![]() Mxsmanic wrote: RomeoMike writes: Well, you may get thirsty before dehydrating while playing with your joy stick, but people who work and play in hot climates know that that is not true. I was born and raised in a desert. You get thirsty when you get dehydrated; it is an extremely reliable indicator of dehydration. Physiologists know that dehydration can precede thirst. Only under very unusual circumstances of rapid water loss, which are not likely to ever occur while flying a general aviation aircraft. Essentially, you have to be vomiting, urinating, experiencing diarrhea, or perspiring profusely to dehydrate that rapidly. None of these is very probable in an aviation context. The military knows it in training troops. Pro sports teams know it. Serious hikers know it. None of them are pilot GA aircraft, however, and there is no comparison. You're no more likely to dehydrate significantly in an aircraft than in a car. All plan appropriate water consumption based on planned fluid losses, not thirst. Only when TBW losses are expected to be extremely rapid. That does not apply to general aviation. You also imply in another post in this thread that the kidneys won't make urine if one is dehydrated: They will concentrate as much as they can. If dehydration is extreme, however, they will go into acute renal failure. Again, however, this is never likely to occur in an aviation context. If it burns when you urinate, that's one sign that you are seriously dehydrated. A simple test is to make sure your bladder fills every 3-5 hours, and check to make sure that your urine is not brightly colored. If it is lightly colored and you urinate at least with this frequency, it's unlikely that you are significantly dehydrated. That's not so either, unless you're going into shock. It's normal physiology. Well, it's normal that normal physiology is normal, but you don't know what that normal is. I'm not going to address your ignorance further for the same reasons that others have given up on you. I only responded to suggest to anyone interested in the topic that they not take those statements of yours that I quoted as factual. They should go read an authoritative source about a topic that can be vitally important to some. As for you, who has never even had a flying lesson let alone piloted a plane, you even have the hubris to suggest to an ex-fighter pilot how to recover from a stall. LOL |
Don't bother to argue with him, he knows everything about anything, and is a
world expert on the whining backchat. "RomeoMike" wrote in message ... Mxsmanic wrote: RomeoMike writes: Well, you may get thirsty before dehydrating while playing with your joy stick, but people who work and play in hot climates know that that is not true. I was born and raised in a desert. You get thirsty when you get dehydrated; it is an extremely reliable indicator of dehydration. Physiologists know that dehydration can precede thirst. Only under very unusual circumstances of rapid water loss, which are not likely to ever occur while flying a general aviation aircraft. Essentially, you have to be vomiting, urinating, experiencing diarrhea, or perspiring profusely to dehydrate that rapidly. None of these is very probable in an aviation context. The military knows it in training troops. Pro sports teams know it. Serious hikers know it. None of them are pilot GA aircraft, however, and there is no comparison. You're no more likely to dehydrate significantly in an aircraft than in a car. All plan appropriate water consumption based on planned fluid losses, not thirst. Only when TBW losses are expected to be extremely rapid. That does not apply to general aviation. You also imply in another post in this thread that the kidneys won't make urine if one is dehydrated: They will concentrate as much as they can. If dehydration is extreme, however, they will go into acute renal failure. Again, however, this is never likely to occur in an aviation context. If it burns when you urinate, that's one sign that you are seriously dehydrated. A simple test is to make sure your bladder fills every 3-5 hours, and check to make sure that your urine is not brightly colored. If it is lightly colored and you urinate at least with this frequency, it's unlikely that you are significantly dehydrated. That's not so either, unless you're going into shock. It's normal physiology. Well, it's normal that normal physiology is normal, but you don't know what that normal is. I'm not going to address your ignorance further for the same reasons that others have given up on you. I only responded to suggest to anyone interested in the topic that they not take those statements of yours that I quoted as factual. They should go read an authoritative source about a topic that can be vitally important to some. As for you, who has never even had a flying lesson let alone piloted a plane, you even have the hubris to suggest to an ex-fighter pilot how to recover from a stall. LOL |
![]() Barney Rubble wrote: Don't bother to argue with him, he knows everything about anything, and is a world expert on the whining backchat. I'm avoiding his assertions regarding physiology scattered throughout this thread. He displays in them two bad proclivities. One is to run to the Internet to get a superficial and often erroneous impression of some topic and then post in an authoritative fashion based on that info. The other is to not be willing to alter his misconceptions if challenged. He digs himself further into a hole and gets more and more ridiculous. |
Iran is preparing for an underground nuclear test with North Korean help before year's end | AirRaid Mach 2.5 | Naval Aviation | 19 | March 19th 07 04:21 AM |
MSC podcast with Gordon Boettger - Preparing for the Wave | [email protected] | Soaring | 9 | February 2nd 06 03:20 PM |
Israel Preparing For Military Action To Stop Iran's Nuclear Program... | [email protected] | Naval Aviation | 1 | January 23rd 06 04:57 AM |
Operation Brother's Keeper preparing for Rita | Jim Burns | Owning | 1 | September 23rd 05 12:59 AM |
Operation Brother's Keeper preparing for Rita | Jim Burns | Piloting | 1 | September 23rd 05 12:59 AM |
