IFR Practical test requirements
Old January 25th 07, 05:51 PM posted to rec.aviation.ifr
Mark Hansen
Default IFR Practical test requirements
On 01/25/07 09:40, Kevin Clarke wrote:
Jim Macklin wrote:
They maybe gone from the PTS, but any good training course
will still include them.
I still did them (awhile ago now). I actually found them easier under
the hood then when doing my PPL. You just keep checking on the AI during
the scan and keep that picture the same. Rollout is the same under the
hood or not. Assuming you don't futz with the power or trim (which you
wouldn't do normally anyway).
KC
No trim? Hmmmm, I don't know about that. I was taught that adjusting the
trim is a great way to ease some of the burden of holding the back
pressure during the steep turn. I didn't do it until I practiced steep
turns under the hood, and found it made it much easier.
Of course, you have to remember to remove the trim when you roll out ;-)
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old January 25th 07, 06:13 PM posted to rec.aviation.ifr
Kevin Clarke
KC
after you are in the turn. Don't futz with the trim. Trim the **** out
of it as you enter the turn. You can go hands off if you do it right.
The plane will circle until you run out of gas!
KC
Old January 25th 07, 07:06 PM posted to rec.aviation.ifr
Mark Hansen
KC
Well ... this is what I meant. Trim while you're rolling-in and again
while rolling-out.
Sacramento, CA
Old January 25th 07, 07:18 PM posted to rec.aviation.ifr
B A R R Y[_2_]
KC
I was taught to add a tick of power, as well as trimming.
Commercial rating: complex aircraft required aircraft for practical test? Marc J. Zeitlin Piloting 22 November 24th 05 04:11 AM
CRS: V-22 Osprey Tilt-Rotor Aircraft Mike Naval Aviation 0 October 14th 05 08:14 PM
Slip to landing on PPG practical test Roger Worden Soaring 56 November 11th 04 09:38 PM
CONRAC CORP C5A COMPUTER TEST SET Mikel Giles General Aviation 0 February 7th 04 05:04 PM
