Visual coordination of turns revisited
Old February 8th 07, 12:13 AM posted to rec.aviation.piloting
chris[_1_]
Default Visual coordination of turns revisited
On Feb 8, 12:24 pm, Mxsmanic wrote:
Gig 601XL Builder writes:
In the real world we don't have that little V superimposed on the wind
sheild. What we do have is that little dodad ball in most cases in the turn
coordinator. Keep that little ball so it looks like this
|O| and you will be in a coordinated turn.
I know, but under VFR I'm supposed to be looking out the window, not staring
at the ball.
I found some Web pages on this; one of them suggests looking out the side of
the aircraft at the wing. If I'm in level flight, the extension of the wing
out the window points to the horizon, and it moves forward (very slowly,
depending on the distance of terrain). If I turn, however--and if the turn is
coordinated--it seems that the extension of the wing will point to a spot on
the ground that remains stationary. This spot is the center of my turn. The
steeper the turn, the closer this spot will be to my aircraft, but it will
always be aligned with the wing. If no spot above the wing is stationary in
the turn, the turn is uncoordinated.
Does that seem logical?
If you want to know how to make that V do what you want you are going to
have to ask in a flight sim newsgroup.
The pages I read suggest making a mark on the windshield for the purpose, with
a grease pencil or something. The sim provides a more perfect mark than one
can achieve in real life (because in real life one moves one's head, etc.),
but the same technique can be used in real life. The problem with it, though,
is that I'm not sure how fast the heading should be changing for a given
degree of bank, and it's not clear that there is a way to recognize this
intuitively.
Watching the extension of the wing out the side of the aircraft seems to work,
although it's more awkward. The page I read said you can fly the aircraft all
day by watching the wingtip, and this does indeed seem to be true, although I
suppose one would finish the day with a sore neck.
Step on the ball...
You may or may not know about adverse yaw - when you use the ailerons
they are producing more lift on the upgoing wing, and lift produces
drag so the wing initially moves the wrong way. You need to apply
rudder in the direction of the turn as you are using the ailerons,
then back off the rudder as you centre the yoke / stick. You will
then find you need to apply a small amount of left rudder, no rudder
or right rudder depending on the angle of bank. You will soon work it
out.
I still have to glance at the ball from time to time, but it is
something you do get used to.. Every aircraft is different with
regards to how much rudder you need to apply.
Old February 8th 07, 02:17 PM posted to rec.aviation.piloting
Gig 601XL Builder
wind sheild. What we do have is that little dodad ball in most cases
in the turn coordinator. Keep that little ball so it looks like this
staring at the ball.
It isn't a binary set solution. One of the things you learn in basic flight
training is to use the instruments you have without fixating on them.
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 04:40 AM
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
