"ContestID67" wrote in message ups.com... I have a question for this august body. I found a link on the 1-26 associations web site talking about the proper length of an antenna for operation at 123.3Mhz. This turns out to be; 1/4 wave Length: 0.61 m or 23.95 in 3/4 wave Length: 1.82 m or 71.84 in I was curious about the length of the coax. I was under the impression that to get the maximum power out of the antenna, that the combined total length of the coax *AND* the antenna needs to be taken into consideration and needs to be an even number of wavelengths. That prevents power from reflecting at the tip of the antenna and then back into the trasceiver. This can not only rob radiated power but might also damage the transceiver. A VSWR meter is used to tune this for maximum radiated power typically by adjusting the length of the antenna. I may be all wet on this subject as I am an electronics engineer (a bit pusher) and not an RF electrical engineer. Any comments? Where you have an antenna connected to a transmitter or receiver via a length of coax the important thing is that the characteristic impedance of the various components match to ensure maximum power transfer and eliminate reflections in the system. This is achieved by using the correct type of coax for the equipment and making sure the antenna is the correct length. You can use a VSWR meter to match the antenna to the rest of the system (start long and snip bits off). The length of the coax is not important from the point of view of matching the impedance. However, because the coax will attenuate the signal, the shorter it is the better. These might explain things: http://en.wikipedia.org/wiki/VSWR (go to the practical implications section). http://en.wikipedia.org/wiki/Characteristic_impedance Stephen |
| Thread Tools | |
| Display Modes | |
| I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 06:39 PM |
| LORAN antenna difference? | JFLEISC | Home Built | 6 | December 24th 04 11:10 PM |
| Antenna ground plane and coax grounding | G. Fred McCutchen | Home Built | 2 | August 8th 04 01:27 PM |
| ELT antenna -- Pitts | Al MacDonald | Home Built | 0 | July 15th 04 04:27 PM |
| Yaesu/Vertex coax antenna adaptor | RM | Piloting | 15 | July 13th 04 10:32 PM |
