Starter question
Old February 1st 07, 04:45 PM posted to rec.aviation.owning
Default UPDATE Starter question
On Feb 1, 8:55 am, Tauno Voipio wrote:
On Jan 31, 6:53 pm, john smith wrote:
In article .com,
Coils (inductors) are current storage devices.
Capacitors are voltage storage devices.
As if current and voltage were independent of each other?
The coil will produce a surge of current, which has a specific
pressure that we call voltage. You can't have current flow without
voltage; any flow (amperage) requires pressure (voltage) to drive it.
Just like water in a hose.
It seems that you need some basic physics repeat training.
The quote above about storage is correct for capacitances
and inductances.
An inductance converts current changes into voltage changes
in such a way that it opposes the original current changes,
that is, an inductance smoothes current flow at the expense
of voltage changes.
A capacitance converts voltage changes into current changes
in such a way that it opposes the original voltage change,
that is, a capacitance smoothes a voltage at the expense
of current changes.
The magneto produces a pressure upward of 20,000 volts. It
does this using a pair of coils and a switch (points). Your
automobile's ignition system probably produces 40,000 volts, again
using paired coils. Both of those systems have a primary coil that
produces the current surge (which has a voltage spike) when its
current flow is interrupted, and the collapsing magnetic field
produces the huge spike in the secondary coil for use at the spark
plug.
The voltage from a magneto (or a simple spark coil) comes from
two sources:
- the abrupt break of the current in the primary winding of
the coil. It creates a voltage spike to (in vain) keep the
current smooth.
- the transformation ratio of the primary to the secondary
winding in the coil.
A magneto works in the same way as a spark coil, but the initial
current is created by a generator action of the moving magnet.
So tell me where I was wrong.
Dan
Old February 1st 07, 05:33 PM posted to rec.aviation.owning
Tauno Voipio
In article .com,
and inductances.
of voltage changes.
of current changes.
plug.
two sources:
current smooth.
Dan
He
--- quote ---
-- end quote --
They are - the circuit impedance ties them together.
--- quote ---
-- end quote --
The coil *suppresses* surges of *current* by producing surges
of voltage. Here, the coil is the impedance creating the relation
of voltage and current.
--- quote ---
-- end quote --
There are weird things called superconductors, where this
does not apply - in normal conductors, the conductor resistance
is the impedance tying voltage and current together.
Tauno Voipio
tauno voipio (at) iki fi
Lightweight Starter for Sale! Tom Enterline Home Built 0 July 4th 05 09:25 PM
Stumped by new starter Jim Burns Owning 16 January 13th 05 03:42 PM
Starter Questions Aaron Coolidge Owning 4 June 30th 04 02:52 PM
Stuck starter solenoid? Paul Lee Home Built 4 April 16th 04 02:58 PM
Starter selection -- seeking input [email protected] Owning 3 April 5th 04 12:43 AM
