G'day All,
this occurs only if the main rotor blades are not correctly aligned & tracked - I have had it occur once when after many hours of boring tracking - i.e. they put strobe reflecting bits on the end of the blades - for say a 3 bladed job the strobe thingos are sorta like this - | _ / - you as a pilot pull it into a 3' hover & hold it - the maintenance bloke aims his strobe gun on the main rotors usually sitting on the top of a ladder - notes stuff arcane stuff in his little book - sees which one of the 3 is higher or lower. Then we land the helicopter - shut it down & the LAME makes adjustments to all the nuts & bolts on the main rotor hub & the process is repeated - sometimes for an agonising period. Then ya go out & fly it - with the LAMe sitting in with ya - you then put it into an autorotation & if the blades have been tracked successfully then the main rotor RPM should stabilise at the max RPM red line. So I suppose what I am trying to say is that if you experience a main rotor overspeed then the maintenance of the machine is a bit of a worry. I still have the bolt that was removed from the offending blade - it was cracked all the way through - so it is really a very serious problem to experience a main rotor overspeed. see ya Conscious Pilate P.S. Your total logged time for about 3 hrs work is usually about 15mins!! |
FA: 1-Day-Left: Aviation Scanner Fans, Flight Sim Fans - Maps, Charts, JEPPS, DOD, FAA, VFR, IFR, etc. | Pete | Aviation Marketplace | 0 | April 10th 06 01:37 PM |
Jet Helicopter Question | Dick | Rotorcraft | 0 | April 7th 06 11:30 PM |
FA: Aviation Scanner Fans, Flight Sim Fans - Maps, Charts, JEPPS, DOD, FAA, VFR, IFR, etc. | Ed | Aviation Marketplace | 0 | April 4th 06 08:34 PM |
Helicopter Question | Jay Honeck | Piloting | 49 | December 5th 05 05:41 AM |
Helicopter "imcident" question | Chuck | Piloting | 10 | October 19th 04 12:33 AM |
