Battery-Driven Tanis
Old February 2nd 07, 12:08 AM posted to rec.aviation.piloting
Dave[_5_]
Default Battery-Driven Tanis
On Feb 1, 8:26 am, "BDS" wrote:
"Dave" wrote
You could charge the battery with a solar
panel
That might not work so well in an application like this. If he has the 250
watt heater and runs it for 3 hours then he has removed 750 watt-hours of
energy from the battery (plus change).
A typical solar panel charger is meant for trickle charging and they only
put out something like 10 watts or less, although I've seen some up around
20 watts. That means that it will take 75 hours of charging time at 10
watts to replace that 750 watt-hours, and that's at 100% efficiency which,
as well all know, doesn't exist.
Most of these deep cycle cells are looking for a charge at around 20 amps
for 10 hours or so to bring them up to full charge, and then a float charge
to hold the terminal voltage around 13.8 volts.
Either a generator or a propane-fired pre-heater is the way to go here.
BDS
I did say that you'd have to do the math to see if it is practical or
not. I think it would work for someone who flies infrequently. Solar
power does have a significant upfront cost - but is essentially free
thereafter.
Personally I have had good luck with a couple of ceramic "cube"
heaters with dryer duct hoses attached to the business end - but have
been fortunate to have had AC available.
David Johnson
battery self-destruct [email protected] Owning 13 June 13th 06 11:04 PM
Battery Question [email protected] Soaring 19 September 15th 05 01:38 AM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 01:37 AM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 06:32 PM
