One is that I am pretty sure that for the same IAS (not TAS) at a higher
altitude, more power is required. However, one contributor to the thread has stated that this is not the case:- You are correct. "Power is net force time velocity. Thrust equals drag, net force is zero. The energy change of the airframe overtime is zero. All energy from the engine is going into the air. That ignores a lot of technical niceties, and inefficiencies, but is adiquate for our purposes. The power to move air to make the same thrust is the same regardless of velocity. Same IAS, same engine power Wrong! That is the basis of most, if not all, of the misconceptions. Power is proportional to thrust times velocity (speed) requirement. Look at some aircraft performance charts." I'd always understood that power = thrust x velocity, hence the deduction that it requires more power to go the same IAS at a higher alt. At the same IAS the drag and hence the thrust is the same. Plug that into the equation and you get the power required, which is more because TAS is higher at altitude. True. As for aircraft performance charts, they're for the most part in TAS, not IAS. However, the same author as the snippet above says:- "The statement that power is drag time velocity is incorrect." Is it? I've seen that formula mentioned in almost every text on power that I've seen. Is there something I'm missing? You are correct. Given constant velocity, thrust and drag are the same. Not trying to be a PITA, just seeking clarification of something I was sure was right. And I know that operationally TAS is much more important than IAS except for, say, stall speed, best glide and the like. So it's a largely an academic question, I realise. It was (sort of) started as a way of finding a plain language non-mathematical explanation for the question "why does the same IAS require more power at altitude?". I haven't found that plain language explanation yet, but now I'm getting conflicting answers as to the very definition of power. Can someone clear it up? TIA! I still think that it's mathematical, but you seem to have simplified it as much as practical. |
