![]() "Cecil Chapman" wrote in message ... Question: As part of the Private Pilot training there is a minimum of 3 hours of hood/instrument training required. One of the things which seems to be always taught (it was the way I was taught and the way I am instructing) is the one minute standard rate turn which is to be used by a Private Pilot if he/she gets theirselves into some IMC, inadvertently. No matter who I ask, I get the same technique (which is the way I was trained during my PPL training); standard rate turn, one minute (3 degrees per second times 60 equals 180 degrees). Aside from the scenario where there is a vacuum system failure (where you lose the DG, for example), what is so wrong with teaching them to look at the bottom of the heading indicator and standard rate turn to that value? The answers I get when I ask this question, vary from, 'I was just taught to use time', 'the pilot is likely to forget the 180 degree heading they were supposed to roll out on', etc... I teach, by timing, just as I was taught, but still haven't got a compelling answer as to why not have them look at the 'bottom' of the DG and turn to that heading (standard rate)? For those I've spoken to that have said, "they are more likely to forget the heading than mess up the time", I can see that they could just as easily lose track of the time as they could the clock. This may be a hold over to the old days when a common VFR panel was a turn and bank and a mag compass. In this case using the compass while turning is not good because of the known error caused by being banked. Danny Deger |
On Sat, 3 Feb 2007 12:43:54 -0600, "Danny Deger"
wrote: This may be a hold over to the old days when a common VFR panel was a turn and bank and a mag compass. In this case using the compass while turning is not good because of the known error caused by being banked. +1 Needle, ball, and airspeed. Don |
Danny Deger wrote:
This may be a hold over to the old days when a common VFR panel was a turn and bank and a mag compass. In this case using the compass while turning is not good because of the known error caused by being banked. DG's are not required for VFR flight. Even the partial panel IFR training typically use the needle to make timed turns to heading. Once you settle down you can verify with the mag compass you're on the heading you want. |
On Sat, 03 Feb 2007 19:03:23 -0500, Ron Natalie
wrote: Even the partial panel IFR training typically use the needle to make timed turns to heading. Once you settle down you can verify with the mag compass you're on the heading you want. When I learned IFR the instructor kept the AH covered until the check ride. I still prefer the TC to the AH but I notice that the new planes with the glass panels have a back up AH but no TC. |
Change in AIM wording concerning procedure turn | Kris Kortokrax | Instrument Flight Rules | 208 | October 14th 05 12:58 AM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
35th's Life Support Section named best in the Air Force | Otis Willie | Military Aviation | 0 | July 16th 04 11:08 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
