It's heavily cropped but makes a nice image
-- Upload/view images at www.warbirdz.net Join the Warbirdz Forum Channel http://www.warbirdz.net/phpBB2/index.php www.aus-photographers.com |
Wow,
What an impressive shot! Cheers, Indrek Aavisto |
It does!
Would make one hell of a toaster! :-) -- Darryl Gibbs Aircraft of Australia Aviation Photography. www.aircraftofaustralia.com Vintage and Warbirds. http://www.vintageandwarbirds.com Information on all aspects of aviation, particularly vintage and warbirds. Home of the CNAPG aircraft recognition quiz's, and the Vintage and Warbird mailing list. "Glenn" www.warbirdz.net@come-join-the-forum wrote in message ... It's heavily cropped but makes a nice image -- Upload/view images at www.warbirdz.net Join the Warbirdz Forum Channel http://www.warbirdz.net/phpBB2/index.php www.aus-photographers.com |
A tad close for toasting the marshmallows, aren't ya? ;D
-- Daniel Blakemore ICQ:14459824 Yahoo IM: mylordkhorne |
Are you sure it is cropped, the fuel dump is directly between the engines?
They could use afterburners to ignite the fuel as it is pumped out. |
miket6065 wrote:
Are you sure it is cropped, the fuel dump is directly between the engines? They could use afterburners to ignite the fuel as it is pumped out. Yep. Last time I did any real photography work, cropping an Image didn't change anything on an object ;-) -- Upload/view images at www.warbirdz.net Join the Warbirdz Forum Channel http://www.warbirdz.net/phpBB2/index.php |
![]() "Glenn" www.warbirdz.net@come-join-the-forum wrote in message ... It's heavily cropped but makes a nice image The commentator at the Richmond Airshow put the fuel consumption of this action into laymen's terms when he said this was the equivalent of X number of beer cartons being consumed per second. Sorry, I can't recall the exact number. But I guess a few second worth would keep you in beer for some time! BTW Thanks for the great shots Glenn! there all much better that my own. Although you can't expect to much from the 3 x zoom on my Canon Chris |
"CD" wrote in message
u... "Glenn" www.warbirdz.net@come-join-the-forum wrote in message ... It's heavily cropped but makes a nice image The commentator at the Richmond Airshow put the fuel consumption of this action into laymen's terms when he said this was the equivalent of X number of beer cartons being consumed per second. Sorry, I can't recall the exact number. But I guess a few second worth would keep you in beer for some time! BTW Thanks for the great shots Glenn! there all much better that my own. Although you can't expect to much from the 3 x zoom on my Canon I recall the old RAAF Mirage simulator (analog and ancient by todays standards), it used to give a click for every imperial gallon of fuel consumed (4.5L). At cruise it clicked at a rate of roughly one gallon per second. On after burner it sped up enormously. Now that was a single engine jet, now a big Pig with two (albeit modern) engines doing a dump and burn must be literally roaring through the fuel. -- The Raven http://www.80scartoons.co.uk/batfinkquote.mp3 ** Now I will bring chaos to the world! |
"The Raven" wrote in message
... I recall the old RAAF Mirage simulator (analog and ancient by todays standards), it used to give a click for every imperial gallon of fuel consumed (4.5L). At cruise it clicked at a rate of roughly one gallon per second. On after burner it sped up enormously. Now that was a single engine jet, now a big Pig with two (albeit modern) engines doing a dump and burn must be literally roaring through the fuel. For one thing, the engines aren't that modern; they're essentially '60's technology. Also, don't forget that the fuel capacity of the Aardvark is much higher per unit of thrust than the Mirage - it's designed for long-range bombing, not short-range fighting. -- Alan Erskine |
Re replacment of Australian F111 | hobbit | Naval Aviation | 19 | April 21st 04 11:40 AM |
Australia F111 to be scrapped!! | John Cook | Military Aviation | 35 | November 10th 03 11:46 PM |
