![]() "xerj" wrote I don't mean opening the throttle to make up for the engine power loss. I mean the fact that to maintain the same IAS you need more power as you go up. Why the preoccupation with IAS? At around 6,000 feet, the power of a non turbo piston engine is around 75%. As you go higher, the power drops off, but the true air speed goes up. Who cares about IAS? The question was does it take more power to go faster, right? Any non pilot will think faster means true airspeed, not indicated. -- Jim in NC |
faster, right? Any non pilot will think faster means true airspeed, not indicated. True, but the conversation got to how high a plane can fly. I said that going higher did two things: limited the amount of power that an engine can put out because of density, and that even if you had an engine that didn't lose power, the power required goes up regardless. Also, not that it would matter to a non-pilot, but IAS obviously matters for keeping best range speed for instance. |
![]() "xerj" wrote Also, not that it would matter to a non-pilot, but IAS obviously matters for keeping best range speed for instance. How so? -- Jim in NC |
![]() Also, not that it would matter to a non-pilot, but IAS obviously matters for keeping best range speed for instance. How so? Best L/D occurs at a particular angle of attack. This corresponds fairly well to indicated airspeed. |
I mean the fact that to maintain the same IAS you need more power as you go up. Why the preoccupation with IAS? At around 6,000 feet, the power of a non turbo piston engine is around 75%. As you go higher, the power drops off, but the true air speed goes up. Who cares about IAS? The question was does it take more power to go faster, right? Any non pilot will think faster means true airspeed, not indicated. -- Ok, I confess, I'd rather have an angle of attack meter to correlate more directly with the best coefficients of lift and drag independently of current weight. But IAS and a little math based on initial weight and fuel consumed should work well enough for us cheap-skates. Even if you are operating at a speed other than best L/D, which seems mostly reserved for Glider Pilots and Jet Jocks, reference to IAS is about the only way (that I know of) to keep the theoretical discussion understandable Peter Cheapest of the cheap ;-)) |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
#1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 03:04 AM |
Change in TAS with constant Power and increasing altitude. | Big John | Home Built | 6 | July 13th 03 03:29 PM |
