No, same IAS, same drag, same thrust, same power requirement from the
engine to generate the thrust. The statement that power is drag time velocity is incorrect. That is the point where the error is made. All of the definitions of power that I have seen have been along the lines of P = T * V, or something that equates to that. For instance:- "The formula for Thrust Horsepower (THP) is: THP = D x V" from http://selair.selkirk.bc.ca/aerodyna...nce/Page4.html. That is wrong? |
xerj writes:
All of the definitions of power that I have seen have been along the lines of P = T * V, or something that equates to that. Yes. I may have misread your previous post as "distance/time" meaning "distance or time" (not distance over time). Force * distance = work Work / time = power Thrust = force A constant IAS requires constant power to maintain at any altitude. A constant TAS requires constant power to maintain at only one altitude; if the altitude increases, the power required diminishes, and vice versa. The power produced by most powerplants diminishes with altitude; the thrust they can maintain at a given IAS varies directly with the power. I think I have that right. It's easy to get confused. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote in message ... A constant IAS requires constant power to maintain at any altitude. A constant TAS requires constant power to maintain at only one altitude; if the altitude increases, the power required diminishes, and vice versa. The power produced by most powerplants diminishes with altitude; the thrust they can maintain at a given IAS varies directly with the power. I think I have that right. It's easy to get confused. -- Transpose mxsmanic and gmail to reach me by e-mail. NOTICE!!!! Mxsmanic is NOT a pilot, has NEVER flown an aircraft and is NOT qualified to issue competent information regarding any aspect of the operation of any aircraft. |
Casey Wilson writes:
NOTICE!!!! Mxsmanic is NOT a pilot, has NEVER flown an aircraft and is NOT qualified to issue competent information regarding any aspect of the operation of any aircraft. And you, I presume, are not a physicist, a mathematician, or an engine mechanic. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "xerj" wrote in message ... No, same IAS, same drag, same thrust, same power requirement from the engine to generate the thrust. The statement that power is drag time velocity is incorrect. That is the point where the error is made. All of the definitions of power that I have seen have been along the lines of P = T * V, or something that equates to that. For instance:- "The formula for Thrust Horsepower (THP) is: THP = D x V" from http://selair.selkirk.bc.ca/aerodyna...nce/Page4.html. That is wrong? You can certainly define a term called Thrust Horse Power as thrust x velocity. And this link definition of Brake Horse Power is correct (torque times RPM). But there is no reason to think these terms are equal in an aircraft. A great deal of the power out of the engine (all of the power if in steady state level flight) goes into the air and not the airframe. It is my understanding that for a given thrust at a given IAS (actually Equivelant Air Speed, EAS, is the better term), the engine power requirement is basically the same for different altitudes. I wish I had a good aircraft performance handbook to confirm this. Danny Deger |
![]() "Danny Deger" wrote in message ... P.S. I have a Master's in Aerospace and have worked in the industry for many years. I will admit most of my schooling and experience was with jets and rockets -- not pistons and props. But I do recall the equations and techniques to calculate engine horsepower required for various flight modes of a prop plane was VERY complex. I am CERTAIN equating thrust horsepower (thrust times velocity) to brake horse power (torque time RPM) is wrong. Anyone have an aircraft performance chart to look at the IAS for 75% power at sea level and at altitude?? I am not going to say it will be exact, but I think it will be close. Danny Deger |
many years. I will admit most of my schooling and experience was with jets and rockets -- not pistons and props. But I do recall the equations and techniques to calculate engine horsepower required for various flight modes of a prop plane was VERY complex. Yeah, those damn eggbeaters hanging out the front make it all pretty complicated. I most certainly DON'T have a Master's in Aerospace. I find it slightly comforting that a guy that does says it's complex. Thanks for taking the time to answer. I am CERTAIN equating thrust horsepower (thrust times velocity) to brake horse power (torque time RPM) is wrong. Anyone have an aircraft performance chart to look at the IAS for 75% power at sea level and at altitude?? I am not going to say it will be exact, but I think it will be close. Do you mean working back from TAS to get an IAS? I looked up a Navajo information manual. There's a chart True Airspeed vs Density Altitude. I chose the line for 260 BHP which is around 75% of the 350 BHP engines. At sea level the TAS is shown as around 207 MPH (have to interpolate, it's a grid that goes up in 10s). That is obviously the IAS as well. At 20,000, the TAS is close to 250 MPH. The inferred IAS is 184. Any thoughts? |
![]() "xerj" wrote in message ... P.S. I have a Master's in Aerospace and have worked in the industry for many years. I will admit most of my schooling and experience was with jets and rockets -- not pistons and props. But I do recall the equations and techniques to calculate engine horsepower required for various flight modes of a prop plane was VERY complex. Yeah, those damn eggbeaters hanging out the front make it all pretty complicated. I most certainly DON'T have a Master's in Aerospace. I find it slightly comforting that a guy that does says it's complex. Jets and rockets are actually much easier to do design work on than prop planes. The jet produces thrust, which is the thrust used to propel the plane. Calculate the thrust required then it is a simple step to calculate fuel flow from the engine to get the thrust. With a prop, exactly what happens as you convert rotation power into thrust is complex, complex, complex. Thanks for taking the time to answer. I am CERTAIN equating thrust horsepower (thrust times velocity) to brake horse power (torque time RPM) is wrong. Anyone have an aircraft performance chart to look at the IAS for 75% power at sea level and at altitude?? I am not going to say it will be exact, but I think it will be close. Do you mean working back from TAS to get an IAS? I looked up a Navajo information manual. There's a chart True Airspeed vs Density Altitude. I chose the line for 260 BHP which is around 75% of the 350 BHP engines. At sea level the TAS is shown as around 207 MPH (have to interpolate, it's a grid that goes up in 10s). That is obviously the IAS as well. At 20,000, the TAS is close to 250 MPH. The inferred IAS is 184. Any thoughts? See my other posts. I stand corrected. For a given engine power, IASI drops off with altitude. For a jet, IASI does not drop off for a given engine thrust as the plane climbs. Maybe that is an inherent reason jets are faster at altitude than a prop. Danny Deger |
"Danny Deger" wrote: "Danny Deger" wrote in message ... P.S. I have a Master's in Aerospace and have worked in the industry for many years. I will admit most of my schooling and experience was with jets and rockets -- not pistons and props. But I do recall the equations and techniques to calculate engine horsepower required for various flight modes of a prop plane was VERY complex. I am CERTAIN equating thrust horsepower (thrust times velocity) to brake horse power (torque time RPM) is wrong. Anyone have an aircraft performance chart to look at the IAS for 75% power at sea level and at altitude?? I am not going to say it will be exact, but I think it will be close. Danny Deger Danny, Go back to "Airplane Performance Stability and Control," by Perkins & Hage, John Wilet & Sons, NY, London (1949). |
"Danny Deger" wrote: "xerj" wrote in message ... No, same IAS, same drag, same thrust, same power requirement from the engine to generate the thrust. The statement that power is drag time velocity is incorrect. That is the point where the error is made. All of the definitions of power that I have seen have been along the lines of P = T * V, or something that equates to that. For instance:- "The formula for Thrust Horsepower (THP) is: THP = D x V" from http://selair.selkirk.bc.ca/aerodyna...nce/Page4.html. That is wrong? You can certainly define a term called Thrust Horse Power as thrust x velocity. And this link definition of Brake Horse Power is correct (torque times RPM). But there is no reason to think these terms are equal in an aircraft. A great deal of the power out of the engine (all of the power if in steady state level flight) goes into the air and not the airframe. It is my understanding that for a given thrust at a given IAS (actually Equivelant Air Speed, EAS, is the better term), the engine power requirement is basically the same for different altitudes. I wish I had a good aircraft performance handbook to confirm this. That is incorrect! A classic problem in sophomore aero engineering is to determine the maximum altitude at which an aircraft will fly, simplifying the problem by assuming turbosupercharging to allow constant power and discounting compressibility effects, given its stall IAS and lift/drag curves. At very high altitudes a plane will fly very fast at low IAS (min porew required speed/alpha. The power = speed*thrust is valid and is a basic tenet of aero engineering. |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
#1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 03:04 AM |
Change in TAS with constant Power and increasing altitude. | Big John | Home Built | 6 | July 13th 03 03:29 PM |
