The one minute turn that can save your life
Question:
As part of the Private Pilot training there is a minimum of 3 hours of hood/instrument training required. One of the things which seems to be always taught (it was the way I was taught and the way I am instructing) is the one minute standard rate turn which is to be used by a Private Pilot if he/she gets theirselves into some IMC, inadvertently. No matter who I ask, I get the same technique (which is the way I was trained during my PPL training); standard rate turn, one minute (3 degrees per second times 60 equals 180 degrees). Aside from the scenario where there is a vacuum system failure (where you lose the DG, for example), what is so wrong with teaching them to look at the bottom of the heading indicator and standard rate turn to that value? The answers I get when I ask this question, vary from, 'I was just taught to use time', 'the pilot is likely to forget the 180 degree heading they were supposed to roll out on', etc... I teach, by timing, just as I was taught, but still haven't got a compelling answer as to why not have them look at the 'bottom' of the DG and turn to that heading (standard rate)? For those I've spoken to that have said, "they are more likely to forget the heading than mess up the time", I can see that they could just as easily lose track of the time as they could the clock. Anyone have any 'whys' on this one? -- =----- Good Flights! Cecil E. Chapman CFI-A, CP-ASEL-IA Check out my personal flying adventures from my first flight to the checkride AND the continuing adventures beyond! Complete with pictures and text at: www.bayareapilot.com "I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery - "We who fly, do so for the love of flying. We are alive in the air with this miracle that lies in our hands and beneath our feet" - Cecil Day Lewis - |
"Cecil Chapman" wrote in message ... Question: As part of the Private Pilot training there is a minimum of 3 hours of hood/instrument training required. One of the things which seems to be always taught (it was the way I was taught and the way I am instructing) is the one minute standard rate turn which is to be used by a Private Pilot if he/she gets theirselves into some IMC, inadvertently. No matter who I ask, I get the same technique (which is the way I was trained during my PPL training); standard rate turn, one minute (3 degrees per second times 60 equals 180 degrees). Aside from the scenario where there is a vacuum system failure (where you lose the DG, for example), what is so wrong with teaching them to look at the bottom of the heading indicator and standard rate turn to that value? The answers I get when I ask this question, vary from, 'I was just taught to use time', 'the pilot is likely to forget the 180 degree heading they were supposed to roll out on', etc... I teach, by timing, just as I was taught, but still haven't got a compelling answer as to why not have them look at the 'bottom' of the DG and turn to that heading (standard rate)? For those I've spoken to that have said, "they are more likely to forget the heading than mess up the time", I can see that they could just as easily lose track of the time as they could the clock. This may be a hold over to the old days when a common VFR panel was a turn and bank and a mag compass. In this case using the compass while turning is not good because of the known error caused by being banked. Danny Deger |
I'm not a CFII but am ASEL-IA. I found super-basic attitude flying
pretty easy after only during those 3 hours with my CFI. So from my perspective, I don't know why either. Whatever is easiest to fix the VFR into IMC scenario. The only thing I'd think of is the VFR pilot might sweat the small stuff by being off 5 degrees on the heading. The one thing that many CFII don't teach is that the pilot should be able to do a standard rate turn using the AI only. It won't be a perfect standard rate turn but we're not looking for perfection, just something to save their hides. Most students are flying 152 / 172 to Warrior type airplanes which means ~15 degree bank at cruis speed. Use the AI to keep a level pitch attitude and maintain altitude. Basically all the student would have to do is look at the AI and the DG rather than having to fly effectively partial panel. From everything that I've read, heard , taught and practice, IFR flying is 80% plus looking at the AI with quick glances for confirmation to the other instruments. Why do it differently for VFR students? Gerald |
"Cecil Chapman" wrote in message ... Question: As part of the Private Pilot training there is a minimum of 3 hours of hood/instrument training required. One of the things which seems to be always taught (it was the way I was taught and the way I am instructing) is the one minute standard rate turn which is to be used by a Private Pilot if he/she gets theirselves into some IMC, inadvertently. No matter who I ask, I get the same technique (which is the way I was trained during my PPL training); standard rate turn, one minute (3 degrees per second times 60 equals 180 degrees). Aside from the scenario where there is a vacuum system failure (where you lose the DG, for example), what is so wrong with teaching them to look at the bottom of the heading indicator and standard rate turn to that value? The answers I get when I ask this question, vary from, 'I was just taught to use time', 'the pilot is likely to forget the 180 degree heading they were supposed to roll out on', etc... I teach, by timing, just as I was taught, but still haven't got a compelling answer as to why not have them look at the 'bottom' of the DG and turn to that heading (standard rate)? For those I've spoken to that have said, "they are more likely to forget the heading than mess up the time", I can see that they could just as easily lose track of the time as they could the clock. Anyone have any 'whys' on this one? It's probably a carry-over from the old style of directional gyro, which looked a lot like a larger wet compass with a caging knob mounted in the panel. What is now thought of as the bottom of the display was out of view on the far side (back) of the instrument. I don't know when those ceased to be installed in new aircraft, but there were a lot of them still in service in the 1980's--and they had a couple of interesting quirks. They could be easily tumbled by an excessive bank angle and the caging knob could also be left engaged--supposedly to prevent damage when practicing spins in VMC. I was taught to ALWAYS pull the knob back AND twist it sharply after resetting the direction to make SURE that it was not still engaged. IIRC, there was also a related quirk to the old "gull wing" artificial horizons--in addition to being devilishly difficult to use. I believe that they tumbled at just over 60 degrees of bank, and were very slow to recover. The overall result was that, in the bad old days, the turn indicator was the only gyro based instrument that you could always trust--even when taken by surprise. Peter |
On Sat, 3 Feb 2007 12:43:54 -0600, "Danny Deger"
wrote: This may be a hold over to the old days when a common VFR panel was a turn and bank and a mag compass. In this case using the compass while turning is not good because of the known error caused by being banked. +1 Needle, ball, and airspeed. Don |
I trust the clock more than the heading indicator. So what if you roll out a
few degrees off of exactly 180? If you are trying to escape weather or avoid special use airspace, the name of the game is to go away, not to go away on a specific heading. Anyone who can't remember that the second hand (gotta have one, you know) was on the twelve, or whatever, should have his or her head examined. Bob Gardner "Cecil Chapman" wrote in message ... Question: As part of the Private Pilot training there is a minimum of 3 hours of hood/instrument training required. One of the things which seems to be always taught (it was the way I was taught and the way I am instructing) is the one minute standard rate turn which is to be used by a Private Pilot if he/she gets theirselves into some IMC, inadvertently. No matter who I ask, I get the same technique (which is the way I was trained during my PPL training); standard rate turn, one minute (3 degrees per second times 60 equals 180 degrees). Aside from the scenario where there is a vacuum system failure (where you lose the DG, for example), what is so wrong with teaching them to look at the bottom of the heading indicator and standard rate turn to that value? The answers I get when I ask this question, vary from, 'I was just taught to use time', 'the pilot is likely to forget the 180 degree heading they were supposed to roll out on', etc... I teach, by timing, just as I was taught, but still haven't got a compelling answer as to why not have them look at the 'bottom' of the DG and turn to that heading (standard rate)? For those I've spoken to that have said, "they are more likely to forget the heading than mess up the time", I can see that they could just as easily lose track of the time as they could the clock. Anyone have any 'whys' on this one? -- =----- Good Flights! Cecil E. Chapman CFI-A, CP-ASEL-IA Check out my personal flying adventures from my first flight to the checkride AND the continuing adventures beyond! Complete with pictures and text at: www.bayareapilot.com "I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery - "We who fly, do so for the love of flying. We are alive in the air with this miracle that lies in our hands and beneath our feet" - Cecil Day Lewis - |
"G. Sylvester" wrote in message
From everything that I've read, heard , taught and practice, IFR flying is 80% plus looking at the AI with quick glances for confirmation to the other instruments. Why do it differently for VFR students? Maybe I'm an anomaly, but I don't use the AI nearly that much in my IMC flying. Still, your point about 12-15 degrees bank for standard rate is a good rule of thumb. I think teaching the standard rate turn helps prevent overbanking and spatial disorientation in a pilot who may not be accustomed to gray-filled windshields. Using the DG in addition to this helps the student/pilot get pointed in the right direction, but using relatively gentle turns at standard rate to get to that heading may prevent entry to a graveyard spiral. -- John T http://sage1solutions.com/blogs/TknoFlyer Reduce spam. Use Sender Policy Framework: http://openspf.org ____________________ |
"Cecil Chapman" wrote in message ... Question: As part of the Private Pilot training there is a minimum of 3 hours of hood/instrument training required. One of the things which seems to be always taught (it was the way I was taught and the way I am instructing) is the one minute standard rate turn which is to be used by a Private Pilot if he/she gets theirselves into some IMC, inadvertently. No matter who I ask, I get the same technique (which is the way I was trained during my PPL training); standard rate turn, one minute (3 degrees per second times 60 equals 180 degrees). Aside from the scenario where there is a vacuum system failure (where you lose the DG, for example), what is so wrong with teaching them to look at the bottom of the heading indicator and standard rate turn to that value? The answers I get when I ask this question, vary from, 'I was just taught to use time', 'the pilot is likely to forget the 180 degree heading they were supposed to roll out on', etc... I teach, by timing, just as I was taught, but still haven't got a compelling answer as to why not have them look at the 'bottom' of the DG and turn to that heading (standard rate)? For those I've spoken to that have said, "they are more likely to forget the heading than mess up the time", I can see that they could just as easily lose track of the time as they could the clock. Anyone have any 'whys' on this one? -- =----- Good Flights! Cecil E. Chapman CFI-A, CP-ASEL-IA Check out my personal flying adventures from my first flight to the checkride AND the continuing adventures beyond! Complete with pictures and text at: www.bayareapilot.com "I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery - "We who fly, do so for the love of flying. We are alive in the air with this miracle that lies in our hands and beneath our feet" - Cecil Day Lewis - Cecil, go look back in to your instrument training about gyro precession and turning! |
Of course, given the FAA's current thinking, the whole thing may be moot...
---------------------------------------------------------------------------- -------------------------------------------------- From AC 91-75 b. Replacing the rate-of-turn indicator will mean losing an easy reference for standard rate turns. However, in today's air traffic control system, there is little need for precisely measured standard rate turns or timed turns based on standard rate. Maintaining a given bank angle on the attitude indicator for a given speed will result in a standard rate turn. Pilots using this AC to substitute an attitude indicator for their rate-of-turn indicator are encouraged to know the bank angle needed for a standard rate turn. NOTE: The FAA preamble language for the 1970 amendment to section 91.33, re-codified to section 91.205, states: "[T]he FAA believes, and all other commenters apparently agree . the rate-of-turn indicator is no longer as useful as an instrument which gives both horizontal and vertical attitude information." ---------------------------------------------------------------------------- -------------------------------------------------- So you may soon be seeing students who have never flown a turn coordinator... |
Danny Deger wrote:
This may be a hold over to the old days when a common VFR panel was a turn and bank and a mag compass. In this case using the compass while turning is not good because of the known error caused by being banked. DG's are not required for VFR flight. Even the partial panel IFR training typically use the needle to make timed turns to heading. Once you settle down you can verify with the mag compass you're on the heading you want. |
Similar Threads | ||||
Change in AIM wording concerning procedure turn | Kris Kortokrax | Instrument Flight Rules | 208 | October 14th 05 12:58 AM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
35th's Life Support Section named best in the Air Force | Otis Willie | Military Aviation | 0 | July 16th 04 11:08 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
