Can you dry sump a type1 VW engine?
Old January 24th 07, 06:57 PM posted to rec.aviation.homebuilt
Default Can you dry sump a type1 VW engine?
On Jan 23, 7:03 pm, "Fonz" wrote:
Is is possible (has it been done), to dry sump a type1 VW
engine, such as the one marketed by great planes?
Yes. In fact, it's a standard procedure for high-output engines based
on after-market VW components installed in dragsters.
The use, inverted flight,
and mild -ve Gs.
Entirely different subject, if you mean sustained flight whilst
inverted or knife-edged. Not that it can't be done but that weight &
cost of doing so is generally impractical for such a small engine.
-R.S.Hoover
Old January 27th 07, 07:28 AM posted to rec.aviation.homebuilt
Fonz
Thanks for all replies and links
Rob
Melbourne Australia.
ps.com...
and mild -ve Gs.
-R.S.Hoover
M20 Air/Oil separator Jay Honeck Owning 70 September 3rd 04 06:34 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Motorgliders and gliders in US contests Brian Case Soaring 22 September 24th 03 12:42 AM
