Hey Prime!
Are a member of the Cherokee group? http://www.piperowner.com/ Probs like yours are discussed regularily there... ...A must for a Cherokee driver.... Dave On 15 Feb 2007 00:50:16 GMT, Prime wrote: We have a really weird one and I'd like some help in the diagnosis. We're in Southern California and have a 1974 Cherokee Cruiser with the O-320E3D. Background: About a year ago we had our annual. During the annual our mechanic took apart the gascolator and checked/cleaned the area. We flew the plane home from the "annual" field to the "home" field without problems. In the next flight or two, we had a situation that would repeat itself a number of times in the last year: During an attempted cold start, we would primecrankfiredie. The primer appeared to burn off and then nothing would get the plane started. I noticed that when trying to start the plane I heard the aux fuel pump continue ticking as if pressure couldn't be maintained in the system. Additionally, there was some gas inside the plane near the fuel tank valve. Our on-field mechanic checked the plane and removed and reassembled the aux fuel pump, cleaned out the primer lines, and rebuilt the mags which probably needed it anyway. One item was that this starting problem happened after a rain. During the summer, we had an uncharacteristic rain. My partner tried to fly and the same primecrankfiredie sequence occurred. He pulled the plugs and found what appeared to be water in them. He cleaned them and put them back in, and the engine fired up and ran normally. Forward all the way to a few days ago. The plane had been down for a nose strut rebuild, and my partner flew the plane afterwards. The next day we had a very small amount of rain. I went out the next day to fly, having been grounded for the strut repair for a few weeks. Since it had rained and I suspected rain might have something to do with the starting problem, I made sure and sumped both tanks and the gascolator. No trace of water. The same sequence of primecrankfiredie occurred with me. After this happened I then re-sumped everything and still found no water. I did notice that once I couldn't start the plane, the aux fuel pump kept ticking as if there was a pressure leak in the system. I looked under the engine and saw some fresh fuel under the carburetor on the nosewheel pant. Since I didn't have any tools with me to pull the plugs, I gave up for the day. A couple of days later my partner went to the plane, pullled the plugs, and found water. He dried the plugs and the plane started right up. Observations: - This has only occurred after it has rained - When it occurs it seems that the fuel pump cannot maintain pressure - We've seen some fuel leakage but no consistency here - We've had it occur even though we don't find obvious water in the system - The two times we've pulled plugs they appeared to have water on them - When it hasn't rained the full starting sequence has been normal and we've seen no fuel leakage Based upon this reocurring problem, we've put some tools in the plane so that we can always pull the plugs. Yet I don't really trust flying the plane a long way or especially if precipitation is forecast. Anybody have any ideas on what could be happening here? T. Long |
FS: PA28-140 | Steve Foley | Aviation Marketplace | 0 | November 27th 06 01:06 PM |
FS: 1966 PA28-140 | Steve Foley | Aviation Marketplace | 0 | July 3rd 06 12:36 PM |
FS: 1966 PA28-140 | Steve Foley | Aviation Marketplace | 0 | February 4th 06 11:48 PM |
Price for PA28-180 | Billy | Owning | 12 | November 5th 04 04:37 PM |
PA28 gas cap | Frank Van Haste | Owning | 19 | July 24th 03 07:17 PM |
