Battery-Driven Tanis
Old January 31st 07, 11:01 PM posted to rec.aviation.piloting
Jim Macklin
Default Battery-Driven Tanis
Go to a store and buy a portable gasoline powered generator.
Get insulating blankets for the cowl, otherwise all the heat
will escape.
If you can setup some sort of remote starting for the
generator, you can get started warming it up or just start
the generator and go get a cup of coffee.
You don't want to be hauling hundreds of pounds of acid
filled batteries around.
Or run a powerline, they do that all the time at
construction sites.
"BDS" wrote in message
et...
| "Marco Leon" wrote in message
| I have a common problem of possessing a Tanis heater in
my Warrior but
| no electrical source by which to run it. Past newsgroup
and online
| knowledge (including an email from Tanis) say that at
least a couple
| of hours are needed to heat the engine in about 20 deg F
temps.
| An old post from 1999 suggested that a "deep cycle"
battery be used in
| conjuction with an inverter to be turned on a couple of
hours prior to
| flight.
| Looks like the smallest Tanis heaters are around 250
watts. Even with a
| good inverter you will probably consume around 300 watts,
or 25 amps at 12
| volts.
| Most of the deep cycle batteries are rated based on a
20-hr discharge rate.
| That means that a 225 amp-hr battery will only deliver
that storage capacity
| when it is discharged at the 20-hr rate, or in this case
about 12.5 amps -
| if you discharge it faster (25 amps) then you will not get
rated capacity.
| Of course, the battery will not do as well in very cold
temperatures either.
| In addition and IIRC, deep cycle batteries are designed to
be discharged to
| about 20% of capacity and no more.
| Even so, it looks like getting a couple of hours out of a
225 amp-hr battery
| shouldn't be a problem. You will just have to haul the
thing around and
| keep it charged all the time to be able to use it and to
keep it healthy. I
| wouldn't expect that you'd be able to run more than about
5 or 6 hours
| continuous though, and again, that's on a healthy battery.
| If your heater has a higher rating than 250 watts, you
would have to take
| that into account and decrease the numbers above
accordingly.
| BDS
Old February 1st 07, 04:30 PM posted to rec.aviation.piloting
Marco Leon
On Jan 31, 6:01 pm, "Jim Macklin"
will escape.
That's a good point about the acid batteries. Charging would be a
constantpain as well.
I think you guys are convincing me to go the generator route...
Old February 1st 07, 04:54 PM posted to rec.aviation.piloting
I've been reading this tread with some interest, but I am fortunate in
that I have electricity to my hanger. What I'm curious about is the
cell phone or pager thing to turn on a heater remotely. Has anyone
done that, and how so? One thing that came to mind with pagers is that
alot of times they will beep something like once a minute as a
reminder if you don't push the button when it goes off, does that mean
that any application would be switching on and off likewise if you
used a pager?
-Ryan Wubben
Madison
Old February 1st 07, 05:27 PM posted to rec.aviation.piloting
Marco Leon
used a pager?
-Ryan Wubben
Madison
You can start he http://www.reiffpreheat.com/Beeper%20Box%20pg%201.htm.
There are others on the market I believe. There's also a $15
ThermoCube that turns on the outlet under a certain temperature.
Sporty's has it.
Marco
battery self-destruct [email protected] Owning 13 June 13th 06 11:04 PM
Battery Question [email protected] Soaring 19 September 15th 05 01:38 AM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 01:37 AM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 06:32 PM
