Need help with a rocket motor ID
Old February 4th 07, 03:40 AM posted to alt.binaries.pictures.aviation
William R Thompson
Default Need help with a rocket motor ID
Henry_H@Q_wrote:
I see that there was a lot of discussion I didn't read. I am glad to
see that the source was tracked down. But, I am I bit surprised to see
it was from Rocketdyne.
It looks like someone issued specs that said, basically, "make it
reliable and simple, and don't worry too much about the weight."
(For airplanes, RATO lost out to the army developed "JATO" solid
propellant "boosters.")
I can see why. RATO could be throttled and restarted, but I think
the only application anyone saw for that was in seaplane take-offs.
JATO looks a lot less maintenance-intense than RATO (see attached
picture).
T-Stoff, was a mixture of 80% hydrogen peroxide plus
oxyquinoline or phosphate as a stabilizer. [most of the other 20
percent would have been water. _hh]
And that
C-Stoff was a mixture of 57% methanol + 30% hydrazine hydrate + 13%
water, with
traces of either cupro-potassium cyanide or copper oxide (probably as
a stabilizer).
I accept those as being correct. Methanol the kind of stuff you would
want as a fuel. The hydrazine hydrate would be added to provide
"smooth combustion" and the water may have resulted from using the
highest concentration of hydrazine hydrate that was available, or
possibly it was just added as coolant.
(Usually wiki is a really good place for this kind of stuff, but I
didn't find the exact numbers there)
Those are the same figures in Sutton's "Rocket Propulsion Elements."
I figure that Mano Zeigler gave different numbers in "Rocket Fighter"
due to conditions in Axisland--with the Allies bombing their plants
and supply lines, they may have had to settle for anything that could
flow through the lines and burn.
It is hard to find people in the rocket biz that have had long term
exposure to hydrazine that have not also be exposed to N2O4 so when
there are stories about long term effects, you don't know which to
blame. But I will take the alternative to "in a couple of more days,
they die." Better chronic than prompt.
As I recall, Vance Brand passed out from exposure to dumped fuels
during the Apollo-18/ASTP descent, and the crew was taken to the
hospital afterward. They didn't seem to suffer any long-term effects.
(In ordnance circles, I got into this thing of distinguishing between
"high order" explosions or "detonations" and "low order" explosions or
deflagrations. Then there are "no yield" ones, like tank ruptures. I
use to rankle when people talked about auto gas tanks exploding, or
example. Then I read some dictionaries. The "sufficient" definition of
an "explosion" seems to be some event in which a noise was heard.)
I know people who think that a proper footnote is anything with
an asterisk. (Sorry, but citing a newspaper gossip column isn't
quite the same as citing, say, a trial transcript.)
One thing that was more hazardous on the Me163 than the exotic (for
then) propellants was the operational scenario. Take off, climb to
combat altitude, run out of propellant, glide to a landing spot, and
be stuck on the ground on the landing skids.
The allied pilots quickly figured that out, and that there was little
to be done about powered flight, so they just waited and followed them
down and nailed them on the ground. It is a wonder that anyone had any
stories about explosions, they should have all been killed.
My conclusion from trying to find out what happened was that the
Luffwaffe was totally negligent in keeping any useful accident reports
in the WW II era, at least that I found.
That was a typical condition in the Reich. And, given how hard it was
to find self-confessed Nazis after the war, the condition persisted.
Albert Speer's "Inside the Third Reich" is a classic example.
Designers are often told that "You have to listen to what the user
says, they were the ones that know what is going on.
I agree that you should listen. But you should evaluate what you hear.
Anyone's "eye witness account" is likely to be highly biased and
frequently just imaginary.
That's what I was taught when getting my degrees in hysteria, er, history.
My favorite example has to do with the "Nuts!" event at Bastogne.
There are several accounts of exactly what was said; the accounts
come from people who were there--and they don't match up.
(Although the military historian SLA Marshall claims that the
Germans did, indeed, get the "Nuts!" message. Marshall interrogated
Manteuffel and his staff after the war. At one session Manteuffel
kept blaming his mistakes on his staff. At last one of his subordinates
leaned forward, waggled a finger in Manteuffel's face and shouted
"Nuts! Nuts!")
And, what were the seals and all the other bits made of. I was once
reading a report on the X-1 which was very like an American Lox Me163
and at about the same time. There was something about an explosion and
a fire. The report said they weren't sure what happened, but they
though it might have involved a seal. (I think maybe it was in a check
valve and lit off when the valve closure slammed on it.) They then
started to discuss what sort of special, proprietary LEATHER (!) the
seal was made of. I quit reading.
The Ulmer leather gaskets, which if memory serves were treated with
tricresyl phosphate. The accounts I've read said that the treated gaskets
didn't react with the liquid oxygen--but in the presence of lox, the gaskets
became *very* sensitive to mechanical shock, making them "slightly"
explosive. I think the losses of the X-1A, X-1D and second X-2 were
blamed on that.
--Bill Thompson
Click image for larger version
Mooney Rocket Al Owning 7 September 1st 06 07:31 PM
FS: Harmon Rocket II Rob S. Piloting 0 March 4th 06 11:50 PM
Rocket Man.... Gary Emerson Soaring 2 November 5th 05 04:49 AM
WW-II rocket motor on E-bay - opinions ? BeepBeep Naval Aviation 32 August 11th 05 03:29 PM
TWO EXTREMELY RARE ROCKET BOOKS ON EBAY - INCREDIBLE ROCKET HISTORY! TruthReigns Military Aviation 0 July 10th 04 11:54 AM
