Scary Icing ATC tape
Old February 6th 07, 04:20 AM posted to rec.aviation.piloting
Marco Leon
Default Scary Icing ATC tape
On Feb 5, 6:25 pm, "Peter R." wrote:
On 2/5/2007 5:36:57 PM, "Marco Leon" wrote:
Yes, now that you mention it I recall reading on his forum that he had a hand
in the JFK feeds. Good to see that you help out, too. Thanks for contributing
to a great web-based resource for aviation fans.
I run the KFRG feed as well. Awesome site. I really got a kick out of
hearing my ATC exchange on a feed from way up in NH on the way home
from Bangor.
I saw that he was a pilot but didn't realize he also flew a Bonanza.
I believe he's in the Boston area. I smell a LiveATC fly-in
brewing...once the temperatures rise of course.
Marco
  #92
Old February 6th 07, 01:10 PM posted to rec.aviation.piloting
john smith
In article . com,
from Bangor.
Marco,
What are some good inexpensive scanners (brand and costs) for LiveATC
use?
What have you seen/read of people using to supply their links?
  #93
Old February 6th 07, 03:28 PM posted to rec.aviation.piloting
James Robinson
from Bangor.
Marco,
use?
Radio Shack currently has a relatively good scanner, the Pro-84, on sale
for $50, after rebates. That is a real steal, since they were originally
sold for $200. The sale ends February 10:
http://tinyurl.com/2b2qeh
It is a rebranded Uniden BC92XLT and is marketed as a NASCAR scanner. What
that means is that the scanner has a NASCAR sticker on it, and is pre-
programmed with NASCAR team frequencies. The frequencies can be deleted or
overridden.
The scanner covers the aircraft band, along with other public service
bands, and can therefore be used as an air scanner.
  #94
Old February 6th 07, 03:57 PM posted to rec.aviation.piloting
Marco Leon
On Feb 6, 8:10 am, john smith wrote:
Marco,
use? What have you seen/read of people using to supply their links?
I can do better than that, here are some actual pictures of feeders'
setups: http://www.liveatc.net/forums/index.php/board,4.0.html
I use a Uniden BC278CLT that I got a local store for about $130. The
Sporty's base scanner looks like it will do as well. The JFK feeds
have a bank of Uniden BC350A's (also around $130) and a Radio Shack
model that escapes me at the moment. The main features that are needed
from a scanner a
- a line out
- a programmable bank of freq's to scan
- a delay function (so people can reasonably follow an exchange)
Even the most basic scanners have these capabilities. What really
drives a good feed is the receiver's proximity to the transmitting
antenna. You can also setup a nice antenna on your roof if your
proximity-challenged. I have one but being .25 miles from the airport,
I don't really need it.
They provide the streaming software so with a cable/DSL/fiber
connection that's always on, you're good to go. It's really a low-
maintenance task to be a feeder.
Marco
  #95
Old February 6th 07, 04:55 PM posted to rec.aviation.piloting
Peter R.
from Bangor.
Yep, I started feeding my home airport's tower and approach frequencies (too
far to do ground and clearance) for the selfish reason that I wanted to
critique my radio skills. It worked.
Peter
  #96
Old February 6th 07, 05:35 PM posted to rec.aviation.piloting
Marco Leon
overridden.
Thanks for the heads-up James! I've been looking for a replacement to
the small Maycom I keep in my car that's on its last legs. I grabbed
the last one at my local Radio Shack. It's got a boatload of more
features than my Maycom at half the price. It even recharges NiMH/
NiCad batteries for you. Cool.
Marco
Wing Tape - Does Thickness Affect Performance? ContestID67 Soaring 87 February 1st 07 03:24 PM
60 Year Old Duct Tape Jay Honeck Piloting 11 January 15th 06 06:52 PM
Known Icing requirements Jeffrey Ross Owning 1 November 20th 04 03:01 AM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 07:44 PM
FAR 91.157 Operating in icing conditions O. Sami Saydjari Instrument Flight Rules 98 December 11th 03 06:58 AM
