tow hook limitation question
Old February 4th 07, 06:49 PM posted to rec.aviation.soaring
Marc Ramsey
Default tow hook limitation question
Jim Vincent wrote:
Kevin, do you have any known examples of this happening? Flying off the
winch is very similar to a glider high scenario, yet I've never had a
problem releasing even under tension.
There have been a number of accidents apparently caused by Schweizer
hooks jamming on the tow plane when the glider gets too high. However,
most everyone has applied an approved fix from years ago, turn the
release assembly upside down and the jamming problem goes away...
Marc
Old February 4th 07, 07:01 PM posted to rec.aviation.soaring
Marc Ramsey
Marc Ramsey wrote:
the winch is very similar to a glider high scenario, yet I've never
had a problem releasing even under tension.
Here's a 337 for a Pawnee:
http://home.att.net/~jdburch/Form337.htm
Marc
Old February 4th 07, 07:03 PM posted to rec.aviation.soaring
Marc Ramsey
However, most everyone has applied an approved fix from years ago,
turn the release assembly upside down and the jamming problem goes
away...
And an article:
http://home.att.net/~jdburch/towhook.htm
Marc
Tow Hook on Cessna 180 - Update Stuart Grant Soaring 13 April 10th 20 10:48 AM
Nose hook addition Jack Soaring 2 April 29th 06 08:08 AM
SZD55 Launch hook info Sleigh Soaring 3 December 28th 05 08:57 PM
Weight Limitation for the Front seats of a C172 Brad Zeigler Piloting 3 August 15th 05 02:43 AM
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 09:32 PM
