Peter R. wrote:
One tip, though: Don't bother hooking up a funnel and hose to the jug. This will result in a most undesirable backflow. This is what Usenet is all about: learning from other people's mistakes. .... Alan -- Alan Gerber PP-ASEL gerber AT panix DOT com |
![]() "Alan Gerber" wrote This is what Usenet is all about: learning from other people's mistakes. How true. If you were to use a small vent tube in addition to the flow tube, that would eliminate the backup problem. It is just another point of leakage, so to speak. -- Jim in NC |
On Thu, 25 Jan 2007 22:40:23 -0500, in ,
Morgans wrote: If you were to use a small vent tube in addition to the flow tube, that would eliminate the backup problem. It is just another point of leakage, so to speak. Of course, some of have aircraft with canopies, so theoretically, all we need to do is slow to an acceptable speed, slide back the canopy, and pee off the side... grin Come to think of it, drilling a hole in the floor and running a tube through there for a relief tube is starting to sound a lot better... |
Grumman-581,
Come to think of it, drilling a hole in the floor and running a tube through there for a relief tube is starting to sound a lot better... You mean, regularly spraying a highly corrosive fluid onto the underside of your plane, which then creeps in through every opening and seam, sounds good? I don't get it... -- Thomas Borchert (EDDH) |
Thomas Borchert writes:
You mean, regularly spraying a highly corrosive fluid onto the underside of your plane, which then creeps in through every opening and seam, sounds good? I don't get it... Urine is not highly corrosive. It's mostly sterile, dilute salt water with a bit of urea, and a neutral pH. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Sigh.
It is not its pH that makes urine corrosive, but the dissolved salts that become reactive. That's why cars that are close to the oceans rust more quickly than do those in rainy inland locations. Sooner or later you may get something right. Let me rephrase that. Sooner or later you may apply a known fact correctly to the situation being discussed. That urine is more or less neutral, or even more importantly has little buffering capacity, is true, but that fact is not relevant to the topic. On Jan 26, 8:14 am, Mxsmanic wrote: Thomas Borchert writes: You mean, regularly spraying a highly corrosive fluid onto the underside of your plane, which then creeps in through every opening and seam, sounds good? I don't get it...Urine is not highly corrosive. It's mostly sterile, dilute salt water with a bit of urea, and a neutral pH. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Tony writes:
It is not its pH that makes urine corrosive, but the dissolved salts that become reactive. That's why cars that are close to the oceans rust more quickly than do those in rainy inland locations. Urine isn't usually terribly concentrated. Some of the byproducts of urine that are produced after exogenous microorganisms attack it (such as ammonia) are much more damaging. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() On Jan 26, 12:49 pm, "Tony" wrote: Sigh. It is not its pH that makes urine corrosive, but the dissolved salts that become reactive. That's why cars that are close to the oceans rust more quickly than do those in rainy inland locations. Tony, Here is another example of the corrosive effect of urine http://tinyurl.com/26ghv8 "On the pitting corrosion of high strength aluminium alloys by rat urine Sreekumar, K; Jacob, E; Natarajan, A; Lakshmanan, T S Praktische Metallographie (Germany). Vol. 34, no. 9, pp. 478-481. Sept. 1997 High strength AFNOR 7020 aluminium alloy sheets in T6 condition are used for fabricating propellant tanks (nitrogen tetroxide N sub 2 O sub 4 and unsymmetrical dimethyl hydrazine UDMH) for launch vehicle applications. These tanks are fabricated through welding route and are filled with dry nitrogen gas at 300 mbar and sealed at both ends. The tank is then cocooned with aluminised plastic sheets and stored under positive dry nitrogen gas pressure. During the storage rats had cut open the aluminised plastic sheets and had urinated all over the surfaces of the aluminium alloy tank. The tank surface showed discolouration and severe pitting corrosion attack wherever the rat urine had come in contact with it. This paper highlights the investigations made to understand the severity of the corrosion attack on the surface of the tank with a view to clear it for further processing and utilisation. I'd bet someone will argue that rat urine is not the same as human stuff. The counter argument is that some people are considered 'dirty rats' ;-) By the way, the pH level of human urine can range from 4.5 to 8 and normal urine is slightly acidic. |
![]() "Mxsmanic" wrote in message ... Thomas Borchert writes: You mean, regularly spraying a highly corrosive fluid onto the underside of your plane, which then creeps in through every opening and seam, sounds good? I don't get it... Urine is not highly corrosive. It's mostly sterile, dilute salt water with a bit of urea, and a neutral pH. Quit demonstrating your stupidity or cite your sources, such as: Read the last line twice... http://www.nlm.nih.gov/medlineplus/e...cle/003583.htm ....pH is a measure of how acidic or alkaline a fluid is, like blood or urine. The pH in blood is maintained within the narrow range of 7.35 to 7.45. Your body maintains this narrow range by using buffers -- chemicals that can switch back and forth between 2 forms, a weak acid or weak base. The buffers are only temporary "stop gaps" to avoid dramatic changes in blood pH. Long-term correction of blood pH requires the kidneys to excrete the acid or base in urine. For example, when your blood pH is low (acidic), your kidneys react by excreting more acid in the urine. The urine pH becomes more acidic until the blood pH returns to normal. In some cases, checking your urine pH is helpful for identifying body acid-base imbalances. In other cases, a blood pH test is needed. Your provider may want to modify your urine pH to help prevent kidney stones. Acidic urine is associated with xanthine, cystine, uric acid, and calcium oxalate stones. Alkaline urine is associated with calcium carbonate, calcium phosphate, and magnesium phosphate stones. Some medications are more effective in acidic or alkaline environments. For example, streptomycin, neomycin, and kanamycin are more effective in treating urinary tract infections when the urine is alkaline. Normal Values Return to top The normal values range from 4.6 to 8.0. |
Casey Wilson writes:
Long-term correction of blood pH requires the kidneys to excrete the acid or base in urine. The acid or base. QED. The normal pH is very close to 7 (neutral). Your provider may want to modify your urine pH to help prevent kidney stones. Acidic urine is associated with xanthine, cystine, uric acid, and calcium oxalate stones. Alkaline urine is associated with calcium carbonate, calcium phosphate, and magnesium phosphate stones. Acid, alkaline. See? The normal values range from 4.6 to 8.0. And the average is just about 7.0. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Iran is preparing for an underground nuclear test with North Korean help before year's end | AirRaid Mach 2.5 | Naval Aviation | 19 | March 19th 07 04:21 AM |
MSC podcast with Gordon Boettger - Preparing for the Wave | [email protected] | Soaring | 9 | February 2nd 06 03:20 PM |
Israel Preparing For Military Action To Stop Iran's Nuclear Program... | [email protected] | Naval Aviation | 1 | January 23rd 06 04:57 AM |
Operation Brother's Keeper preparing for Rita | Jim Burns | Owning | 1 | September 23rd 05 12:59 AM |
Operation Brother's Keeper preparing for Rita | Jim Burns | Piloting | 1 | September 23rd 05 12:59 AM |
