contain things which you want to access
during normal handling on the ground. On Draken for
example the ground crew data entry panel is in the nose
gear bay. That's why they open almost 180 deg.
And speaking of air brakes, Gripen's front nose gear door
doubles as one -- but only on the single seat version.
Urban Fredriksson http://www.canit.se/%7Egriffon/
1) What is happening will continue to happen
2) Consider the obvious seriously
3) Consider the consequences - Asimov's "Three Laws of Futurics", F&SF, Oct 74
Old July 8th 03, 03:30 AM
patrick savoie
"Urban Fredriksson" a écrit dans le message de
snip
The same on F-18 ... Maintenance Codes Panel is in nose wheel well and air
pressure indicator for APU in right main wheel well and associated hand pump
in case of pressure lost (good work-out for tech if pressure drops
regularly). There are also assorted pressure gauges and humidity indicators
visible ... without having to open panels.
Although having open wheel wells on landing does occassionaly (very
occasionally) allow FOD to strike inside where there are a lot of small
hydralic lines. A good post-flight inspection can help prevent a problems in
this area.
From what I have seen, other fighters seems to be built in the same way. I
would assume cargo & civilian a/c are similiar.
Pat
Cessna landing gear legs Reserve MET! Bill Berle Home Built 1 February 23rd 04 12:31 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
