Nose Strut O-Ring Was Bad...
Old February 9th 07, 03:41 AM posted to rec.aviation.owning
Dave[_3_]
Default Nose Strut O-Ring Was Bad...
Well..
That's .065 AMU's....
I have always found that having the "naughts" in FRONT of the real
numbers was better than having the "naughts' (0's) AFTER the real
numbers...
Dave
On 8 Feb 2007 07:32:25 -0800, "Jay Honeck" wrote:
Last week, in -22 temperatures, our nose gear drooped all the way to
the stop. Later, we were able to put some down pressure on the
stabilator (in the hangar) and bring it back up a couple of inches,
but made plans to have our A&P look at it.
Yesterday, since he wasn't coming in the shop till afternoon, we
decided to go flying first. My landing in Oskaloosa, IA (KOOA) was
gingerly -- a text book soft field landing, with the nose gear staying
high in the air till almost stopped. The strut stayed up around three
inches all the way to parking. The temperature was about 5 above
zero, and I thought that perhaps this had been a transient problem
that had "fixed itself". (We always hope, no? :-)
Not. Mary's landing back in Iowa City was fine, but the strut again
collapsed to the stop -- so we taxied straight to the shop. My A&P
told me that he could "service" it (basically, add air), but after
some discussion we decided to replace the seals in the strut. He
said that the O-rings were likely old (we hadn't replaced them in the
5 years we've owned Atlas), stiff, and perhaps "rolled", so that even
though lubricating the strut and adding air might do the trick for a
while, it would be a stop-gap measure, at best.
I helped him do it, and it took about an hour. (Of course, he's done
it a million times -- the job would have taken me all day, with
instructions, and I might have killed myself doing it.) But now, the
strut is sitting tall again, with new fluids, O-rings, and air
pressure.
Total: $65. Not bad at all, in aviation terms...
He says that it's SOP to apply brake fluid to the struts of the DC-9s
he services (at his day job) every, single time they park. It's
messy, as a result, but their strut seals rarely need to be replaced.
Granville's Strut Seal - Or Other Strut Maintenance Techniques zatatime Owning 4 August 31st 05 04:30 PM
slow roll in a super decathlon Nobody Aerobatics 4 August 24th 05 02:36 AM
Cherokee Strut Lower Strut Seal Replacement Report Mike Spera Owning 3 July 23rd 05 07:07 PM
Three more newbie Qs, if you don't mind :) Ramapriya Piloting 17 November 7th 04 05:03 AM
VW-1 C-121J landing with unlocked nose wheel Mel Davidow LT USNR Ret Military Aviation 1 January 19th 04 05:22 AM
