I ran into quite a few guys who flew P-39's. The all said the same thing. It
	had dangerous flat spin characteristics. . Benig bombardier I asked, "what the hell is .that?" They explained. I don't remember what they said so I can't explain it here. But I am sure guys like Ed and Dudley can. Arthur Kramer Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer  |
			 "ArtKramr" wrote in message ... I ran into quite a few guys who flew P-39's. The all said the same thing. It had dangerous flat spin characteristics. . Benig bombardier I asked, "what the hell is .that?" They explained. I don't remember what they said so I can't explain it here. But I am sure guys like Ed and Dudley can. Flat spins are an aft cg scenario for the P39. Generally, in an airplane with positive stability , a flat spin has to be entered deliberately and HELD with power and aileron; the exact amounts of each differ with each type spun flat. The P39, had a problem with aft cg movement along a very narrow in range parameter with ammunition expenditure. If the airplane exceeded critical angle of attack when the ammo cans were at a certain level, the departure could easily cause an out of envelope spin mode that could go flatter as autorational velocities and moments of inertia changed as the spin progressed into ever increasing yaw rates. Departure in a P39 while in this configuration was a very difficult thing to handle. Pilots like Tex Johnston had little trouble with recoveries under controlled conditions, but a low time pilot on operational flying could find himself in a world of hurt if getting caught this way. It usually happened if the airplane went defensive and turning after an initial extended firing run air to air. If engaged and going defensive, as the speed bled due to radial g and the angle of attack increased, a departure was imminent if you went deep enough into the turn, especially if the turn was being forced down by an aircraft with a lighter WS and lower corner. You could easily be pulled into departure city in a situation like that, and this is indeed what nailed a lot of 39 drivers. If you departed and went flat in this airplane, recovery was NOT where the amateurs should be!!! I should say also that most of the 39 pilots I have talked to through the years liked the airplane after flying it for a protracted period...and that includes Yeager! The trick was to fly it right the first time through to the last time....and I could say THAT about every airplane I've ever flown at least!! :-))) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired  |
			 "Dudley Henriques" wrote in message rthlink.net... "ArtKramr" wrote in message ... I ran into quite a few guys who flew P-39's. The all said the same thing. It had dangerous flat spin characteristics. . Benig bombardier I asked, "what the hell is .that?" They explained. I don't remember what they said so I can't explain it here. But I am sure guys like Ed and Dudley can. Flat spins are an aft cg scenario for the P39. Generally, in an airplane with positive stability , a flat spin has to be entered deliberately and HELD with power and aileron; the exact amounts of each differ with each type spun flat. The P39, had a problem with aft cg movement along a very narrow in range parameter with ammunition expenditure. If the airplane exceeded critical angle of attack when the ammo cans were at a certain level, the departure could easily cause an out of envelope spin mode that could go flatter as autorational velocities and moments of inertia changed as the spin progressed into ever increasing yaw rates. Dudley, do you mean to say that the center of gravity is usually designed such that the airplane avoids a tail slide in a stall? In other words, the nose rolls over and airspeed increases? Departure in a P39 while in this configuration was a very difficult thing to handle. Pilots like Tex Johnston had little trouble with recoveries under controlled conditions, but a low time pilot on operational flying could find himself in a world of hurt if getting caught this way. It usually happened if the airplane went defensive and turning after an initial extended firing run air to air. If engaged and going defensive, as the speed bled due to radial g and the angle of attack increased, a departure was imminent if you went deep enough into the turn, especially if the turn was being forced down by an aircraft with a lighter WS and lower corner. You could easily be pulled into departure city in a situation like that, and this is indeed what nailed a lot of 39 drivers. If you departed and went flat in this airplane, recovery was NOT where the amateurs should be!!! Like being sucked into a black hole? I should say also that most of the 39 pilots I have talked to through the years liked the airplane after flying it for a protracted period...and that includes Yeager! The trick was to fly it right the first time through to the last time....and I could say THAT about every airplane I've ever flown at least!! :-))) All the thrills of your own airplane out to kill you and people shooting at you too! jpt  |
Dudley Henriques wrote:
	Flat spins are an aft cg scenario for the P39. Generally, in an airplane with positive stability , a flat spin has to be entered deliberately and HELD with power and aileron; the exact amounts of each differ with each type spun flat. The P39, had a problem with aft cg movement along a very narrow in range parameter with ammunition expenditure. If the airplane exceeded critical angle of attack when the ammo cans were at a certain level, the departure could easily cause an out of envelope spin mode that could go flatter as autorational velocities and moments of inertia changed as the spin progressed into ever increasing yaw rates. So... what you're saying is, the flat spin recovery technique was to pull the trigger and start shooting...? :-) Jeff  |
Subject:  P=39's and flat spins.
	From: "Dudley Henriques" Date: 7/14/03 11:44 AM Pacific Daylight Time Message-id: ink.net "ArtKramr" wrote in message ... I ran into quite a few guys who flew P-39's. The all said the same thing. It had dangerous flat spin characteristics. . Benig bombardier I asked, "what the hell is .that?" They explained. I don't remember what they said so I can't explain it here. But I am sure guys like Ed and Dudley can. Flat spins are an aft cg scenario for the P39. Generally, in an airplane with positive stability , a flat spin has to be entered deliberately and HELD with power and aileron; the exact amounts of each differ with each type spun flat. The P39, had a problem with aft cg movement along a very narrow in range parameter with ammunition expenditure. If the airplane exceeded critical angle of attack when the ammo cans were at a certain level, the departure could easily cause an out of envelope spin mode that could go flatter as autorational velocities and moments of inertia changed as the spin progressed into ever increasing yaw rates. Departure in a P39 while in this configuration was a very difficult thing to handle. Pilots like Tex Johnston had little trouble with recoveries under controlled conditions, but a low time pilot on operational flying could find himself in a world of hurt if getting caught this way. It usually happened if the airplane went defensive and turning after an initial extended firing run air to air. If engaged and going defensive, as the speed bled due to radial g and the angle of attack increased, a departure was imminent if you went deep enough into the turn, especially if the turn was being forced down by an aircraft with a lighter WS and lower corner. You could easily be pulled into departure city in a situation like that, and this is indeed what nailed a lot of 39 drivers. If you departed and went flat in this airplane, recovery was NOT where the amateurs should be!!! I should say also that most of the 39 pilots I have talked to through the years liked the airplane after flying it for a protracted period...and that includes Yeager! The trick was to fly it right the first time through to the last time....and I could say THAT about every airplane I've ever flown at least!! :-))) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired Thanks Dudley. I got it now, And it only took me 60 years. These guys also had a lot of bad things to say about sitting in front of the engine. It resulted in some very gory crash landings. Arthur Kramer Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer  |
	years liked the airplane after flying it for a protracted period...and that includes Yeager! The trick was to fly it right the first time through to the last time....and I could say THAT about every airplane I've ever flown at least!! :-))) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired Dynamite paperback re the P39: "Nanette" by Edwards Park, Smithsonian Institution Press, 1977. Really great. Quent  |
			 "ArtKramr" wrote in message ... I ran into quite a few guys who flew P-39's. The all said the same thing. It had dangerous flat spin characteristics. . Benig bombardier I asked, "what the hell is .that?" They explained. I don't remember what they said so I can't explain it here. But I am sure guys like Ed and Dudley can. Arthur Kramer Was this flat-spin condition related in any way to an equally-distressing condition I've been told about called the "tumble", in which the P-39 allegedly could flip end-over-end (i.e., swap ends, or tumble, tail-to-front) if sufficient Gs were pulled in turns? Apparently, the aircraft's wings would completely lose their grip on the air or vice versa. Ostensibly, this "tumble" was a bugaboo unique to the P-39. At least, I've never heard of it being associated with its P-63 successor....  |
 Tumblin' P-39s
	I've read the factory findings about the in depth testing done to determine whether this condition actually existed and if so, how to correct it. No amount of adjustment resulted in the factory test pilots to duplicate the manuever described by so many combat pilots. Frustrated, the factory asked the air corps to provide one or more combat pilots who said they had encountered 'tumble' to come to the factory and assist in recreating the situation necessary to cause it. After several test flights with various data points matching what the combat pilots reported, no one was ever able to force a P-39 to tumble. I read this in a 'lessons learned'-type report generated after the extensive testing had been completed. v/r Gordon ====(A+C==== USN SAR Aircrew "Got anything on your radar, SENSO?" "Nothing but my forehead, sir."  |
			 "Gordon" wrote in message ... Tumblin' P-39s I've read the factory findings about the in depth testing done to determine whether this condition actually existed and if so, how to correct it. No amount of adjustment resulted in the factory test pilots to duplicate the manuever described by so many combat pilots. Frustrated, the factory asked the air corps to provide one or more combat pilots who said they had encountered 'tumble' to come to the factory and assist in recreating the situation necessary to cause it. After several test flights with various data points matching what the combat pilots reported, no one was ever able to force a P-39 to tumble. I read this in a 'lessons learned'-type report generated after the extensive testing had been completed. I think the "tumble" stories were a direct result of what uninitiated and green pilots encountered when they caused the Cobra to depart while coupled into accelerated stall and an extreme rearward cg due to the gun cans problem. An accelerated departure in any fighter can be "interesting". With the cg aft far enough, the airplane can exhibit some wild antics as it goes through post stall and develops increasing yaw rates. With roll introduced as this is happening, I wouldn't be at all surprised with a very high disorientation factor in a young inexperienced pilot in this airplane. It would be quite easy for an inexperienced pilot to interpret these wild antics as a "tumble"!!! I don't see any way the airplane would have swapped ends though. To do this requires a tremendous impetus force and a very high energy state, which would be inconsistent with the aerodynamics found in an ever decreasing turn radius caused by a decreasing TAS through the arc of the turn as angle of attack increased up to and past CLmax causing a departure. The resulting stall from this attitude would most likely have been fairly violent in the Aircobra with an aft cg, and depending on where the ball was as the stall commenced, either a high wing roll off or a low wing roll off into the departure would have been a possibility in the P39, which had positive static and dynamic stability when in the cg envelope, but with the cg aft due to ammo expenditure, that roll off could easily have scared the living crap out of an amateur! In the disorientation through the departure, through the incipient post stall stage and throwing in a fully developing spin mode going flat with a coincident extremely high yaw rate associated with this scenario; a young pilot could easily think the airplane had "tumbled" Actually, many pilots don't know this, but to get a prop airplane to tumble, you have to meet specific criteria. Gyroscopic precession from the prop disk is critical to getting an airplane to tumble, which means power!!! This means the airplane has to be carefully set up before a tumble potential can exist. For example, to tumble a Pitts, you set up a 45 degree up line and slow the airplane below Va with FULL POWER. Then you nail full right rudder with full left aileron and forward stick all at once!! This causes a 3 axis inertia coupling that vectors on the gyroscopic precession from the prop 90 degrees ahead of the disk axis as the airplane is being maneuvered in positive pitch. With all three axis coupled, the damn airplane develops a mind of it's own and all you do is hang on for dear life as the energy dissipates through whatever the airplane has decided to do without consulting you :-)) Now, THAT'S a tumble!!! :-)) Personally, I can see no way that an aircraft configured like the P39 could be set up to tumble at departure...violent yes...but I seriously doubt end over end....even with an aft cg. Bell would have picked up on this right away and they didn't. Hell, this is hard enough to set up in a Pitts, much less the Aircobra. My guess is a violent departure, lived through and retold by a VERY "excited" novice :-) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired  |
| Thread Tools | |
| Display Modes | |
| Wrinkly flat panels | [email protected] | Home Built | 27 | March 6th 04 03:12 PM |
| Accelerated spin questions | John Harper | Aerobatics | 7 | August 15th 03 08:08 PM |
