#11
![]() "Cecil Chapman" wrote in message ... Question: As part of the Private Pilot training there is a minimum of 3 hours of hood/instrument training required. One of the things which seems to be always taught (it was the way I was taught and the way I am instructing) is the one minute standard rate turn which is to be used by a Private Pilot if he/she gets theirselves into some IMC, inadvertently. No matter who I ask, I get the same technique (which is the way I was trained during my PPL training); standard rate turn, one minute (3 degrees per second times 60 equals 180 degrees). Aside from the scenario where there is a vacuum system failure (where you lose the DG, for example), what is so wrong with teaching them to look at the bottom of the heading indicator and standard rate turn to that value? The answers I get when I ask this question, vary from, 'I was just taught to use time', 'the pilot is likely to forget the 180 degree heading they were supposed to roll out on', etc... I teach, by timing, just as I was taught, but still haven't got a compelling answer as to why not have them look at the 'bottom' of the DG and turn to that heading (standard rate)? For those I've spoken to that have said, "they are more likely to forget the heading than mess up the time", I can see that they could just as easily lose track of the time as they could the clock. Anyone have any 'whys' on this one? It's probably a carry-over from the old style of directional gyro, which looked a lot like a larger wet compass with a caging knob mounted in the panel. What is now thought of as the bottom of the display was out of view on the far side (back) of the instrument. I don't know when those ceased to be installed in new aircraft, but there were a lot of them still in service in the 1980's--and they had a couple of interesting quirks. They could be easily tumbled by an excessive bank angle and the caging knob could also be left engaged--supposedly to prevent damage when practicing spins in VMC. I was taught to ALWAYS pull the knob back AND twist it sharply after resetting the direction to make SURE that it was not still engaged. IIRC, there was also a related quirk to the old "gull wing" artificial horizons--in addition to being devilishly difficult to use. I believe that they tumbled at just over 60 degrees of bank, and were very slow to recover. The overall result was that, in the bad old days, the turn indicator was the only gyro based instrument that you could always trust--even when taken by surprise. Peter |
Change in AIM wording concerning procedure turn | Kris Kortokrax | Instrument Flight Rules | 208 | October 14th 05 12:58 AM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
35th's Life Support Section named best in the Air Force | Otis Willie | Military Aviation | 0 | July 16th 04 11:08 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
