Roberto Waltman writes:
In the final stages, when I was getting consistently good comments on my landings from my flight instructors (on three planes: C152, C172, Cherokees) I still couldn't hold a stable approach on a simulator. You're probably depending a great deal on physical sensations. You can probably get away with that on the aircraft you've been flying, but not all aircraft (it's hard to fly by the seat of one's pants in an Airbus). -- Transpose mxsmanic and gmail to reach me by e-mail. |
VFR flying is different than IMC - when using VFR rules your eyes should
be outside the cockpit - not inside on the instruments. In many ways an instrument approach - even partial panel - is simpler - there are fewer things to look at/be aware of. Of course, if your flying experience is limited to MSFS then it is all the same. Mxsmanic wrote: Roberto Waltman writes: In the final stages, when I was getting consistently good comments on my landings from my flight instructors (on three planes: C152, C172, Cherokees) I still couldn't hold a stable approach on a simulator. You're probably depending a great deal on physical sensations. You can probably get away with that on the aircraft you've been flying, but not all aircraft (it's hard to fly by the seat of one's pants in an Airbus). |
Tim writes:
VFR flying is different than IMC - when using VFR rules your eyes should be outside the cockpit - not inside on the instruments. The manipulation of controls required to fly the plane is identical for both IFR and VFR. -- Transpose mxsmanic and gmail to reach me by e-mail. |
How would you know? You happen to be correct in the staqtement below,
but the generalization you made prior was silly. Visual cues are different in IMC and VFR. The manipulation of controls required to fly the plane is identical for both IFR and VFR. |
Tim writes:
How would you know? It's so self-evident that I'm surprised you ask the question. Why would the controls of an airplane behave _differently_ just because of changing visibility outside the cockpit? It's the same atmosphere, the same control surfaces, the same airframe, the same powerplants ... obviously they will operate exactly the same in both VMC and IMC. One need not be a genius to figure this out, and certainly one need not be a pilot (although it appears that some pilots _haven't_ figured it out). You happen to be correct in the staqtement below, but the generalization you made prior was silly. Visual cues are different in IMC and VFR. There are no visual cues in IMC. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Tim writes: How would you know? It's so self-evident that I'm surprised you ask the question. Why would the controls of an airplane behave _differently_ just because of changing visibility outside the cockpit? It's the same atmosphere, the same control surfaces, the same airframe, the same powerplants ... obviously they will operate exactly the same in both VMC and IMC. One need not be a genius to figure this out, and certainly one need not be a pilot (although it appears that some pilots _haven't_ figured it out). You happen to be correct in the staqtement below, but the generalization you made prior was silly. Visual cues are different in IMC and VFR. There are no visual cues in IMC. The controls don't behave differently (unless the airframe is iced up), but you are neglecting the fact that the pilot is part of the control loop. In VMC the input to the pilot is far different, with considerably more information and lots of subtle cues than it is when in IMC. In IMC, the total input to the pilot is through a few instruments. Peripheral vision won't help you keep the wings level like it does in VMC. Because there is much less information available to the pilot, and his sense of balance can betray that information, it is far more difficult to maintain the control of an aircraft without the visual cues you get in VMC. This isn't about basic aircraft control, it is learning to correctly interpret the instruments to replace the visual cues. Furthermore, it takes a certain degree of concentration as well as practice to do it. Now add in turbulent air, having to navigate, having to set up for an approach, and talking with ATC. Unless you are proficient on interpreting the instruments, you won't be able to simultaneously keep control of the aircraft and also accomplish those peripheral tasks without relying on an autopilot. COnsider the average lifespan of a non-instrument rated pilot in an inadvertent IMC encounter. There were studies done where the average time from entry into IMC to a non-recoverable graveyard spin for non-instrument rated pilots come out to something like 180 seconds. I suspect when you are flying your MSFS you are relying more on the instruments than a real pilot does in VMC, because simply put you don't have the visual cues on a 2D screen that you get when sitting in a real cockpit. You are most likely compensating by using the instruments more than you would in a real airplane, probably without even realizing it. As a result, when you go IMC on the sim, it isn't as big a shift for you as it is for a pilot in a real airplane. Try this: cover up or turn off the instrument display while flying VMC on the computer. See how well you fare compared to when the instruments are there. Now try flying into a simulated cloud with the instruments still covered. Tell me how long you last before you hit the ground. |
Ray Andraka writes:
The controls don't behave differently (unless the airframe is iced up), but you are neglecting the fact that the pilot is part of the control loop. No, the pilot is independent of both the controls and the instruments. He is the interface between the two domains, not part of them. In VMC the input to the pilot is far different, with considerably more information and lots of subtle cues than it is when in IMC. In IMC, the total input to the pilot is through a few instruments. Yes. Peripheral vision won't help you keep the wings level like it does in VMC. Because there is much less information available to the pilot, and his sense of balance can betray that information, it is far more difficult to maintain the control of an aircraft without the visual cues you get in VMC. It is far more difficult for the pilot to decide what control inputs to make. The control inputs themselves are the same. This isn't about basic aircraft control, it is learning to correctly interpret the instruments to replace the visual cues. Yes. I suspect when you are flying your MSFS you are relying more on the instruments than a real pilot does in VMC, because simply put you don't have the visual cues on a 2D screen that you get when sitting in a real cockpit. Agreed. You are most likely compensating by using the instruments more than you would in a real airplane, probably without even realizing it. Probably. As a result, when you go IMC on the sim, it isn't as big a shift for you as it is for a pilot in a real airplane. That depends on what the pilot of the real airplane is accustomed to. Some real pilots might well be instrument oriented, too, especially if they fly large aircraft (and particularly if they have learned to fly _only_ large aircraft, which is difficult in the U.S. but not out of the realm of possibility in other countries). Try this: cover up or turn off the instrument display while flying VMC on the computer. See how well you fare compared to when the instruments are there. Now try flying into a simulated cloud with the instruments still covered. Tell me how long you last before you hit the ground. Hmm ... interesting. I'll try it. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Like Hell there aren't! |
Peter Dohm writes:
Like Hell there aren't! Which visual cues do you have in IMC? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic,
There are no visual cues in IMC. Yeah, right. That's why it's called blind flying, right? -- Thomas Borchert (EDDH) |
MSFS 2004 Video frame rate very slow | Greg Brown | Simulators | 1 | November 11th 05 07:24 PM |
Instrument training | xxx | Instrument Flight Rules | 79 | May 24th 05 11:04 PM |
Instrument training | xxx | Piloting | 82 | May 24th 05 11:04 PM |
"one-week" Instrument Training? | Rod S | Piloting | 7 | August 25th 04 12:03 AM |
Visual bugs in MSFS 2004 | [email protected] | Simulators | 1 | October 4th 03 06:34 PM |
