On Wed, 24 Jan 2007 08:46:49 -0700, Newps wrote:
Ron Rosenfeld wrote: I've not flown extensively in mountainous areas. Are there really many airways with MEA's below the minimum 91.177 IFR altitudes for flight? Or are you saying that ATC would not grant the clearance because of radar coverage/MIA/MVA issues? We have lots of airways whose MEA's are well below the peaks of the mountains, 4-5000 feet below. A lot of airways zig zag to get into the low areas or passes between mountains. Some just go right over the top. As for OTP we don't care about radar coverage. We use OTP everyday here, more in the winter than the summer. We don't care what altitude you go at. MVA/MIA is also irrelavant for OTP ops. That's what I thought. When you write about airways below the peaks -- obviously there are many of those. But what I wondered, specifically, if there were MEA's lower than the 91.177 minimum required IFR altitude (2,000' above the highest obstruction within four miles of your flight path). So far as the requiremnt (for pilots) for VFR altitudes, that would only apply at 3000' or more AGL. So would probably not be applicable here. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() Ron Rosenfeld wrote: When you write about airways below the peaks -- obviously there are many of those. But what I wondered, specifically, if there were MEA's lower than the 91.177 minimum required IFR altitude (2,000' above the highest obstruction within four miles of your flight path). No, the MEA would follow the 2000 foot rule over the valley floor. So far as the requiremnt (for pilots) for VFR altitudes, that would only apply at 3000' or more AGL. So would probably not be applicable here. Required altitudes for pilots flying OTP are the pilots problem. I simply don't care. |
Newps wrote:
Required altitudes for pilots flying OTP are the pilots problem. I simply don't care. That sums it up. In the final analysis, it is the pilots' responsiblity to obey FARs and directive information in the AIM. |
On Wed, 24 Jan 2007 08:46:49 -0700, Newps wrote: Ron Rosenfeld wrote: I've not flown extensively in mountainous areas. Are there really many airways with MEA's below the minimum 91.177 IFR altitudes for flight? Or are you saying that ATC would not grant the clearance because of radar coverage/MIA/MVA issues? We have lots of airways whose MEA's are well below the peaks of the mountains, 4-5000 feet below. A lot of airways zig zag to get into the low areas or passes between mountains. Some just go right over the top. As for OTP we don't care about radar coverage. We use OTP everyday here, more in the winter than the summer. We don't care what altitude you go at. MVA/MIA is also irrelavant for OTP ops. That's what I thought. Both of you need to read the AIM 4-4-7. It doesn't say, "Unless otherwise authorized by ATC." ;-) |
On Wed, 24 Jan 2007 09:27:42 -0800, Sam Spade wrote:
Ron Rosenfeld wrote: On Wed, 24 Jan 2007 08:46:49 -0700, Newps wrote: Ron Rosenfeld wrote: I've not flown extensively in mountainous areas. Are there really many airways with MEA's below the minimum 91.177 IFR altitudes for flight? Or are you saying that ATC would not grant the clearance because of radar coverage/MIA/MVA issues? We have lots of airways whose MEA's are well below the peaks of the mountains, 4-5000 feet below. A lot of airways zig zag to get into the low areas or passes between mountains. Some just go right over the top. As for OTP we don't care about radar coverage. We use OTP everyday here, more in the winter than the summer. We don't care what altitude you go at. MVA/MIA is also irrelavant for OTP ops. That's what I thought. Both of you need to read the AIM 4-4-7. It doesn't say, "Unless otherwise authorized by ATC." ;-) 4-4-7 does not appear to prohibit (for the pilot) operations at 91.177 compliant altitudes. If ATC does not issue me an altitude restriction, then 91.177 would apply. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
4-4-7 does not appear to prohibit (for the pilot) operations at 91.177 compliant altitudes. If ATC does not issue me an altitude restriction, then 91.177 would apply. I would agree. But, few pilots can figure that one out. Then, if I am with a Center that is trained to take exception with altitudes below the MEA or MIA, then they will also take exception with my 91.177 selection, if it is "too low." |
On Wed, 24 Jan 2007 13:07:41 -0800, Sam Spade wrote:
Ron Rosenfeld wrote: 4-4-7 does not appear to prohibit (for the pilot) operations at 91.177 compliant altitudes. If ATC does not issue me an altitude restriction, then 91.177 would apply. I would agree. But, few pilots can figure that one out. Then, if I am with a Center that is trained to take exception with altitudes below the MEA or MIA, then they will also take exception with my 91.177 selection, if it is "too low." True, but it is ATC's responsibility to issue me a clearance of "VFR on top at or above nnnn" Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
On Wed, 24 Jan 2007 13:07:41 -0800, Sam Spade wrote: Ron Rosenfeld wrote: 4-4-7 does not appear to prohibit (for the pilot) operations at 91.177 compliant altitudes. If ATC does not issue me an altitude restriction, then 91.177 would apply. I would agree. But, few pilots can figure that one out. Then, if I am with a Center that is trained to take exception with altitudes below the MEA or MIA, then they will also take exception with my 91.177 selection, if it is "too low." True, but it is ATC's responsibility to issue me a clearance of "VFR on top at or above nnnn" Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) I haven't done it in a long time myself. I did have LA Center a couple times way back when say "Unable to approve VFR on top at the requested altitude.." So, since On Top is an amendment to an IFR clearance I think they can make whatever they choose out of their responsibilities with on On-Top amendment to your IFR clearance. Some controllers or facilities, particularly a mountain-area center, might reasonably be very unconfortable with the IFR flight plan aspect of the aircraft being below MIA or MEA. |
On Wed, 24 Jan 2007 17:09:40 -0800, Sam Spade wrote:
I haven't done it in a long time myself. I did have LA Center a couple times way back when say "Unable to approve VFR on top at the requested altitude.." So, since On Top is an amendment to an IFR clearance I think they can make whatever they choose out of their responsibilities with on On-Top amendment to your IFR clearance. Some controllers or facilities, particularly a mountain-area center, might reasonably be very unconfortable with the IFR flight plan aspect of the aircraft being below MIA or MEA. No doubt. Here in the NE I've only used OTP to get through an overcast. And my usual clearance would be basically out of the 7110.65. Something like: CLIMB TO AND REPORT REACHING VFR-ON-TOP, NO TOPS REPORTS. IF NOT ON TOP AT 7000', MAINTAIN 7000', AND ADVISE. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Aztec Lower Cowl Mod STC | Jim Burns | Owning | 3 | April 16th 06 03:21 PM |
Cherokee Strut Lower Strut Seal Replacement Report | Mike Spera | Owning | 3 | July 23rd 05 07:07 PM |
Orca Island, WA | Robert M. Gary | Piloting | 11 | June 5th 04 04:38 PM |
Flight planning at the lower flight levels | Peter R. | Piloting | 2 | March 16th 04 02:39 AM |
Question about Rear Admiral, lower half | Pechs1 | Naval Aviation | 28 | October 5th 03 11:24 PM |
